Old Thu, Jul-12-2018, 04:12:02 AM   #11
dcsax
Reputation: 0 dcsax is on a distinguished road
Default Re: SMG2 and TPS issues: long story.
I experienced ALL of these problems on my SMG with 52K miles. Every problem the original OP described went on for 4yrs, +30K miles. The car spent numerous trips to BMW (under an aftermarket warranty up to 100K). Even broke down in the middle lane of the fwy during rush hour traffic. Car wouldn't go into gear and had CHP tow me off to the side of the road. BMW scored about 12K in repairs from my warranty company and the car NEVER ran correctly!
Last resort was when the SMG pump took a dump. Went to Lang Racing and swapped to a 6spd. NEVER looked back!!! Been a couple years and lots of mileage (apprx 17K) and no more codes, problems, or break downs!!! The car also runs so much stronger that ever! Nice reliable car with a nice manual transmission.
Jump to top dcsax is offline   Reply With Quote
Old Thu, Jul-12-2018, 03:21:51 PM   #12
jared212
Reputation: 0 jared212 is on a distinguished road
So you had a worn clutch/ToB, a bad slave cylinder, and a malfunction in the throttle system and swapped the transmission? Seems like you are butt hurt about being screwed by your mechanic and don't even know who or what to blame. I see you quoted an insurance payout but how much did the SMG swap cost in total?
I got tired of getting beat by vettes and every other performance car so I dumped that N/A shit and never looked back.
'04 SGM/Blk|SMG|AA/FS Prima Elite kit|Hacksaw built engine w/ JE/Molnar/Supertech/ARP/lots of ceramic TBC|ID1050x injectors|Radium rail+FPD-XR|Aeromotive FPR|-6an fuel system walbro 450 e85|RMS headers|Magnaflow custom 2.5" sec1|Besian|Redish|ZCP springs/Koni's|Hotchkis front sway bar+deleted rear|Turner Pulleys|Southbend stg 3 DD clutch|Innovate/Spek gauges|relocated SMG|Mishi OCC|Koyo Radiator|CSF oil cooler|basically stock interior and exterior
Jump to top jared212 is offline   Reply With Quote
Old Thu, Jul-12-2018, 07:28:36 PM   #13
dcsax
The repair work was performed at a BMW dealership, at the cost of the warranty company. The biggest pain was taking the car back over and over again, to try to fix it. The dealership kept replacing parts but it just wouldn't run correctly. Once the SMG pump went out (and the warranty expired), I took matter into my own hands and did the SMG to manual conversion. It uses the same transmission that was in the car as it's a conversion, not a swap.
Old Thu, Jul-12-2018, 10:00:21 PM   #14
jared212
Fair enough. I bet your dealer mechanic got a helluva commission check by pointing the finger at the SMG. Insurance company rep would be clueless to fight it.
Old Thu, Jul-12-2018, 10:30:12 PM   #15
qualicas
qualicas's Avatar
You should have bought an Alberta car. M3s are less costly here than almost anywhere else in North America. I just managed to sell a slick top manual finally after 2 years.
Now back to your problem. I'm not really big on coincidences. Car ran fine for 1500 km then problems started. Slave and then new clutch. Now issues. I would be looking at something buggered up in the clutch job. SMG motor and pump should not be bad now if they were okay before. There are a lot of pressure lines in the trans tunnel, one could be leaking. As well, if you bought the car in Canada, the SMG motor should last forever. Heat cooks them, no heat in Canada!
Old Fri, Jul-13-2018, 12:31:12 AM   #16
rovert604
rovert604's Avatar
Thatís what I thought too. I live in Vancouver where people arenít dropping like flies when it gets hot. But my SMG motor decided to call it quits at 100,000 miles. I rarely sit in traffic and Iím mostly on the highway and suburbs during non-gridlock. I mean, my failed SMG motor was 14 years old...so it built up and wore out after a long time.
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, Jul-18-2018, 06:20:56 PM   #17
STR8F4C3
Reputation: 0 STR8F4C3 is on a distinguished road
Thanks for all the replies. I had a leak in the SMG supply line, got a new line in the car drives like a dream. The only issue still lingering is the throttle. Still completely shuts down at 50% throttle, turns on traction control and eml lights. Check engine light also comes on, shows code 230 (p1637). I tried replacing the gas pedal assembly, the only difference is that when I run the EDK test through DIS V44, the result for "full load adaptation" is "100% adaptation not run" whereas before it was "not okay". Everything else on the test checks out. I've spoken to an indy mechanic about this, he's of the opinion it could be anything from wiring to software to a bad throttle body etc. Etc. I will try changing the throttle position sensor on the throttle actuator, but after that I'm out of ideas. As always any help would be appreciated.
In regards to some of the last replies. I looked for six months to find a decent condition, decent price Coupe, and of the few that appeared in Alberta, they were all poorly maintained in one aspect or another. I was just about ready to move on to another BMW when this car appeared. Car is from Richmond, sold at the dealer there.
Something else I should mention is that it's very possible that this issue could have been around before we bought the car. My mom drove it home while I wrote exams, and as such the car wasn't driven hard until after the clutch change. And when the car isn't pushed, there is no issue. Hope this helps.
Jump to top STR8F4C3 is online now   Reply With Quote
Discussing SMG2 and TPS issues: long story. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
