E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
I don't think pre O2s are crossed sinced they not seem long enough and only one miss fire code at 7400 rpm on cylinder 2. (206)
Maybe the bank 2 pre sensor was damaged? At 840 and 1640 rpm missfires on 4-6 cylinders Any suggestions? Uploading an image failed and I don't think photo bucket works anymore |
Sponsored Links |
from what I understand, pre sensor doesn't have anything to do with your fuel/air mixture. its just there so that it can see if there's any difference in readings between the pre and post cat sensors and based on the post cat sensor readings that's where the computer adjust the fuel/air ratio.. but then again I don't think it would cause you to get misfires...
try putting the coils from that cylinder to another and see if the misfire moves to that. and or spark plugs. |
The pre cat bank 1 and bank 2 sensors are excatly the same length. You likely have them switched.
The pre cats adjust mixture post cats and egt verify the cat functionality Last edited by 95bullet; Tue, Nov-14-2017 at 09:24:20 PM. |
#4 |
It looks like the sensors were installed differently at the factory then diagrams and wire looms were backwards the car is now working
Bookmarks |
Thread Tools | |
Display Modes | |
