Old Thu, Oct-18-2012, 04:14:32 AM   #21
p0lar
Naturally Agitated
p0lar's Avatar
Default Re: Comprehensive MSS54/MSS54HP DME Information
Originally Posted by matthias2280 View Post
VERY good stuff here. What version of the DATEN files are you using? I flashed my DME to 7837779 and I don't see it listed. I imported V41 into WinKFP. Is there a more recent set of files?
Whats the difference between the MSS54 and MSS54HP build?
Could you send me that .0DA file? I'll analyze it and place it into the list!
Old Thu, Oct-18-2012, 04:16:50 AM   #22
p0lar
Naturally Agitated
p0lar's Avatar
There also seem to be discrepancies between the release number and the file names. Has anyone noticed that? I also see a few duplicate release numbers. however with different models or STAND numbers associated. How would that work ?? Look at 7842975. I see 3 instances of that release, but listed 2 different models and 3 different STAND's.
I noticed this as well, but all I did was write a piece of software that grabs EVERYTHING and spurts it out into a forum-table delimited file. Since all variables are cleared after each file read, there's absolutely zero chance that it has taken these values from a previous file. Interesting, it is!
Old Thu, Oct-18-2012, 04:18:11 AM   #23
p0lar
Naturally Agitated
p0lar's Avatar
Originally Posted by cyberlando View Post
Could you also include in the graphics if it's for manual? I only see smg specific and alot of others not covered don't wanna just assume its manual
Well, some of these would require extrapolation of the data from a specific field. That's doable, but some don't list MT or SMG whatsoever. I can do it, yes, but there's no code in there for MT except possibly HS, which stands for?
Old Thu, Oct-18-2012, 04:20:53 AM   #24
p0lar
Naturally Agitated
p0lar's Avatar
Originally Posted by SliM3 View Post
This is about as far as I've gotten so far in identifying the maps. As I learn more, if it's at all relevant to the direction of this thread, I'd be more than happy to share.
EDIT: p0lar, I should add that I'm not trying to hijack your thread and I'd only post if this is something you'd like to incorporate in this discussion.
You don't need my permission to post such useful information, unload here freely - I wholly encourage it!
Old Thu, Oct-18-2012, 04:58:11 AM   #25
7837779 should correspond to 7937780.0da - which has been present on pretty much every release I've acquired
Old Thu, Oct-18-2012, 05:31:58 AM   #26
beam
Reputation: 0 beam is on a distinguished road
Was there ever a low compression version is the s54?? Why would there be an option for sa858, low compression?
Jump to top beam is offline   Reply With Quote
Old Thu, Oct-18-2012, 06:15:33 AM   #27
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
For places that have really crappy gas maybe?
E46 ///M325i Touring journal
Old Thu, Oct-18-2012, 12:58:24 PM   #28
matthias2280
Reputation: 0 matthias2280 is on a distinguished road
I'll upload it as soon as I get home tonight.
On another note, I flashed to 7837781 to do the rear O2 delete because I was getting CEL's for KAT related codes (178 and 179). So far no codes, but the car seems to have lost a bit of the top end "umph" that the 7837779 gave it compared to the US code. I will run a tank of gas through it and let you guys know what I find out
Sold but not forgotten
2005 ///M3 | PY | Black | 6MT
Karbonius CSL Airbox | Frank Smith Alpha-N
SGT | Helios | Geoff Steel | ST | Rogue
Borla | Dr. Vanos | Powerflex | Hotchkis | VMR | Hankook | ECS
2014 JKU
Big wheels and tires and a buncha other expensive junk
Jump to top matthias2280 is offline   Reply With Quote
Old Thu, Oct-18-2012, 01:03:47 PM   #29
SliM3
SliM3's Avatar
SA858 also designates Hot Climate (Tropics) version
EDIT: Better explained here:
The content of SA 858 varies from engine to engine but generally said you have a modified knock control to avoid a knocking of the engine due to low fuel quality. With the SA 858 you have a modified cooling control to avoid critical situations for the engine concerning overheating. With those options the cars have slightly higher fuel consumption and slightly less power but usually the difference won't be noticed by the customer. Therefore there won't be problems with knocking or overheating engines.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Jump to top SliM3 is online now   Reply With Quote
Old Thu, Oct-18-2012, 02:16:33 PM   #30
SliM3
SliM3's Avatar
Hey matthias, don't know if you have convenient access to E85 but if you do a 70/30 mix with pump/E85, and clearing your adaptations, will definitely regain that "umph". In fact, you gain about 2-3 degrees of timing and better throttle response from mid-range on up.
I know there's a lot of misinformation out there about E85 but I do it all the time and was pretty adamant in the beginning with thoroughly checking diagnostics through INPA. No adverse affects were noted.
-Benjamin Franklin
Discussing Comprehensive MSS54/MSS54HP DME Information in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
