Old Wed, Mar-17-2010, 02:08:53 AM   #1
russian_m3
газа до отказа
russian_m3's Avatar
Reputation: 0 russian_m3 is on a distinguished road
Russian Federation
Default Just bought M3 E46.. SMG question
Hi ,
did a search on smg's didn't find anything useful.
I just bought a 2006 M3.
It has an SMG tranny ,
HOW THE **** does it work ?????
I know its a clutch-less manual tranny , but I feel it shift
no matter what level I put it on.
The little level selector under the SMG shifter ,
I feel mostly comfortable driving it on line (3) 1 2 |3| 4 5...
but I cant predict when car will shift , for me to release gas pedal for it to shift more smoothly ...
any suggestions ?
sorry for noob question , this thing is pissing me off , I have a feeling the tranny has been engineered properly.
P.S.
1 - no its not my first BMW
2- yes I have driven manual cars before (and automatic/tiptronic)
3- yes I have read the instructions
thank you fellow M3-ers
Jump to top russian_m3 is offline   Reply With Quote
Old Wed, Mar-17-2010, 02:17:04 AM   #2
IFX
Reputation: 0 IFX is on a distinguished road
I think you should have test drove one before you bought it.
Are you saying you can't drive it correctly in Auto mode? I'm a bit lost.. as to what your trying to say.
Just stay out of it, is my best advice to you.
05 AW Vert/Imola
Red Roundels
Black Hood Grills
Black Fender Gills
Magnaflow Exhaust
Tinted Tails
6K HID Fogs
C/F Guage Cluster
Jump to top IFX is offline   Reply With Quote
Old Wed, Mar-17-2010, 02:21:55 AM   #3
capnmark4
We're not going to Guam are we?
capnmark4's Avatar
Reputation: 0 capnmark4 is on a distinguished road
Antarctica
Sounds like you are driving A (automatic) 3. Should shift about 3k. Roobe16 posted a link to a 'how to drive a SMG' manual recently. Might try searching for SMG posted by Roobe16.
Mark
'06 M3 Cabriolet/SilberGrau/Gray/SMG
clear reflectors, smoked corners, DICE Silverline Pro
New pic coming soon
BMWCCA 429926
Jump to top capnmark4 is offline   Reply With Quote
Old Wed, Mar-17-2010, 02:22:41 AM   #4
The Nebulizer
The Nebulizer's Avatar
Reputation: 0 The Nebulizer is on a distinguished road
Yeah, sounds like you are in auto mode - get out of that and never use it again. It is only for when you need your girlfriend to drive you home.
Just drive like a manual, but pull the levers instead of stepping on the clutch pedal and moving the stick. The basic driving is simple. You will get better at keeping things smooth with practice.
Jump to top The Nebulizer is offline   Reply With Quote
Old Wed, Mar-17-2010, 02:34:58 AM   #5
Kringkily
Reputation: 0 Kringkily is on a distinguished road
go into manual mode when you shift think in your head lift off then gas when you feel as if you had manual shifted. also remember on a hill BECAREFUL MAKE SURE YOU ARE IN GEAR 1. i can remember how many times I drove up in 2nd gear get to the top and then right as i wanted to go the car rolled back as it tried to "automatically" downshift into 1st. fukin scary.
Jump to top Kringkily is offline   Reply With Quote
Old Wed, Mar-17-2010, 02:45:04 AM   #6
russian_m3
газа до отказа
russian_m3's Avatar
Russian Federation
thanks alot guys for the useful advice.
That's what I've been doing the whole day , driving it in manual mode.
much better like this !
Should of just got a manual M3 :S ..
Old Wed, Mar-17-2010, 02:57:48 AM   #7
wilsel
wilsel's Avatar
Reputation: 0 wilsel is on a distinguished road
It does have a clutch. It's actually the same transmission as the 6spd cars. Only difference is that SMG has hydraulic/electric actuators that can shift faster than a person in S6 mode. It does take a couple weeks of getting used to. I do find myself using S5, and starting out in 2nd gear from stops. 1st gear is pretty useless if you ask me, and 1-2nd gear is not a smooth transition under power. I can't take the delay off auto mode. It's shifts slower than any automatic I've ever driven.
http://www.m3forum.net/m3forum/image.php?u=112891&type=sigpic&dateline=1266947664
Jump to top wilsel is offline   Reply With Quote
Old Wed, Mar-17-2010, 03:01:16 AM   #8
russian_m3
газа до отказа
russian_m3's Avatar
Russian Federation
Thats how I felt , it does shift slower than many automatics.
and for city driving it is smoother starting from 2nd gear !!
so you recommend S5 mode for regular driving ?
Old Wed, Mar-17-2010, 03:02:39 AM   #9
macming
Reputation: 0 macming is on a distinguished road
Originally Posted by russian_m3 View Post
Hi ,
any suggestions ?
P.S.
SMG II is not smooth. You will always feel a bit of the shift, but I find it shifts faster than I can with a manual.
So you should push the shift lever to the right again, so the display shows S (sequential), and then you just shift it yourself. I like S mode when I'm driving by myself, and it feels like I'm in charge of the car.
Otherwise, the car shifts around 3k in auto mode (D).
I actually LOVE the SMG transmission, and hopefully you will like it as well. Just give it time.
Jump to top macming is offline   Reply With Quote
Old Wed, Mar-17-2010, 03:08:56 AM   #10
russian_m3
газа до отказа
russian_m3's Avatar
Russian Federation
I only did 100km on it so far... I am sure I'll get use to it.
I guess it is a matter of time !
Thanks !
bought, e46, question, smg
Discussing Just bought M3 E46.. SMG question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
