Old Sat, Apr-19-2014, 09:23:18 PM   #101
Got_S54?
Got Lip?
Got_S54?'s Avatar
Reputation: 0 Got_S54? is on a distinguished road
Great write up. I may be getting back into an M3 again and would consider picking up an SMG if I cant find a MT coupe with the color and options I'd want, and just convert it to a MT down the road.
I didnt see any instructions for removing the paddle shifters from the steering column. Is that pretty straightforward?
05 TT 225 Quattro - APR Stage 1|FK coilovers|Megan Adj.Cont.Arms|APR catback|15F/20R spacers|OEM ALMS 18's - daily
02 M3 AW/IR - sold but not forgotten
Jump to top Got_S54? is offline   Reply With Quote
Old Sat, Apr-19-2014, 11:34:02 PM   #102
Pnick
Pnick's Avatar
Check this out..
Old Sat, Apr-19-2014, 11:57:30 PM   #103
Got_S54?
Got Lip?
Got_S54?'s Avatar
Thabks for that pdf. So the steering wheels are the same for the smg and m/t? And the smg simply havethe paddles mounted on the back side? Had no idea! Nice.
Old Wed, May-14-2014, 10:21:08 PM   #104
Being3
Being3's Avatar
Reputation: 0 Being3 is on a distinguished road
Here is a video of the SMG bell housing modification explained.
Jump to top Being3 is offline   Reply With Quote
Old Wed, May-14-2014, 10:31:06 PM   #105
Rontgen
Rontgen's Avatar
Reputation: 0 Rontgen is on a distinguished road
Nice! I'll post this here also...
http://www.m3forum.net/m3forum/showthread.php?t=475959
-Darrell
2001 M5
Jet Black / Black
Jump to top Rontgen is offline   Reply With Quote
Old Thu, May-15-2014, 04:15:32 AM   #106
Being3
Being3's Avatar
Originally Posted by Rontgen View Post
I read ur post... Excellent job...best one yet
Old Fri, Jun-13-2014, 03:01:34 PM   #107
vgrntbeauxner
vgrntbeauxner's Avatar
Reputation: 0 vgrntbeauxner is on a distinguished road
This thread is indispensable. However, I'm looking for some clarity on the gear identification switch (p/n 23142229113) and it's wiring.
I gather that switch replaces the existing reverse switch (p/n 23147524811), and shares a similar connector.
But simply unplugging the old sensor and plugging its connector into the new one results in the reverse lights being constantly illuminated.
The DME has been flashed with EU3, and the VO has been updated along with every module in the car.
Jump to top vgrntbeauxner is offline   Reply With Quote
Old Thu, Jun-19-2014, 01:07:36 PM   #108
Charliexd
Charliexd's Avatar
Reputation: 0 Charliexd is on a distinguished road
Have a question. Was checking out the shopping list and came up with some part numbers that I thought were odd. Can you explain/confirm if these are the same or different?
#07129904567 - Circlip
Comes up as “Fuse”
25111222451 - Lockring
Comes up as “Circlip”
25111222688 - Gear Shift Rod Joint
Superseded as “Joint”
25111220439 - Plastic Washer
Comes up as “Spec. Shim”
25111222015 - Bearing Shifting Arm
Comes up as "Suspension"
Also. If I was to get my BH core exchanged at PT, would there be parts I don't need from your list or would they just do the machining only?
THANKS!
Jump to top Charliexd is offline   Reply With Quote
Old Thu, Jun-19-2014, 03:41:56 PM   #109
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
Going off memory here but I had to trim the ridge off the new gear position sensor connection so it would plug and play. I also had zero issue with reverse lights
Old Thu, Jun-19-2014, 03:48:52 PM   #110
gear identification sensor does not replace the reverse switch. It is switch that exists in addition to the reverse switch
