Old Mon, Nov-13-2017, 01:52:52 AM   #1
Justin458
Reputation: 0 Justin458 is on a distinguished road
Default Clutch help. Forced induction
What’s everyone running for clutches with their turbo/supercharged cars? I want to be able to run full boost and not worry about it. I felt some slipping on my race gas map the other day which has me concerned. Something that will hold lots of power and abuse but still drive somewhat decent. Thanks fellas
Jump to top Justin458 is offline   Reply With Quote
Old Mon, Nov-13-2017, 02:07:37 AM   #2
Nicholas1996
Reputation: 0 Nicholas1996 is on a distinguished road
Greece
Default Re: Clutch help. Forced induction
I got a Clutchmasters FX400. Works good. S/C with 9 psi.
Topaz Blau
PTE 6266 on E85
AEM Infinity.
Jump to top Nicholas1996 is offline   Reply With Quote
Old Mon, Nov-13-2017, 03:56:11 AM   #3
kokgo20
kokgo20's Avatar
On SMG or 6MT?
Build thread
Old Mon, Nov-13-2017, 03:59:42 AM   #4
Nicholas1996
Greece
6MT. With single mass flywheel i should add.
Topaz Blau
PTE 6266 on E85
AEM Infinity.
Old Mon, Nov-13-2017, 03:46:50 PM   #5
Justin458
Forgot to mention 6 speed manual trans
Old Mon, Nov-13-2017, 03:52:14 PM   #6
mrgizmo04
mrgizmo04's Avatar
I know some FI guys still stick with stock clutches. Those can handle even 500hp. With single mass flywheel there are some conversion kits with spring clutch discs.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Nov-14-2017, 01:39:03 AM   #7
808elise
808elise's Avatar
Reputation: 0 808elise is on a distinguished road
FX800
-Josh
Jump to top 808elise is offline   Reply With Quote
Old Tue, Nov-14-2017, 01:48:53 AM   #8
curiouz_g
Reputation: 0 curiouz_g is on a distinguished road
What kind of FI are you running? With S/C cars, you're running less torque than N/A due to the parasitic drag below roughly 5000rpms so a stock clutch will hold. I dyno'd at 500whp and I'm still on my stock clutch at 92k miles.
Daily grinder: 2008 BMW 335I
All weather warrior: 2011 Acura RDX
Weekend thrasher: 2004 BMW M3 6spd Vortech Supercharged VT550+ (500whp @ 9lbs on ONLY 93 )
Toy: 2008 BMW M3 Sedan 6 speed AA Supercharged
Jump to top curiouz_g is offline   Reply With Quote
Old Tue, Nov-14-2017, 08:08:58 PM   #9
Turb02
Turb02's Avatar
This is good info. Im doing a 6mt swap and put down 440whp (93 degrees with 60+% humidity) on a mustang dyno.
This will save me monies.
NOT NARDO
Active Autowerke Stage 2.5-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang
Jump to top Turb02 is offline   Reply With Quote
Old Wed, Nov-15-2017, 07:45:20 PM   #10
Justin458
It’s a stage 2 maximum psi kit so it puts down a lot of torq on the high boost map
Discussing Clutch help. Forced induction in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
