Old Mon, Nov-13-2017, 08:46:27 PM   #21
angelr
angelr's Avatar
Reputation: 0 angelr is on a distinguished road
Default Re: My $50 Baffled Oil Catch Can
What are the hoses made of Tbone? Just be aware that many materials used aren't petroleum safe and will have the oil start to weep through over time, natural rubber is good to go though.
07 z4 m coupe aw over ir
04 IR smg coupe- Dead
Jump to top angelr is offline   Reply With Quote
Old Mon, Nov-13-2017, 08:49:05 PM   #22
James1251
James1251's Avatar
Reputation: 0 James1251 is on a distinguished road
Originally Posted by Brian N View Post
Great even better!
That looks good in black. Though I wonder how it looks with the tubes attached. For almost 500 it would have to look super clean for me to consider something like this. The drug bin solutions look pretty clean already. It would be nice to fill that empty SAP spot though. Hmmm...
I spent $650 with the oil return and powder coated. But once he gets all the lines out on I’ll send you a picture.
05 BMW M3 ZCP BLK/BLK
Jump to top James1251 is offline   Reply With Quote
Old Mon, Nov-13-2017, 08:52:27 PM   #23
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Subscribed. This is gold and something I planned to add for my eventual CSL Airbox. Love of simple, affective, and cheap this is. It looks right at how in the engine bay without looking aftermarket.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Karbonius CSL Airbox, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized section 2, Rogue Engineering Muffler (soon to be switched), WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune.
Active Group-Buys (PM if Interested): OE CSL Bootlids, Supersprint Headers/Exhaust MEGA thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Old Mon, Nov-13-2017, 09:02:52 PM   #24
VinceSE2
FKA VinceSE
Sweden
I don’t mean to highjack this thread, but as a number of alternatives are being discussed I thought I’d go ahead and share my installation as well.
The objective here was to:
• Place whatever little weight there is as far inwards and rearwards as possible
• Keep the can out of the way for other things I want to put in the drug bin
• Make it look as factory as possible
http://www.m3forum.net/m3forum/showthread.php?t=485581
Old Mon, Nov-13-2017, 09:10:19 PM   #25
Dr M3an M3
Dr M3an M3's Avatar
Looks great. I love how recessed this is. You can definitely still fit the SMG pump in there too.
IG: DrM3anM3
Old Mon, Nov-13-2017, 09:14:22 PM   #26
No worries Vince, happy to have other solutions in here, just wanted to show people you could put something pretty nice together for $50 instead of the expensive ones.
Thanks Leighton (Dr. Dan :P )!
Angelr - I linked the hose in the OP. It's just braided rubber. the PSI rating is more than needed, the size was right , the look was right, the price etc...
Also, an update on this...
I've driven a fair bit now and it's started to collect No leaking anywhere, no codes, no smoking lol
Also forgot to mention in the OP that, in that "filter" - the piece with holes in it, I put some steel wool in to filter the oil even further.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Tue, Nov-14-2017, 12:38:23 AM   #27
kippers4brkfast
Reputation: 0 kippers4brkfast is on a distinguished road
Yours looks great, I like how its tucked nicely in there.
2003.5 M3, 2010 VW GTI, 1998 Jeep Cherokee
Jump to top kippers4brkfast is offline   Reply With Quote
Old Tue, Nov-14-2017, 01:02:37 AM   #28
kokgo20
kokgo20's Avatar
I have the same can you have, but i was told that it's not good to have the steel wool in it, I thought it would be a good filter also
Build thread
Jump to top kokgo20 is online now   Reply With Quote
Old Tue, Nov-14-2017, 01:26:54 AM   #29
Any reason why? I'm not having any affect on performance or any codes being thrown.
I also tested it by blowing on it and air was pretty easily coming through - I'm not worried about flow.
-NA S54-
Old Tue, Nov-14-2017, 02:21:01 AM   #30
elbert
Sikkens Autocryl MM
elbert's Avatar
Reputation: 0 elbert has disabled reputation
Wales
Stainless steel wool should be OK.
Regular steel wool, not so much.
04 E46 M3
17 WK2 5.7
01 E46 325iT
Jump to top elbert is offline   Reply With Quote
Discussing My $50 Baffled Oil Catch Can in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
