Old Thu, Aug-24-2017, 05:16:41 PM   #151
EricSMG
40 something
Default Re: Ultimate Alignment Specs?
Originally Posted by SQ13 View Post
Any chance your RTAB brackets are installed upside down? I had the same camber issue a while back because of that.
No sir. The rear of my black car sits a little higher than 'normal' and so this is why my camber is lacking.
2004 E46 M3 6MT SG/Black
Old Sat, Aug-26-2017, 03:46:43 AM   #152
C///M
Can anyone confirm what the regular M3 and CSL M3's rear toe settings are in degrees? I'm looking at my alignment sheets from two places, a BMW dealership and an independent shop. The independent shop's computer shows 0.30 total toe in for CSL and 0.36 for regular. I only have CSL toe in specs from the BMW dealership, which is 0.03-0.17. I'm wondering if the 0.36 is the reason I had excessive inner tire wear.
I was going to do an emergency toe adjustment but decided not to mess with the alignment. I have time to take car to get a proper alignment now.
I may be misunderstanding what you're saying/asking, but total toe is the measurement of both sides added together.
The measurements given are MAX recommended. So total toe of 0.30 is 0.15 toe-in on each wheel and 0.36 total toe is 0.18 toe-in on each wheel. The 0.03 - 0.17 specs from the BMW Dealer were definitely listed as per side, not total. So the specs given by both Indy shop and Dealer were both pretty much the same. Dealer gave range, Indy shop just listed max, I've seen both. BMW recommends between 0.03 and 0.17 toe-in, not to exceed 0.36 total toe.
Also, excessive wear on the inside of your tires comes from too much TOE-OUT, not toe-in. Positive toe is toe-in and negative toe is toe-out.
That said, how much negative camber do you run in the rear? I find it hard to believe you'd be running toe-out in the rear. It doesn't make sense. But I can see negative camber and zero toe wearing your inner tires pretty bad.
Jump to top C///M is offline   Reply With Quote
Old Mon, May-28-2018, 07:01:40 PM   #153
zaharias
Greece
Replaced RTABs with powerflex black series and did an alignment
-2 front -1.6 rear with CSL toe in settings.
Car is on Koni Yellows with schnitzer springs & GC street camber plates with staggered Schnitzer type IIIs 8.5/9.5 225/45/18 - 255/40/18).
Car is more comfortable after the alignment, rear end is stable when accelerating (even though the stock rtabs where like new after almost 145K kms) and also did a road trip and hitting 200-260 km and it feels nice and stable.
I might switch to Eibach springs next year.
Jump to top zaharias is offline   Reply With Quote
Old Fri, Jul-13-2018, 01:15:59 AM   #154
duracellttu
Originally Posted by WyattH View Post
Current setup -
Front: -2.0* camber, 3/32'' total toe in, max caster
Rear: -1.7* camber, 3/16'' total toe in
I have not played around with toe as much, just went with TCK's recommended settings which feel nice. I did have camber before at -2.5F/-2.0R and that did feel marginally nicer on turn in.
Next time I will aim for -
Front: -2.2 camber, 1/16'' total toe in
Rear: -1.8 camber, 3/16'' total toe in
To me this is the sweet spot for a single, sporty, street setup that performs and feels great without being overkill at the expense of drivability or tire life.
I run ~32psi F&R normally since I just drive the car for fun on weekends. On road trips, I bump it to ~35 F&R.
245/35 and 275/30 19'' PSS. Not changing anything here.
I'm running the same size tires and am asking my shop to align to the specs you have above. The shop is telling me that they need to toe in degrees. Can you tell me if the numbers below look correct?
Front: 1/16'' total toe in -->0.14 deg total toe in
Rear: 3/16'' total toe in --> 0.42 deg total toe in
again, this is for Fr: 245/35/19 and Rr: 275/35/19 size tires. Thanks for the help!
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Respray and Restoration: RKP Slicktop Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams | CSL Karbonious Airbox | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Fri, Jul-13-2018, 04:14:33 AM   #155
oceansize
Kwisatz Haderach
oceansize's Avatar
First looks good. Second I get .40 instead of .42
Used this
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | RE Diablo Exhaust w/ SS Tips | RE Rasp Pipe
Storm Motorwerks SMG Paddles | Two Tone Black/Grey Interior | Alcantara E-brake Boot
Very Recent Maintenance: FCABs | FCAs | RTABs | Motor Mounts | PS Hoses | Inner/Outer Tie Rods | End Links | Vanos Solenoid |
Driveshaft R&R | Flex Disc | Fan Clutch | Trans Fluid | Diff fluid
Old Fri, Jul-13-2018, 04:48:49 AM   #156
duracellttu
Used this
Thanks, I actually used that same exact website for my conversion. Also, 0.14*3=0.42...if the first looks good the the second is also right.
Old Tue, Jul-17-2018, 12:27:53 AM   #157
hbalzanya69
Reputation: 0 hbalzanya69 is on a distinguished road
If you don't want your tires destroyed in a few thousand miles run the minimum spec for rear toe. There is no point in running that much toe-in in the rear of this chassis.
Jump to top hbalzanya69 is offline   Reply With Quote
Old Tue, Jul-17-2018, 03:07:44 AM   #158
DvSkD4
Reputation: 0 DvSkD4 is on a distinguished road
Originally Posted by 01M3Fan View Post
So - all is right with the world. New RTABs and alignment did the trick - car feels very responsive but stable.
Im going in for an alignment tomorrow, based on everything Ive looked at so far this is essentially the setup Im thinking
Jump to top DvSkD4 is offline   Reply With Quote
Old Tue, Jul-17-2018, 02:42:24 PM   #159
DvSkD4
Yeah I was just talking with my alignment guy, recommended running zero toe in the front and maybe a minimal amount in the rear, but was actually pushing for 0 all around
Old Tue, Jul-17-2018, 02:55:51 PM   #160
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
I haven't read through all of these posts but it seems like everyone's setup varies slightly. Here is my setup:
F: 19x8.5 ET35 245/35/19
R: 19x10 ET40 (plus 20mm spacer, so ET20) 275/30/19
Stock struts (need replacing soon)
Eibach springs
Weekend only car, spirited mountain driving, maybe track at some point in the future
Getting subframe reinforced and new bushings everywhere in a few weeks, so I'll be getting an alignment afterwards. Looking for optimal specs for my setup.
Jump to top Chapelle is offline   Reply With Quote
Discussing Ultimate Alignment Specs? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
