Old Tue, Feb-06-2018, 02:14:00 AM   #31
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Default Re: Joe's 2003 Steel Gray/Cinnamon Journal
Originally Posted by Ninohale View Post
Youíre refreshing
Thanks?
Build///Journal
IG: @Khan_Art_
Old Tue, Feb-06-2018, 02:16:01 AM   #32
Kwakjoe
Kwakjoe's Avatar
Youíre refreshing
Originally Posted by KhanArt View Post
Thanks?
Alright guys, keep it off the public thread. Take it to the private messages if you need to
Jump to top Kwakjoe is online now   Reply With Quote
Old Thu, Feb-08-2018, 09:48:37 AM   #33
maksezzy
Reputation: 0 maksezzy is on a distinguished road
subbed.
I just picked up a steel grey m3 with imola, I have majority of that spreadsheet waiting to install on it.
Jump to top maksezzy is offline   Reply With Quote
Old Fri, Feb-09-2018, 06:31:22 PM   #34
Kwakjoe
Kwakjoe's Avatar
Getting ready to go to Laguna Seca in about a week and of course COG light starts coming on and throwing me in neutral. I did the "stand up" resistor mod. The COG light came on afterwards, but didn't throw me into neutral, however the engine temp didn't get as hot as it did when it did throw me into neutral, so I'm hoping for the best.
On a bright note, flushed the brake system with Castrol SRF and got an alignment at Elite Performance (they have really sick cars over there). Ended up going with -2F, -1.6R for camber and 0F, 1/32R inward for toe.
Originally Posted by maksezzy View Post
subbed.
That's a killer combo as well, let me know if you need any help
Old Fri, Feb-09-2018, 08:10:22 PM   #35
maksezzy
Default Re: Joe's E46 M3 Journal
I had a similar issue with my other m3 with the cog light turning on and it put me in Neutral and locked me out the first time just like all the temp symptoms, but did the resistor mod and had the same light kept coming on so I just did a manual swap to simplify life and turned out it was actually a compression spring that broke inside the transmission. Apparently thatís a common problem as well.
Thanks for the offer, Iíve already installed most of the parts into my tiag m3 recently but the headgasket blew so Iíll now be transporting it all over to the steel grey
Old Fri, Feb-09-2018, 09:31:57 PM   #36
Kwakjoe
Kwakjoe's Avatar
Yeah if it keeps giving me issues I'm gonna just pull the trigger on a 6spd swap
Old Tue, Feb-13-2018, 02:40:24 AM   #37
Kwakjoe
Kwakjoe's Avatar
Getting the car ready for track day next week at Laguna. Flushed the brake and put in Castrol SRF, got a decent alignment, threw on AR20 on my section 1.
Old Wed, Feb-21-2018, 07:00:20 AM   #38
Kwakjoe
Kwakjoe's Avatar
Did my first track day at Laguna Seca with SpeedSF over this President's Day. I was worried about the SMG and the possibility of overheating, but my car ran perfectly! Temps danced around 210F the entire time and never went to anything crazy, the cog light also never came on and SMG definitely made a case to not do the 6spd swap. Also realized I don't need anymore power so I probably will put a pause on the airbox/FI ideas for now.
Couple things I want to do after this track day: SS brake lines, track pads, lighter wheels, and try to "bulletproof the SMG". Overall the car really proved itself to me.
Here are some pictures of throughout the day.
Old Wed, Mar-14-2018, 06:12:29 PM   #39
Kwakjoe
Kwakjoe's Avatar
Small update
I'll be heading to Thunderhill West this Sunday with JaredMV and SeanS54 with the following upgrades done since the last track day: SS brake lines, PFC08 pads, Centric rotors blanks.
It'll also be my last day running with the BCs as I purchased DanAvoN7's old coilover set up (TCKline DAs). I'll be putting these on early April and getting it corner balanced.
Items currently in pipeline: updated eventuri filter, eventuri scoop, gc adjustable endlinks, tckline da coilovers.
Here's a link to a recent mishap with my brake line that finally ended (thank god): http://www.m3forum.net/m3forum/showp...9&postcount=23
Old Thu, Mar-15-2018, 02:20:07 AM   #40
muhli
Reputation: 0 muhli is on a distinguished road
Nice! Let us know how the PFC08s feel. I recently put on ferodo ds2500s and starting to think I should have went with something with a little more bite..
Jump to top muhli is offline   Reply With Quote
Discussing Joe's Street/Track build thread in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
