Old Mon, Mar-08-2010, 02:46:54 PM   #1
The Real M3
In M we trust
The Real M3's Avatar
Reputation: 0 The Real M3 is on a distinguished road
Default Fitment Question
Hey guys,
I got a chance to pick up some BBS LM's but Im not sure if there gonna fit or not. Or how much fender work im gonna do? The specs are 18X9.5 ET 34 Front, and 18X11 ET13 Rear. I got a good deal on them but not to sure what tire to run or how much fender work is gonna be done. Im stock suspension for now??? Any input. I plan just to run H&R Sport with koni's soon.
Rides:
1997 Estoril ///M3 - CASC GT3
2001 Topaz ///M3
|Painted Reflectors|WeissLicht LED|6000k Lows|More to come...|
Jump to top The Real M3 is offline   Reply With Quote
Old Mon, Mar-08-2010, 05:05:11 PM   #2
///M3AN ONE
Live life to the fullest...
///M3AN ONE's Avatar
Reputation: 0 ///M3AN ONE is on a distinguished road
Fronts are fine, you're gonna need some negative camber and maybe some fender work to make the rears fit but it will. The rears will be a bit aggressive but will work. You're probably gonna have to run a 275 in the rear. I fit a 19x11 ET 25 with a 275 along with a 10mm spacer which was a final ET 15. I am rolled, cut, and have arca's set at around -1.75. The stock rear arms can adjust to at least -1.5 if i remember right. The only tricky part is your lowering springs. I would recommend coils so you can make adjustments easier. Having springs means no adjustment which makes adjustments harder especially with the offsets you want to run. BTW, they should look sick!!! Post pics when you get em on!
Jump to top ///M3AN ONE is offline   Reply With Quote
Old Mon, Jan-16-2012, 05:22:43 PM   #3
f50nut
Reputation: 0 f50nut is on a distinguished road
Default Re: Fitment Question
This is a long shot, but do you still have the wheels? Those are M Coupe / Roadster fitments and I might interested if you want to sell them.
Jump to top f50nut is offline   Reply With Quote
Old Mon, Jan-16-2012, 05:35:04 PM   #4
vndkshn
Goin' crazy... wanna come?
Reputation: 0 vndkshn is on a distinguished road
Yeah, I'm sure nearly two years later the OP will be checking this thread.... nice bump.
2005 Interlagos Blue M3 - Cinammon Interior - ZCP - 6MT - Premium - HK Sound
Performance Mods: D/A Race Software, D/A VAC Lightweight UnderDrive Pulleys, Streamline Panel, Ceramic Coated Stainless headers, Race-cats, B&B Tri-Flow, Motons, Vorshlag plates, GC Adj. Rear Camber Arms, GC Race Hybrid FCAB, Powerflex RTABs, H-Sport Sways, GC adjustable endlinks, GSP Clutch Pedal, 40% Autosolutions SSK, Rogue Trans Mounts, PFC WC/GAC front brake kit, PFC-01s for the track.
Click Here for nightmare ECS story. - LOL, it was deleted, guess it shows the sponsors can get away with anything here.
Jump to top vndkshn is offline   Reply With Quote
fitment, question
Discussing Fitment Question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
