Old Mon, Sep-02-2019, 03:40:45 AM   #1
darnelld
darnelld's Avatar
Reputation: 0 darnelld is on a distinguished road
Default Topped of coolant without mixing distilled water
Hey all.. kind f had a brain freeze and topped off my coolant with straight BMW antifreeze. It wasn’t much, just to get the indicator up. Thoughts on if I should be majorly concerned and bleed the entire system? I would think since it was so little maybe it would be ok... maybe add some distilled water to the tank
2008 Silverstone E90 Manual M3. Matching Interior. Carbon accents. 3D M3 - 2 ///
2006 Mystic Blue ZCP Manual M3. Dove Grey Interior. Clear Bra Front Wrap. TCU BT upgrage. GSM Pedal. UUC EVO III + DSSR. RE tranny mounts. 3.91 Dinan LSD. 3D M3///
Jump to top darnelld is offline   Reply With Quote
Old Mon, Sep-02-2019, 08:45:45 PM   #2
Default Re: Topped of coolant without mixing distilled water
I would not worry unless you put in enough to change the mixture substantially. It is a 12 quart system. If you are really OCD, siphon out the reservoir and refill with just distilled water. I’ll let you do the math to figure out how to compensate with water for the amount of pure coolant you put in.
Old Fri, Jan-17-2020, 01:54:02 AM   #3
mickloshh1
mickloshh1's Avatar
Reputation: 0 mickloshh1 is on a distinguished road
You are totally overthinking it.
There are ratio's on the back of the concentrate bottles of coolant which give a huge range of water to concentrate ratio's depending on temp's.
You could put a while liter of concentrate into the system or a liter of water and you would still be fine.
2004 M3 Silver Grey 6Spd MT
Jump to top mickloshh1 is offline   Reply With Quote
Discussing Topped of coolant without mixing distilled water in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
