Old Sat, Nov-11-2017, 04:09:48 AM   #1
Default My $50 Baffled Oil Catch Can
I just bought a CSL airbox and wanted to keep it clean so I had started to research, then buy parts for, a baffled oil catch can. There are some nice kits out there, but they're all around $2-300 and I just didn't think it was worth it, so I started to look at cheaper, generic alternatives. The one to best meet my needs was this one:
https://www.ebay.com/itm/Black-Baffl...53.m2749.l2649
So at $33 (it now looks to be $38), I still needed hose and clips. I got some 5/8" i.d. (5ft) dishwasher hose kit with hose clamps (from another ebay seller: https://www.ebay.com/itm/EASTMAN-DIS.../282723945131? ) for $14 and, lastly, got some black spring clips as well for a sleek look on the end that connect to the engine for a few bucks.
I wanted black, smallish (I drive the car pretty little), baffled, with a dip stick and cheap!
That small o-ring didn't come with the kit, it's actually from our oil filter kits and fits the dip stick perfectly, though not necessary.
In the next pic you can see a steel brace which I fabricated from galvanized 1/8" steel stock, 3/4" wide. I cut a 8" piece, drilled my holes, chamfered the holes, made my bends, and took it to the belt sander to round and smooth it out. Then I polished it with Mother's MAG polish. The hardware I got from my favorite metric hardware source, www.belmetric.com.
You could simply use the hardware supplied and affix the can to that black plastic side "wall" in the drug bin, on the outside like most kits do, bit I used a bracked and a free threaded hole not being used that was for earlier models with the ABS in.
Parts:
I would use plumber's tape on the fittings:
Then I "freed" the connections or bibs for the valve cover and airbox by slicing the hose at the ends and pulled them out, the put them in my new hose ends and clamp them:
Mocked up:
I'll have a final, installed photo once I've finished with the airbox install this weekend.
All done:
Hope this is helpful for others
Tyler
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Sat, Nov-11-2017, 06:40:52 PM   #2
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: My $50 Baffled Oil Catch Can
Solid install , looks like It’s supposed to be there. Is the hood going to crush the hose at the rubber seal? Or is it elevated?
S54 E36 BUILD
Old Sat, Nov-11-2017, 06:54:26 PM   #3
mrgizmo04
mrgizmo04's Avatar
Great diy. Along with Pitt's comment, check out the little flap there on the side (you can see it between your hoses too). Almost like it was reserved for this .
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Nov-11-2017, 06:56:17 PM   #4
Sweet Jones
Sweet Jones's Avatar
Reputation: 0 Sweet Jones is on a distinguished road
Mexico
Awesome little setup.
E46 Touring
S54/6 speed, FluidMotorUnion velocity stacks, CSL cams, Swaintech coated headers, Mishimoto radiator, Alpha N tune, 4.10 diff, M3 suspension, Turner Motorsport subframe reinforcement, CSL brakes, 2.5" SS304 Rhom Innovations exhaust.
E46 touring, Version 2
S54/6 speed, polished FluidMotorUnion velocity stacks, CSL cams, Swaintech coated headers, Mishimoto radiator-Mishimoto radiator hoses-Mishimoto electric fan, Alpha N tune, 4.10 diff and RevShift bushings, RTD mini V2 shifter and DSSR, Airlift Performance 3H suspension, Rogue Engineering RaceBrace strut bar, Turner Motorsport subframe reinforcement, PLM SM-AFR wideband, Eonon GA7150A with front and rear cameras, Work Brombachers, Storm Motorwerks interior pieces, CSL brakes and 996 calipers, 2.5" SS304 Rhom Innovations exhaust, Bimmerworld Race diffuser. M3 bodywork and paint.
Jump to top Sweet Jones is offline   Reply With Quote
Old Sat, Nov-11-2017, 07:58:09 PM   #5
HassanEido
HassanEido's Avatar
Lebanon
Beware of crushing those tubes with the hood. Or you'll see a huge cloud of smoke behind you 5 mins later
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Sat, Nov-11-2017, 08:02:25 PM   #6
tjkenny15
tjkenny15's Avatar
Nice. Looks good.
I want to find a way to mount mine where I removed the secondary air pump.
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Sat, Nov-11-2017, 11:01:35 PM   #7
Sorry guys, forgot to make it more clear - I'm not done yet as I'm in the middle of the airbox install. That little flap for the ABS lines will be coming out.
Lol, the hoses are just laying there to show what it will look like basically. That's why the caption said
"Mocked up."
I'll have a finished pic later
-NA S54-
Old Sun, Nov-12-2017, 12:42:16 AM   #8
WyattH
The only situation where I envy the 01-04 owners ...
Nice find/post!
Old Sun, Nov-12-2017, 02:19:04 AM   #9
tjkenny15
tjkenny15's Avatar
Nice find/post!
What do you mean 01-04 owners?
Old Sun, Nov-12-2017, 02:25:40 AM   #10
The stupid crank case ventilation?
-NA S54-
Discussing My $50 Baffled Oil Catch Can in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
