Old Fri, Sep-05-2014, 06:37:52 PM   #21
cyberlando
cyberlando's Avatar
Default Re: Ultimate Alignment Specs?
So my question.
When my car is lowered and I run -2.5 camber up front -2 In the rear
And factory setting toe
Is the factory setting no longer recommended ?
Engine:
Interior:
Suspension/Handling:
Old Sat, Sep-06-2014, 11:49:00 PM   #22
01M3Fan
01M3Fan's Avatar
Reputation: 0 01M3Fan is on a distinguished road
Suggest zero toe up front and 3/16" rear
My build journal and mod list:
http://www.m3forum.net/m3forum/showthread.php?t=542798
Jump to top 01M3Fan is offline   Reply With Quote
Old Sun, Sep-07-2014, 12:45:03 AM   #23
Depends on the person and circumstance.
E.g. I used to run slightly toe out in front. I was used to it, it was awesome. Now that I alternate with the m5, my brain isn't calibrated for it and it feels out of control/twitchy. Will not be doing that next round of alignment.
Old Sun, Sep-07-2014, 12:52:37 AM   #24
Brian N
wubalubadubdub
Brian N's Avatar
Originally Posted by cyberlando View Post
Csl settings for a regular m wouldn't be quite right as the track width isn't exactly the same due to the csl having a different King pin than us.
This is not true. The CSL king pins do not widen track as once thought. Rather it merely changes the caster angle of the car. The normal M3 and CSL king pins actually have the same printed part number, but they were just drilled differently to achieve this.
The increased track came from the CSL specific front wheels there were wider than ZCP's.
-My Journal-
Old Sun, Sep-07-2014, 03:42:32 AM   #25
bigjae1976
I'm trying:
Front: -4.0 camber, 0 toe.
Rear: -3.0 camber, 1/8" toe in each side.
I usually run:
Front: -3.7 camber, 0 toe.
Rear: -2.0 camber, 3/16" toe in (total).
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Sep-07-2014, 03:52:01 AM   #26
Originally Posted by bigjae1976 View Post
I'm trying:
I usually run:
That's certainly far from optimal for a street driven car.
Old Sun, Sep-07-2014, 05:02:59 AM   #27
bigjae1976
Default Ultimate Alignment Specs?
If I cared about the street, I'd stay around -3.0 or just mark my tie rods for a street and track setting.
I just run crap tires to get me to/from the track and getting work done.
Old Sun, Sep-07-2014, 11:27:20 AM   #28
Indeed, just mentioned it because the op said he was looking for the ultimate aggressive street alignment.
Old Sun, Sep-07-2014, 11:40:08 AM   #29
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Good thread. I run -2 all around.
Old Sun, Sep-07-2014, 02:32:52 PM   #30
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
So slight toe in will track better and be more suitable for the highway and toe out will make the car more lively, but more of a handful, correct?
Mr. Wolfe
1994 Porsche 911 Factory Widebody
Discussing Ultimate Alignment Specs? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
