Old Thu, Dec-09-2010, 08:58:35 PM   #21
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
i got a new fan and new fan clutch i was gonna use
you're welcome to have it for 100 + ship
PM me if you
Jump to top das borgen is offline   Reply With Quote
Old Thu, Dec-09-2010, 10:30:46 PM   #22
Synenergy52
Reputation: 0 Synenergy52 is on a distinguished road
Where's badgtho when you need him on this issue. haa haaaaa
Jump to top Synenergy52 is offline   Reply With Quote
Old Fri, Dec-10-2010, 01:55:54 AM   #23
jayjaya29
Photographer
jayjaya29's Avatar
Its done on my car but I just bought the thing...
Old Fri, Dec-10-2010, 12:38:34 PM   #24
JPoland
Broken My Wallet
JPoland's Avatar
Reputation: 0 JPoland is on a distinguished road
Originally Posted by hcaleman View Post
Pull the fan it sounds like it is on it's last legs. With the current temperatures and highwya driving you shouldn't have any issue. The main concern is sitting stationary in traffic in warmer temperatures. Do a proper delete setup or get a new fan/clutch when the time is available before spring rolls around.
To be clear, you car will still overheat no problem in cold weather when it is stationary and without any fan at all. Free convection is not enough to pull sufficient heat off the radiator, you need forced convection regardless of ambient temperature. So you need to make sure your aux fan is working first.
~Joe
Jump to top JPoland is offline   Reply With Quote
Old Fri, Dec-10-2010, 12:47:14 PM   #25
Supered ///M
Panther fans get on your feet
Supered ///M's Avatar
Reputation: 0 Supered ///M is on a distinguished road
PM me if you
Good deal for new fan and clutch. You can also look into getting a eurodiesel fan from cmuzzy on bf.c. They are generally more reliable than the OEM ones for our cars (they don't implode because of the ring around the blades) and they flow more air. They are a little noisier though.
Probably doesn't matter either way which was you go when push comes to shove, but a lot of people run eurodiesel and it might be something worth looking into if you do want to run a fan.
Also, I don't think anyone mentioned this yet, but make sure your engine mounts aren't worn because that's the most common reason for the fan imploding. There's very little space between the fan and the radiator and worn engine mounts mean the engine will move more when it kicks, throwing the fan into the radiator. Then you have problems.
Originally Posted by JPoland View Post
This is incorrect. You car will still overheat no problem in cold weather when it is stationary and without a fan. Free convection is not enough to pull sufficient heat off the radiator, you need forced convection regardless of ambient temperature. So yes while running without the fan seems like the lesser of 2 evils in this case, don't fool yourself into thinking that just because it is cold outside, you can remain at a standstill for very long while the car is running.
+1
-Sam
Mods: RMS Vortech V1 Supercharger, M50 manifold swap, B&B tri-flo DTM exhaust, Ron Stygar Custom SS kit, autometer oil temp. and boost gauges, ASC throttle body delete, H&R Springs, Bilstein shocks, Dinan rear strut tower brace, Mason front strut tower brace, UUC Barbarian front/rear sway bars, X-brace front subframe connector, JTD rear shock mounts, Steel braided brake lines, yellow tinted fogs, genuine euro plate, ZKW headlights with 8000k LED angel eyes, racing decal, and other stuff
Jump to top Supered ///M is offline   Reply With Quote
Old Fri, Dec-10-2010, 02:07:09 PM   #26
Richardsperry
95 SC M3
Richardsperry's Avatar
Joe, if the aux fan is working, it's not an issue. I've sat in 105F traffic jams with the AC blasting and temps never got over 210F. As long as the aux fan works, the mechanical fan is really redundant.
Old Fri, Dec-10-2010, 02:45:38 PM   #27
JPoland
Broken My Wallet
JPoland's Avatar
Agreed. I guess I just on a tangent in my own mind and forgot the aux fan is still there. Thanks for point that out, I edited my post.
~Joe
Old Fri, Dec-10-2010, 03:01:28 PM   #28
nucci
Reputation: 0 nucci is on a distinguished road
This may be true for stock-ish bolt-on NA cars but is not the case once FI is added. Many in the FI section swear by keeping the stock mechanical fan.
In case anybody may be going FI in the future.
Matt
Jump to top nucci is offline   Reply With Quote
Old Fri, Dec-10-2010, 03:11:56 PM   #29
egebhardt
egebhardt's Avatar
Bagtho isn't going to chime in cuz this has been discussed to death. The original poster should have done a search.
Otherwise, I did the FDM. Had no problems for 2 years. 2 bottle of WatterWetter is overkill to me. I sold the car and the new owner (18yrs old) overheated the engine twice. I have no idea what his conditions were.
97 Byzanz on Magma 4dr - Sold 7.7.17 Jerad in CO
Old Sat, Dec-11-2010, 12:11:52 AM   #30
bl79
Reputation: 0 bl79 is on a distinguished road
Welp, just pulled the fan. Isnt really too tough of a job. Car sounds better now without that damn thing.
Jump to top bl79 is offline   Reply With Quote
delete, fan, mod, pump, question, rollcall
Discussing Fan delete mod roll-call & W. pump question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
