Old Fri, Sep-05-2014, 04:22:10 PM   #11
EricSMG
40 something
Default Re: Ultimate Alignment Specs?
Street and AutoX.
I run factory toe-in front and rear, and even sometimes ask for extra front toe-in as I despise a lively steering wheel. I want it heavy, centered and locked down. I want to the car to track perfectly straight with hands off the wheel over bumpy surfaces.
I also run as much camber as stock parts will allows.
2004 E46 M3 6MT SG/Black
Old Fri, Sep-05-2014, 04:26:14 PM   #12
Jonzny
Jonzny's Avatar
Reputation: 0 Jonzny is on a distinguished road
Originally Posted by rmana View Post
I usually ask for CSL specs at my alignment shop as my car is slightly lowered. Cant go wrong with CSL alignment.
This is a good idea. Im gonna do this
Catless Headers | 8.2k Redline | ST Coilovers | Powerflex RTABS & FCABS
Jump to top Jonzny is offline   Reply With Quote
Old Fri, Sep-05-2014, 04:26:40 PM   #13
buzz367
buzz367's Avatar
Reputation: 0 buzz367 is on a distinguished road
whats the csl alignment?
Jump to top buzz367 is offline   Reply With Quote
Old Fri, Sep-05-2014, 04:30:33 PM   #14
bimmerfan08
bimmerfan08's Avatar
My car...
-2.5 camber front
-1.5 camber rear
0" total toe front and 1/8" total toe rear
Old Fri, Sep-05-2014, 05:01:45 PM   #15
x Spades x
Reputation: 0 x Spades x is on a distinguished road
What are CSL specs? I didn't think US alignment shops, would have this.
Jump to top x Spades x is offline   Reply With Quote
Old Fri, Sep-05-2014, 05:06:31 PM   #16
gojcaj
Cool like a fool in a swimming pool
gojcaj's Avatar
Reputation: 0 gojcaj is on a distinguished road
Albania
My car was dialed in approximately like so for street use. I don't daily it but the car has been wonderful.
Front
-2.7*
1/16" Toe In
Rear
-2.2*
3/32" Toe In
Camber plates were then marked with a paint pen at that street setup as well as ~-3.5* camber in the front for easy potential track day switching.
Worth noting is when just changing the camber for the track setup, the toe will move out which will aid in turn in.
My White Wayfarer - 2005 Alpine White E46 M3 Journal
2006 Audi B7 S4 - Moro Blue
Sold
O|||||||O - 2014 Jeep JKURX
Jump to top gojcaj is offline   Reply With Quote
Old Fri, Sep-05-2014, 05:06:37 PM   #17
rmana
Reputation: 0 rmana is on a distinguished road
Any shop that does alignments with Bosch or other good ones will have CSL e46 M3 in the system to pick. My shop has a Bosch alignment machine and it has CSL preset. I am not sure of the specs but will try to dig it up. CSL comes a bit lower than regular M3 so perfect for guys like me who have car lowered.
Jump to top rmana is offline   Reply With Quote
Old Fri, Sep-05-2014, 05:10:37 PM   #18
rmana
CSL specs:
32 00 Wheel Alignment E46 / M3 CSL
Observe test conditions
Front axle:
Total toe 0 4' 7'
Camber (difference between left/right max. 30') -1 45' 20'
Track differential angle with 20 lock on inside wheel -1 40' 30'
Caster(difference between left/right max. 30') With 10 wheel lock 7 34' 30'
With 20 wheel lock 7 48' 30'
Front wheel displacement 0 10'
Maximum wheel lock
Inside wheel approx. 40.85
Outside wheel approx. 33.65
Rear axle:
Total toe 0 4' 6'
Camber (difference between left/right max. 15') -1 50' 15'
Geometrical axis deviation 0 4'
Old Fri, Sep-05-2014, 05:27:28 PM   #19
nowanker
"He's no wanker!"
Different tires also like different camber settings. The distinction will be more important for track use (lap times...) than for street tire wear.
Different suspension setups (stock, lowered, camber plates...) play a role too.
Sooooo many alignment threads!
Old Fri, Sep-05-2014, 05:35:55 PM   #20
cyberlando
cyberlando's Avatar
Csl settings for a regular m wouldn't be quite right as the track width isn't exactly the same due to the csl having a different King pin than us.
Engine:
Interior:
Suspension/Handling:
Discussing Ultimate Alignment Specs? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
