Old Thu, Nov-11-2010, 12:41:06 AM   #1
azndrunk74
Reputation: 0 azndrunk74 is on a distinguished road
Taiwan
Default well my rear spring perch ripped, question about removal of control arm
so my damn passenger rear spring perch (upper control arm) ripped due to the stress of my bilstein pss9 adjustment collar. does removing the arm require unbolting the diff? and yes i will be buying rear spring perch reinforcements
not my pics but same ish happened
LSB|Cinnamon
Jump to top azndrunk74 is offline   Reply With Quote
Old Thu, Nov-11-2010, 05:20:01 AM   #2
azndrunk74
Taiwan
Fml..anyone? Lol
LSB|Cinnamon
Old Thu, Nov-11-2010, 05:35:28 AM   #3
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Bulgaria
Had my entire subframe out a while back. So memory is vague. I do remeber saying what a pain it would be to remove the upper control arms with all this **** mounted on the car.
Either way you're either dropping the diff or dropping the subframe.
Jump to top hogger453 is offline   Reply With Quote
Old Thu, Nov-11-2010, 06:19:46 AM   #4
playskool1
NorCal's S54 VANOS/Valve Adjust./Rod Bearing guy
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
holy crap! what's funny is i have those RE reinforcement things for like 6 months and still haven't installed them.
did you buy a new control arm? what spring rates are you running in the rear?
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [228k total miles][original motor]
[115k supercharged miles][17k E85 miles][5k turbocharged miles][1.7k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
Jump to top playskool1 is offline   Reply With Quote
Old Thu, Nov-11-2010, 06:53:50 AM   #5
azndrunk74
Taiwan
limping my car to the shop tomorrow, hoping that it's not the case..
yeah got a OEM control arm. i'm not sure what the pss9 rates are since they're progressive. i dont know how they ripped, i don't launch the car or take hard turns. maybe it's because verts are heavier?
man hurry up and install the reinforcement plates..you don't want to pay $250 for a control arm and then 2-3 hours labor on top..it's cheap insurance.
LSB|Cinnamon
Old Thu, Nov-11-2010, 02:59:27 PM   #6
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
Reputation: 0 tonggi is on a distinguished road
Yes you will have to unbolt the diff so you can wiggle it out of the way.
When you get the plates make sure NOT to use the screw and bolt that holds the perch down, That is the main culprit to the failure, It keeps the perch position in one place all the time and the stress just kept adding up.
While you are there you should do adjustable arms, etc. Monoball upper inner bushings too!! :p
good luck. I have a spare set of the reinforcement plates but a gut feeling tells me to hold on to them ( I have weight jackers with the built in perch)
TiTS Racing in association with MMFN Racing and AYO STFU
Want to buy your High Mileage Car!
Jump to top tonggi is offline   Reply With Quote
Old Thu, Nov-11-2010, 04:08:12 PM   #7
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
Can you please explain this theory? With the plates the load is dispersed, so what difference does not bolting it down do? You still have the same point load so I'm curious what your thoughts are on this
Old Thu, Nov-11-2010, 04:38:14 PM   #8
lucky_doggg7
lucky_doggg7
Reputation: 11 lucky_doggg7 is on a distinguished road
Yikes, I think it's time to get those RE reinforcement plates! Thanks for sharing.
Jump to top lucky_doggg7 is offline   Reply With Quote
Old Thu, Nov-11-2010, 06:50:40 PM   #9
azndrunk74
Taiwan
thanks for the info on unbolting the diff. how many hours would u estimate it would take to do?
i just purchased a set from custom performance, ironically it was cheaper from them because shipping is free (vs $14 from RE).
LSB|Cinnamon
Old Thu, Nov-11-2010, 07:00:54 PM   #10
jph28
Back in 'Merica
Reputation: 0 jph28 is on a distinguished road
Whoa! I never even gave this failure mode a thought... looks like it's time to order some reinforcement plates - installed ASTs about a month ago (although my rear spring "perch" is a larger surface area than that pictured).
Current - 2018 M2, 2015 328d Wagon, 2018 Tahoe
2004 SilverGrey 6MT Sold
Past - '02 M5 / '04 M3 / '12 VW JSW TDI / '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is offline   Reply With Quote
arm, control, perch, question, rear, removal, ripped, spring
Discussing well my rear spring perch ripped, question about removal of control arm in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
