Old Mon, Nov-13-2017, 08:28:26 PM   #1
Paulo M
Default O2 sensor confirmation
Hey can you guys confirm which one is bank1 sensor1? Iím assuming itís the purple one? Trying to fix a p0134 code.
Thanks!
BREMBO BBS DIXIS
Old Mon, Nov-13-2017, 09:04:23 PM   #2
Default Re: O2 sensor confirmation
Yes. Pre 1 in that pic. Bank refers to cyls 1-3 & 4-6 iirc. Upstream and downstream will often describe pre or post cat.
/// 2004 SilberGrau M3 ∑ Coupe ∑ 6MT ∑ slicktop ∑ manual seats ∑ no nav______________________JOURNAL
-Evolve-R alpha N ∑ Evolve CSL CF Airbox ∑ eVenturi Scoop ∑ Euro Headers|sect 1 ∑ BMW Motorsport 4.10 ∑ Besian ∑ D/A pullies/fan delete ∑ WPC rod bearings
-TMS Camber & Subf plates ∑ RE Street Trans Mounts ∑ AKG poly SUB/DIFF ∑ SDW RTAB ∑ ZHP knob + UUC DSSR ∑ GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk ∑ APEX 75mm Studs ∑ Sportline 8S 18"x8.5/9.5" ∑ MPSS 245/275 ∑ ss brake/clutch lines
-Pioneer DEH-80PRS ∑ Eclipse PA5422 ∑ CDT HD-6 + WS-100i ∑ CDT EX-530 ∑ 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 ∑ PPI 1600.4 ∑ CDT HD-6 + HD-100 ∑ CDT EX-530 ∑ Clarion 10"
Old Mon, Nov-13-2017, 09:39:00 PM   #3
Paulo M
Sweet, thanks dude
BREMBO BBS DIXIS
Old Mon, Nov-13-2017, 09:51:13 PM   #4
mrgizmo04
mrgizmo04's Avatar
One thing to caution - all the sensors have the same threads on them and could be screwed into any of the spots on exhaust manifold/header. So check, because just because the electric connector is plugged in right, the sensor itself could be on the wrong bank or pre could be in post spot and vice versa. Not all have long enough wires to cross pre vs post, but do those one at a time just to be sure.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, Magnaflow catback, new SAC/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Mon, Nov-13-2017, 10:08:28 PM   #5
Or just use some masking tape and a sharpie and mark the stockers' locations before doing headers :thumbs up:
Old Mon, Nov-13-2017, 10:23:32 PM   #6
maynard423
maynard423's Avatar
Reputation: 0 maynard423 is on a distinguished road
My Preís weíre different in 05. Blue and Green lines were switched. The female connector portions were in the correct order as well. I looked at this diagram specifically along with marking the connectors before hand as well. Never had a single issue with them before or after minus the Bank 2 1 being too short after SS V1 install. I removed each one and transplanted it on the SSís. Thereís no way I got them wrong.
05 M3 6MT Carbon Black Vert
Jump to top maynard423 is offline   Reply With Quote
Old Tue, Nov-14-2017, 01:21:05 AM   #7
dafoe
dafoe's Avatar
http://www.m3forum.net/m3forum/showthread.php?t=463673
Old Tue, Nov-14-2017, 06:14:58 PM   #8
Paulo M
Originally Posted by dafoe View Post
Haha I actually saw that after I made the thread. Very helpful especially the pics. Thanks
What sucks is my engine light went away after driving around for a day. Unfortunately I already bought the sensor lol, not sure what happened there. Probably something to do with the weather change/rain.
BREMBO BBS DIXIS
Old Fri, Nov-24-2017, 07:22:39 PM   #9
Paulo M
So I replaced that bank1 sensor1 o2 sensor with new one as well as disconnect the battery but code p0134 still remains. The previous sensor I’m sure was still good as well considering it had only 3,000 miles.
Any ideas on what it could be or what to check next? It’s obviously not the sensor and I’m certain they’re all in correct locations (dyno at 314whp not long ago and ran perfectly for a year since putting in the sensors). If it means anything I have the ttfs dyno tune and “catless ready” included).
BREMBO BBS DIXIS
Discussing O2 sensor confirmation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
