Old Tue, Nov-14-2017, 03:30:17 AM   #31
Zroman610
Zroman610's Avatar
Reputation: 0 Zroman610 is on a distinguished road
Default Re: My $50 Baffled Oil Catch Can
So glad I came across this. I've been searching different brands all being ~$200. Looks super clean and great info regarding setup!
Jump to top Zroman610 is offline   Reply With Quote
Old Tue, Nov-14-2017, 07:32:38 AM   #32
VinceSE2
FKA VinceSE
Sweden
Originally Posted by kippers4brkfast View Post
Yours looks great, I like how its tucked nicely in there.
Originally Posted by Dr M3an M3 View Post
Looks great. I love how recessed this is. You can definitely still fit the SMG pump in there too.
Thanks guys, that’s certainly the result I was shooting for.
I forgot to mention that I also wanted to avoid having the hoses cross through the bin as I doubt that BMW would do it that way. Having the hoses tucked against the wall, and hidden under the cabin filter tray looks much more factory.
In fact most BMW enthusiasts don’t even notice the can until I point it out.
Also, this placement should be easy with the low cost can that the OP of this thread is using.
Perhaps even sitting with it’s bungs out through holes in the rubber thingy (the u-clamp moved forward to be centred to that opening into the engine bay)?
Old Tue, Nov-14-2017, 01:40:12 PM   #33
CharlaybitM3
I dont like DSC
CharlaybitM3's Avatar
Reputation: 0 CharlaybitM3 is on a distinguished road
Some constructive criticism if you want it... The can would separate dirty oil vapour and whatnot about 100x better if you put some super course stainless fibres of some sort in it. Don't pack it super tight but the vapours need surface area to condense onto. Straight from ebay you just have can walls for surface area. Also if you can rig up a pipe on the inlet side to run ~1/2 to 2/3 of the way down to the bottom of the can it would keep said vapours path away from your outlet to vacuum as much as possible therefore increasing the time they have to condense and not make it back into your airbox. GL
"Not putting miles on your M3 is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend..." -Someone Awesome
Originally Posted by TMS951 View Post
I like it on mine, tips didn't line up perfect, but good enough. Its off a newer car that makes more power so I know it makes more power on my car.
You can make a custom flange to connect it to your stock header with JB weld.
Sound is an 8/10, I was expecting it to sound like a V8 since its a V8 exhaust. It doesn't, anybody know why this is? Does it have to do with how I installed it?
Jump to top CharlaybitM3 is offline   Reply With Quote
Old Tue, Nov-14-2017, 07:22:21 PM   #34
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Cross posting because I think this thread will generate more discussion on this compared to where it was originally posted:
GM's chief powertrain engineer on why no catch cans:
To answer the second question first: No, the 2017 Corvette LT1 will not have the Camaro V8 PCV air/oil separator (what the questioner calls a "catch can") added to its oil management system. For those not familiar with the abbreviation PCV, it stands for "positive crankcase ventilation"
Even though the Corvette and Camaro share the LT1, they are very different in execution detail. The LT1 in the Corvette sits lower and very close to the ground to enable an industry-leading low profile hood and good sight lines despite a very low seated position. Having the engine close to the ground is great for keeping the vehicle's center of gravity down, but means the oil pan is relatively shallow. Having little depth in the oil pan means it is very challenging to scavenge oil in high G loading conditions. For this reason we add dry sump lubrication to our high performance models. The Camaro's higher engine position allows for a deeper oil pan and a reliable configuration for picking up oil for delivery to all parts of the engine. Thus the Camaro is able to avoid the cost and mass of the dry sump tank and resulting complexity of the lube system.
The Corvette's dry sump tank looks relatively simple on the outside but the internals are really quite complex. The top third of the tank contains a PCV air/oil separation system. On the Corvette, PCV lines route from the valve covers to the air/oil separator on top of our dry sump tank. Oil from PCV air is separated and returned to the lube system through the oil tank. The PCV separation system on Camaro V8 performs a similar function except oil is returned to the engine oil pan from the PCV separator's drain back tube. The Camaro V8 PCV air/oil separator is more complex than a "catch-can" since it not only separates oil from PCV air it provides a drain back path for this oil to be reused by the lube system. "Catch-can" systems that do not have a drain back path for separated oil run the risk of poor oil pressure performance over time as oil is removed from the lube system.
The bottom line is that both cars use optimized engineering solutions for their lube systems based on vehicle architectural considerations.
^the s54's stock system is like that of the Camaro above.
I have no desire for a catch can. The stuff people are draining is re-condensed oil vapor (which I want, as that reclaimed engine oil) and re-condensed water vapor-- which burns off when it is in your oil, assuming you get your car fully up to operating temp.
Catch cans all look clunky to me (Vince's looks the least clunky), add weight/complexity, require more upkeep, and I don't see a benefit over the factory oil separator.
IG: DrM3anM3
Mods: WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, Karbonius CSL Airbox, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, CSL Engine management with CSL converted DME, Supersprint V1 Stepped headers w/ Oversized Section 1, SS Resonated X-Pipe section 2, RE El Diablo Muffler, BBS LMs w/ PSS, Streamline CSL Bumper, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, , CSL SMG Engine DME tune, CSL '255' SMG DME tune, .
Active Group-Buys (PM if Interested): OE CSL Bootlids, CSL Bumper, OE CSL Wheels, Supersprint Headers/Exhaust MEGA thread, CSL Airbox, Brembo, Cams/Pistons...and more to come!
Please PM me - In search of:
-- Wanting to Trade basically brand new Eagle Eye Smoked Reverse Trunk Lights for a pair that are Non-smoked
Old Tue, Nov-14-2017, 08:30:12 PM   #35
In my case, I don't care about how much it does or doesn't do really because
-It was $100 cheaper to do my catch can than to buy the CSL PVC lines from ECS (best price)
-I like to mod my car, I got to fab up a brace which is fun (to me at least)
-it looks cool to me
-my airbox should get less grime in it
I wouldn't have spent $300. For others, maybe a can isn't worth it no matter how cheap it is.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav______________________JOURNAL
-Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · AP Headers · Euro cat sect 1 · Dinan sect 3 · BMW Motorsport 4.10 · Besian · D/A pullies/fan delete · WPC rod bearings
-TMS Camber & Subf plates · RE Street Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines
-Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Tue, Nov-14-2017, 08:33:17 PM   #36
Dr M3an M3
Dr M3an M3's Avatar
I've never pulled my sock airbox off. Did you notice any grime in your stock airbox?
IG: DrM3anM3
Old Tue, Nov-14-2017, 08:36:27 PM   #37
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
There's a reason the stock airbox has a return hose to the oil pan.
Old Tue, Nov-14-2017, 09:17:02 PM   #38
The csl airbox also has that.
Old Tue, Nov-14-2017, 09:27:48 PM   #39
CSL PVC lines? Only part I can think of that you need to buy is 11157833649, and that's $25
Old Tue, Nov-14-2017, 09:31:37 PM   #40
delvin
Water Champion
Reputation: 0 delvin is on a distinguished road
IMO this is the best catch can on the market. I've run 16lbsof boost (centri on a pushrod 5.0) and have zero trace of oil in the intake track. This is with hoses straight off the vc's into the can and the vacuum is pulled from about 6" before the blower inlet. Stays dry as a bone.
http://www.jcsautomation.com/vs%20catch%20cans.html
Just thought I'd add another option for anyone looking
Jump to top delvin is offline   Reply With Quote
Discussing My $50 Baffled Oil Catch Can in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
