Old Sun, Nov-12-2017, 07:39:00 PM   #11
WyattH
Default Re: My $50 Baffled Oil Catch Can
^ Yes that. The process is more complicated and not as pretty on 05-06 cars.
Old Sun, Nov-12-2017, 09:18:40 PM   #12
Brian N
wubalubadubdub
Brian N's Avatar
I thought it could be removed and coded out? Thatís my plan anyways.
-My Journal-
Old Mon, Nov-13-2017, 12:43:49 AM   #13
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
I did a similar setup but with a Mishimoto catch can. It works well, usually gets a couple tablespoons of gunk after a track weekend.
Originally Posted by CrookedCommie View Post
I put in a new oil separator, but still noticed a bit of oil consumption between each track day. Ordered a Mishimoto compact catch can (amazon), some 3/8NPT to 10AN fittings, 10AN push lock hose fittings, 10AN push lock hose, and some oetiker clamps (jegs). Reused the stock fittings and mounted the catch can like this to the firewall using the bracket and some self-drilling screws. Going to test this at the track in two weeks, will report back on how it works. Total cost was under $150.
Old Mon, Nov-13-2017, 12:45:01 AM   #14
Ya, looks good! Good mounting for those with ABS there too.
/// 2004 SilberGrau M3 ∑ Coupe ∑ 6MT ∑ slicktop ∑ manual seats ∑ no nav ∑ no xenon ∑ no anything ∑ JOURNAL
Evolve-R Alpha N ∑ Evolve CSL CF Airbox ∑ Eventuri Scoop ∑ Supersprint V1 stepped 63mm ∑ SS V1 S pipe 63mm + 200 cell HFC ∑ OE sect 2 60mm ∑ SS Sport 60mm ∑ BMW Motorsport 4.10 ∑ Besian ∑ RE pullies/fan delete ∑ WPC rod bearings ∑ TMS Camber & Subf plates ∑ RE Trans Mounts ∑ AKG poly SUB/DIFF 95a ∑ SDW RTAB ∑ ZHP knob + UUC DSSR ∑ GroundControl S/A (Koni/Eibach 376/440) + tall RSMs ∑ OE CSL trunk ∑ APEX 75mm Studs ∑ Sportline 8S 18"x8.5/9.5" ∑ MPSS 245/275 ∑ Brembo 996 36/40 345mm Textar ∑ Pioneer DEH-80PRS ∑ Eclipse PA5422 ∑ CDT HD-6 + WS-100i ∑ CDT EX-530 ∑ 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 ∑ PPI 1600.4 ∑ CDT HD-6 + HD-100 ∑ CDT EX-530 ∑ Clarion 10"
Old Mon, Nov-13-2017, 01:00:34 AM   #15
Doesn't even have to be coded out - the software is the same regardless of which year M3 you have.
Old Mon, Nov-13-2017, 01:28:08 AM   #16
WyattH
^ But doesn't is require a jenky looking plug, or an 01-04 air rail?
Eithey way it's cleaner, simpler, and cheaper for 01-04 cars.
Old Mon, Nov-13-2017, 02:39:04 PM   #17
James1251
James1251's Avatar
Reputation: 0 James1251 is on a distinguished road
Originally Posted by tjkenny15 View Post
Nice. Looks good.
I want to find a way to mount mine where I removed the secondary air pump.
Saad racing makes them, kinda expensive but I love how it takes up that empty space from the factory air pump.
05 BMW M3 ZCP BLK/BLK
Jump to top James1251 is offline   Reply With Quote
Old Mon, Nov-13-2017, 03:04:18 PM   #18
tjkenny15
tjkenny15's Avatar
Hmm I like that look ^^^
Thanks for sharing
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Mon, Nov-13-2017, 08:06:47 PM   #19
Brian N
wubalubadubdub
Brian N's Avatar
Great even better!
http://i73.photobucket.com/albums/i217/LiVn_It_UP/IMG_0091_zpsqflgrt6s.jpg[/IMG]
That looks good in black. Though I wonder how it looks with the tubes attached. For almost 500 it would have to look super clean for me to consider something like this. The drug bin solutions look pretty clean already. It would be nice to fill that empty SAP spot though. Hmmm...
-My Journal-
Old Mon, Nov-13-2017, 08:27:30 PM   #20
I suppose. I found an early rail pretty cheap (~$25 I think) on eBay way back when (and now run a CSL rail). And if you don't care about cosmetics, a vacuum cap works fine.
Here's one right now for < $40 - https://m.ebay.com/itm/02130CR-BMW-E...QAAOSwZKBZJJDx
Discussing My $50 Baffled Oil Catch Can in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
