Old Fri, May-18-2018, 04:07:47 PM   #5121
blackknighti30
Swap Addict
Reputation: 0 blackknighti30 is on a distinguished road
Default Re: Comprehensive MSS54/MSS54HP DME Information
Wipe everything from 0x3FE4 to 0x47FF and 0x6000 to 0x7FFF on the slave. That should allow the EWS to be synced with INPA.
Cool, thanks.
Sent from my SM-G965U using Tapatalk
-Paul
2003 "M5" - S62/420g swap, M5 diff, M5 driveshaft, M5 brakes, M5 Traction Bars, M5 Bumpers, M5 Full Leather Interior Swap, M5 Gloss Shadowline, M5 Mirrors, M5 Gauge Cluster,
M5 Ground Control Coilovers, Eibach Sway Bars, UUC Evo3/DSSR, M5 Borla Exhaust w/Muffler Delete, BMW NBT Retrofit, Hella G4 Bi-Xenon Retrofit, APEX PS-7s, e60 Hubs
530i 6-speed swap build thread
2003 530it6 - M54b30/S6S-420g swap, 3.15 540it diff, e60 SSK, VMR VB2 19" Wheels, M5 Gauge Cluster, Hella G4 Bi-xenon Retrofit, NBT Retrofit, Koni Sports, 540i Brakes
2001 749i6 - Retired and being parted out - M5Board Build Log
Jump to top blackknighti30 is offline   Reply With Quote
Old Sun, May-20-2018, 12:13:41 PM   #5122
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
Yeah I'm not even sure if it's useful for that purpose, since all you had to do before was wipe out the ISN on the new DME and then sync it in INPA.
Right. You gotta resync anyway, so... might as well just virginize and not worry about it.
Edit: Just to be clear, 3fe4 is the correct address. INPA doesn't strip out the ds2 reply (12 20 a0) from the output, which makes the address look shifted by 3 bytes.
Thanks. That's odd and I would never every have figured that out.
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Sun, May-20-2018, 12:26:46 PM   #5123
Yeah I could only see it being useful in two scenarios:
1 - you want to copy the ISN to an EWS module for whatever reason (accidentally wiped yours or something perhaps)
2 - You want to keep EWS, don't want to use a BDM, so you modify the program space to look for the ISN elsewhere. But really, at that point I don't know why you wouldn't just delete it.
Well I guess option 3 is if we figure out how to erase/rewrite the boot sector over OBDII
Old Wed, Aug-08-2018, 12:41:53 PM   #5124
ATB88
Reputation: 0 ATB88 is on a distinguished road
What's the difference between the two most recent US MSS54 softwares, with ZB numbers 7842971 and 7842973? All I can find in is that in the table on the OP, they differ in their STAND numbers (J429 vs J469, respectively). Does this mean anything? Why were two different US MSS54 tunes issued on March 13 2009? I'm running 7842971 and wondering if I should be running 7842973 instead?
My car is a completely stock 2002 (01/2002 build date) and 6MT (converted from SMG).
Edit: terraphantm answered this for me in another thread
Difference between J429 vs J469 comes down to the fuel tank leak detection system. Early M3s had unheated modules, while later ones have heated ones. I forget the exact cutoff, I think 2002+ are heated? In which case it would be "more correct" to use whichever ZB# corresponds to J469
Jump to top ATB88 is offline   Reply With Quote
Old Fri, Aug-24-2018, 11:15:21 AM   #5125
kmn
Reputation: 0 kmn is on a distinguished road
Finland
Originally Posted by E46dreamz View Post
looking for k_ti_ga multiplier address for my attached partial read. Anything else required to get my bigger injectors idling nice?
Thanks gents
I'm after the same thing.. Any help?
My car: BMW E46 M3 -01 Imolarot 2
Daily driver: BMW E87 118d -06
Ex cars: E36 328i Coupe -92, E91 320d Touring -06, E36 328i Touring -96, E36 325i Cabriolet -93, E39 528iA Touring -97, E39 535iA Sedan -98, E36 320i Touring -95
Jump to top kmn is offline   Reply With Quote
Old Sat, Aug-25-2018, 10:52:24 AM   #5126
VincentM3E36
Reputation: 0 VincentM3E36 is on a distinguished road
France
Hi,
Send me your partial read, I will tell you the address
Jump to top VincentM3E36 is offline   Reply With Quote
Old Sat, Aug-25-2018, 11:08:32 AM   #5127
VincentM3E36
France
Hi,
There is something that I don’t understand about delete MAF :
Some people put -5000kg/h for K_HFM_DIAG_ML_MIN and I understand that it doesn’t rise a MAF default because DME takes an higher value than -5000kg/h when MAF is unplugged.
But if you do this, how the DME knows that it must calculate RF with Alpha-N map (KF_RF_N_AQ_REL) and not with MAF sensor because it doesn’t know that MAF is unplugged so it must continue to calculate RF with a wrong and fixed MAF value, no ??
Thanks,
Vincent
Old Mon, Sep-17-2018, 02:10:52 PM   #5128
mcpower
Reputation: 0 mcpower is on a distinguished road
Hi guys, what an awesome thread, still not done reading even half of it lol. I keep reading some pages a day based on my schedule.
Couldnt get BMWlogger to work. I have tried with TunerPro but I couldnt find the xdf for my DME. I will keep looking. My DME version is 211322002601-JD79
Also I tried with Chipfilebrowser, it displays my friend's MSS54HP ECU info in the MSS54tuner tab from the partial read but not mine (MSS54). It says it supports MSS54 in the release notes but I cant seem to view or edit anything in the MSS54tuner tab for my ECU.
Lastly, I am reading more into the thread and trying to figure out how to help uncover more stuff within code, If someone wants me to research something tedious, guide me and I'll start working on it.
Thanks,
MC
Jump to top mcpower is online now   Reply With Quote
Discussing Comprehensive MSS54/MSS54HP DME Information in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
