Old Thu, Jul-21-2016, 05:23:08 PM   #11
stash1
Default Re: New CF Driveshaft ComingTo Market
Originally Posted by bmw m3 s50 View Post
Other companies ( NOT fall line/vac ) had issues where once you installed the driveshaft it could not be removed. You literally had to break/destroy the driveshaft to remove it which made it a no go for maintenance purposes.
From what I read the fall line/vac one did not suffer from this issue and could be removed without damaging.
Not sure how this driveshaft has the removal process engineered into it.
All CF driveshafts so far has suffered from the vibrations at high RPM's
Ahhhh, ok, gotcha...and agreed! I'll be sure to let everyone know!
'04 AW/IR...some mods
Old Thu, Jul-21-2016, 05:28:57 PM   #12
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Reputation: 0 bmw m3 s50 is on a distinguished road
Portugal
Again, I have not personally owned a CF driveshaft but have researched it quite alot. This is what I know so far.
I really want a carbon drive shaft on my car. I do believe that is a key reason why the new m4/m3 are freakishly good at putting almost advised the crank hp to the ground on dynos. I just do not want the deal with all the headaches that the current ones on the market deal with.
Jump to top bmw m3 s50 is offline   Reply With Quote
Old Thu, Jul-21-2016, 05:29:55 PM   #13
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Portugal
I want to see that.
see what?
Old Thu, Jul-21-2016, 06:14:59 PM   #14
TEASE///M3
TEASE///M3's Avatar
Reputation: 0 TEASE///M3 is on a distinguished road
I found a post from Mfactory on a UK forum stating the weight is 20lbs. If i'm not mistaken the stock is 18lbs? I'm hoping one of these figures is wrong.
Untitled by . McFarlin, on Flickr
2006 M3 ZCP Interlagos Blue Manual Cinnamon 6MT Slicktop
RIP 2002 M3 Tiag Dove Grey 6MT
Jump to top TEASE///M3 is offline   Reply With Quote
Old Thu, Jul-21-2016, 06:18:09 PM   #15
Drewster
Drewster's Avatar
see what?
I assume he means see an example. It seems weird that any part would require destruction for removal.
The deal-breaker for me is that some of these companies have said weird things about deflecting the guibo since they remove the center joint.. constantly wearing the guibo for weight savings <10lbs is pretty much a no-go
Old Thu, Jul-21-2016, 06:20:25 PM   #16
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Portugal
He stated in the thread they weight 5kg which is about 11 lbs
Old Thu, Jul-21-2016, 06:21:50 PM   #17
nasieg
nasieg's Avatar
I would be interested and could possible be the 6MT Ginny pig, although I feel that if I was willing to do so, there should be some incentive ($$$) for doing so.
Either way, before I am willing to do so, I want to know exactly what the weight of this drive shaft is and how much it saves over stock? Why is this ALWAYS so hard to find out? Seems like this is still not clear, even on the ones from the competitors. I mean if the main benefit is weight/mass reduction, then it should be the first thing that is advertised. At least I think so.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Sportline CS8's, SG CSL Diffuser, OEM CSL Trunk
Jump to top nasieg is online now   Reply With Quote
Old Thu, Jul-21-2016, 06:23:49 PM   #18
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Portugal
I personally have not owned a carbon driveshaft as I said. This is based off of what read through searches and research on the forums. Everyone has said they are almost impossible to remove resulting in destruction.
Old Thu, Jul-21-2016, 06:26:46 PM   #19
Exactly. I'm not picturing how the shaft needs to be destroyed to be removed. How was it even installed?? The ends should be Giubo and CV (or tail end converted).
Old Thu, Jul-21-2016, 06:35:51 PM   #20
Drewster
Drewster's Avatar
If anything you might have to loosen the diff (which is still a pain in the ass) but destruction? That sounds really weird - like tolerances are off and it's fusing to the input flange or something.
Discussing New CF Driveshaft Coming To Market in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
