Old Wed, Mar-22-2017, 03:06:07 AM   #1
SDTA
Reputation: 0 SDTA is on a distinguished road
Default 05/M3 w/VF570 supercharger needs a clutch
I have around 80,000 on my M3 but I am starting to get some slip. I installed a VF engineering 570 supercharger two years ago and will need a clutch that will handle the HP. Will a stock setup do the trick or do I need to go "trick" for this power? I have never installed a clutch and plan on doing it my self. I have build a lot of cars/trucks and engines but have never delt with a manual tranny.
Any words of advice would be appreciate.
DIY?
off jack stands?
OEM or performance?
What do I all need?
Jump to top SDTA is offline   Reply With Quote
Old Wed, Mar-22-2017, 04:51:32 AM   #2
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
Default Re: 05/M3 w/VF570 supercharger needs a clutch
DIY?
off jack stands?
OEM or performance?
What do I all need?
DIY on jack stands. Go aftermarket. Clutch/flywheel/TOB/rear main seal (why not) and other small stuff..
Took me and a buddy a weekend on jackstands to do it. Simple, but also a giant pain in the ass.
Jump to top E46_USMC is offline   Reply With Quote
Old Wed, Mar-22-2017, 09:45:18 AM   #3
idntknow2005
idntknow2005's Avatar
Reputation: 0 idntknow2005 is on a distinguished road
Default Re: 06/M3 w/VF570 supercharger needs a clutch
You'll need a shit ton of extensions to get the trans bolts off.
2001 E46 ///M3 - LSB+ on Cinnamon - Full Restored
Jump to top idntknow2005 is offline   Reply With Quote
Old Wed, Mar-22-2017, 01:33:01 PM   #4
Flow
Flow's Avatar
Reputation: 0 Flow is on a distinguished road
France
You can DIY it if you feel the courage. Getting the trans out is not complicated but an annoying job.
Also, do not let your clutch slip, or you're in for a flywheel also, and that is some serious extra $
- Florian E46 M3 tightening torques PDF
2004 M3 TiAg / LSB SMG
Jump to top Flow is offline   Reply With Quote
Old Wed, Mar-22-2017, 02:31:22 PM   #5
For a stock like clutch/flywheel that can hold more power, sachs HD: https://www.turnermotorsport.com/p-1...hd-clutch-kit/
No reason to replace the flywheel, unless you've been letting it slip excessively (to the point that its scored).
Buy a new OE pilot bearing, throw out bearing, and rear main seal (easier to do if you buy the one already installed in the mounting bracket) while in there. I'd also suggest doing a metal pivot pin, particularly with a beefier setup-- BMW makes one (e39 540i) or RE makes one.
Clutch is not too bad of a job, especially if you have a friend or two to help with the heavy lifting part.
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5,04 M3 wagon, 2017 i3
Old Wed, Mar-22-2017, 08:11:17 PM   #6
SDTA
Probably a very stupid question.... If the flywheel is scorched could I turn it on a lathe? I own a small Machine shop. I am a gun smith and pretty good on a lathe.
Old Wed, Mar-22-2017, 08:20:23 PM   #7
SDTA
By the way fitting that VF570 in the car was a giant Pita! I have a feeling this won't be nearly as bad. I just convinced my neighbor to let me use his car lift.
Old Wed, Mar-22-2017, 08:34:39 PM   #8
Flow
Flow's Avatar
France
You cannot resurface a dual mass flywheel to my knowledge.
Old Wed, Mar-22-2017, 09:31:51 PM   #9
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
You can do everything on jackstands. I installed a Tilton twin disk in my garage. I have a thread documenting my install on here somewhere. Here as a parts list I found on my phone if that helps. There maybe be a few other things you need
AKG||Euro Headers||Customized Bimmerworld Race Exhaust||Tilton Twin Disk Clutch||RTD||Mishimoto||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||G-Loc Brakes||Enkei NT03||Nitto NT01||Custom Chassis Mounted Splitter||AJ Hartman Fulcrum Wing||TTFS Tune||2800 lbs
Trackspec Autosports
MMI Vehicle Systems
Ravenol
G-loc Brakes
IG: marcdavid.m3
Jump to top mdavidm3 is offline   Reply With Quote
Discussing Car stalls ransomly when coming to a light... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
