Old Sat, Nov-13-2010, 03:50:53 AM   #11
ClarkeBurns
At the limit of lateral adhesion
ClarkeBurns's Avatar
Reputation: 0 ClarkeBurns is on a distinguished road
I did the fan delete on both my E36s. To clarify, you're removing the mechanical (belt-driven) fan that sits behind the radiator. The (electrical) aux fan is in front of the a/c condenser, and that's what you see from the front of the car.
I wouldn't really call my current car a "fan delete", though. I've got a spal fan on there in its place. Thing sounds like a jet engine, and it kicks on whenever it feels like it. It's weird to have a fan running after you've turned off the car--sometimes it turns on after I've shut the car off.
Seems to work ok. First track day with that setup is Sunday.
Hencini
Previous:
1995 Avus M3
2004 Mystic M3
Current:
1999 Hellrot M3 (125k miles)
Jump to top ClarkeBurns is offline   Reply With Quote
Old Sat, Nov-13-2010, 03:55:23 AM   #12
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
FDM done two years ago, coolant changed to Propylene glycol, installed Stewart WP and no issues since. FYI the steel impeller oem water pumps are no better than plastic.
Jump to top WRXEATR is offline   Reply With Quote
Old Sat, Nov-13-2010, 04:21:33 AM   #13
Supered ///M
Panther fans get on your feet
Supered ///M's Avatar
Reputation: 0 Supered ///M is on a distinguished road
I personally would feel better about knowing I had a steel oem one in there if mine had never been done vs. a plastic oem. I have a stewart now though and wouldn't replace the OEM one with anything else.
Out of curiosity, does anyone know if the aux fan kicks in to cool the coolant or is it solely for AC and just happens to also direct wind through the radiator as well?
-Sam
Mods: RMS Vortech V1 Supercharger, M50 manifold swap, B&B tri-flo DTM exhaust, Ron Stygar Custom SS kit, autometer oil temp. and boost gauges, ASC throttle body delete, H&R Springs, Bilstein shocks, Dinan rear strut tower brace, Mason front strut tower brace, UUC Barbarian front/rear sway bars, X-brace front subframe connector, JTD rear shock mounts, Steel braided brake lines, yellow tinted fogs, genuine euro plate, ZKW headlights with 8000k LED angel eyes, racing decal, and other stuff
Jump to top Supered ///M is offline   Reply With Quote
Old Sat, Nov-13-2010, 04:25:45 AM   #14
WRXEATR
The aux fan is triggered by coolant temperature, so yes I think it would be safe to say it has a slight effect on lowering the temp of the coolant although that may not be its sole intended purpose.
Old Sat, Nov-13-2010, 06:50:39 AM   #15
PurduinaM3
Reputation: 0 PurduinaM3 is on a distinguished road
Been running the fan delete kit from Understeer for 4 years and have had zero problems at all
Jump to top PurduinaM3 is offline   Reply With Quote
Old Sat, Nov-13-2010, 07:29:03 AM   #16
Oogie_M
o_O
Oogie_M's Avatar
Reputation: 0 Oogie_M is on a distinguished road
Taiwan
stewart WP, zionsville radiator, fan delete, temp switch, lower temp thermostat... all at once.
no problems so far. I monitored the coolant temp with a OBD-II reader in traffic & 98F degrees weather, it seemed just fine.
Jump to top Oogie_M is offline   Reply With Quote
Old Sat, Nov-13-2010, 12:16:50 PM   #17
Richardsperry
95 SC M3
Richardsperry's Avatar
I did the fan delete about 8 years ago, no issues at all.
New OE pumps are plastic, (composite), BMW only used metal impellers for a short while. In fact the original pump was a composite, just a different composite. I changed the original water pump and did the fan delete at about 38K miles since it was then a hot topic. I installed a metal impeller pump.
I just changed out the original radiator, expansion tank, cap, hoses and intalled a Stewart pump. (72K miles.) Still no issues.
Old Thu, Dec-09-2010, 06:01:06 PM   #18
bl79
Reputation: 0 bl79 is on a distinguished road
Quick question in the old thread:
Im currently at school but will be going home in about a week. I recently heard an intermittent chirping noise coming from the area around the fan.
If I try to spin the fan by hand it goes pretty well. There is definitely far less resistance than there should be and the fan wiggles a bit as well.
I have an 8 hour drive home next week and really don't want to have to worry about this fan detonating on me. Is it a viable option just to pull the fan for now? Once I get home Im probably going to do a cooling overhaul anyway including SPAL fan.
Essentially my question is can I get away with just taking out the fan without changing anything else(do I even need to bleed the coolant) for a short period of time? Also, its like 20* here and wont be much warmer home.
Jump to top bl79 is offline   Reply With Quote
Old Thu, Dec-09-2010, 06:37:08 PM   #19
Richardsperry
95 SC M3
I'd recommend it. Especially if you are seeing the fan wobble.
Old Thu, Dec-09-2010, 08:34:28 PM   #20
hcaleman
Reputation: 0 hcaleman is on a distinguished road
Pull the fan it sounds like it is on it's last legs. With the current temperatures and highwya driving you shouldn't have any issue. The main concern is sitting stationary in traffic in warmer temperatures. Do a proper delete setup or get a new fan/clutch when the time is available before spring rolls around.
Jump to top hcaleman is offline   Reply With Quote
delete, fan, mod, pump, question, rollcall
Discussing Fan delete mod roll-call & W. pump question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
