Old Fri, Oct-27-2006, 03:12:34 AM   #1
GR///M3
GR///M3's Avatar
Reputation: 0 GR///M3 is on a distinguished road
Greece
Default bi-xenon headlight swap from euro M3, question
i just got a pair of bi-xenon headlight assemblies + side indicators from an evo M3, 2003.
I want to install them in my non-xenon equipped 2002 M3 (halogen). when i do the swap i heard some stuff around the forums about a bulb out warning coming up....
just curious to see if i'll get it also, and if the install will be plug&play I'm not sure if I will need additional harnesses or something....
if anyone else did it, please post and let me know....
thanks.
///M fan
Jump to top GR///M3 is offline   Reply With Quote
Old Fri, Oct-27-2006, 06:38:48 PM   #2
neil33351
neil33351's Avatar
Reputation: 0 neil33351 is on a distinguished road
They are plug and play but you will need to re-program the LCM. Also you won't get the motor line feature on the headlamps. They will always point straight. The headlamps have a motor that moves them internaly. Good Luck.
Neil
Jump to top neil33351 is offline   Reply With Quote
Old Fri, Oct-27-2006, 06:45:19 PM   #3
GR///M3
GR///M3's Avatar
Greece
someone said that i need to splice wires in order to get just the low beam headlights to work and that i won't get bi-xenon on the high beams or the leveling....
i need to find the additional parts to get it all to work correct.
problem is i don't know what to get and where to get them. if i go to the dealer what else do i need to buy, are there harnesses that will connect to the car side so i don't have to re-wire ?
do i also need sensors for the self-leveling motors ?
///M fan
Old Fri, Oct-27-2006, 09:16:47 PM   #4
UA///M3
Reputation: 0 UA///M3 is on a distinguished road
Neil
WRONG about the plug and play
Jump to top UA///M3 is offline   Reply With Quote
Old Fri, Oct-27-2006, 11:49:44 PM   #5
GR///M3
GR///M3's Avatar
Greece
Neil
what is the LCM ? light control module ?
is this something that is on all bmws ?
ohhh....duhhh you mean the headlight switch in the cockpit.
///M fan
Old Sat, Oct-28-2006, 12:30:17 AM   #6
GR///M3
GR///M3's Avatar
Greece
Neil
so would a dealer reprogram it for me if i asked ?
i would be better off just buying a euro-spec switch off an 03 or later with the same headlights as the ones i got...
///M fan
Old Sat, Oct-28-2006, 06:49:52 AM   #7
GR///M3
GR///M3's Avatar
Greece
it might be that these headlights have brains of thier own, in which case power for each low beam and high beam is all that's needed from the car side.
if not then i will have to get my hands on the euro-spec LCM and wiring diagram.
this could be in interesting DIY post when i'm done.....
///M fan
Old Tue, Nov-07-2006, 01:20:33 AM   #8
GR///M3
GR///M3's Avatar
Greece
u were right they are not plug and play. called pacific bmw today and got a list of additional parts i need. lcm, 2 sensors, and some brackets/extensions.
i don't have the bentley manual, but i know the latest and greatest m3's (06) come with these type of headlights, and so if i could figure out how to wire all this crap up, i would buy the additional parts from pacbmw and do it.
do you know anyone that's got the bentley book or can post the complete curciut ?
components needed:
new LCM (or reflash lcm to latest software)
adaptive headlight level sensors (2)
right side sensor bracket
front angle joint
regulating rod with extension
ride height sensor brackets (3)
and of course, a set of bi-xenon headlamp assemblies.
///M fan
Old Sun, Oct-11-2009, 12:24:26 AM   #9
parad0x
E46 M3 Jet Black 6spd
Reputation: 0 parad0x is on a distinguished road
components needed:
front angle joint
after everythign said and done with all your parts installed, I assume you got the LCM reprogrammed which made the low beams properly and flash to pass to work properly too, but you lost the high beam function when pushing the highbeam stalk forward to click in. I am assumming this LCM upgrade made you loose your constant high beams by pushing forward.. correct? If that is the case, have you got any work around this? have you tried using scott's DIY for the bi-xenon for enabling the flapper to work in the bi-xenons ?
Jump to top parad0x is offline   Reply With Quote
Old Sun, Oct-11-2009, 06:00:51 AM   #10
GR///M3
GR///M3's Avatar
Greece
this function should be enabled after the reflash. there are additional wires and connectors that need to be installed in order to make the high beams stick when pushing the stalk forward. i haven't gotten around to it yet, but i have the parts and wires fabbed and laying around somewhere.....
///M fan
bixenon, euro, headlight, question, swap
FS: Xenon headlight Ss-iLT Parts for Sale/Wanted 0 Thu, May-29-2008 10:44:54 PM
Xenon Headlight Out, Back-on, Out Again? WIDERS911 E46 M3 (2001-2006) 15 Fri, Apr-11-2008 02:08:06 PM
Xenon Headlight Problems fireman3 General BMW Discussion 0 Tue, Dec-13-2005 07:07:04 PM
Xenon headlight question!! 2004m3INjune E46 M3 (2001-2006) 14 Fri, Apr-01-2005 01:56:19 PM
swap e46 M3 xenon bulbs for OEM e39 xenon bulbs??? lthsa E46 M3 (2001-2006) 9 Thu, Dec-09-2004 08:55:15 PM
Discussing bi-xenon headlight swap from euro M3, question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
