Old Fri, Nov-10-2017, 08:38:55 PM   #31
Default Re: OEM cats vs Euro Cats vs CSL Cats vs ALL other cats
I wish I still had my US headers to take a direct measurement now. Maybe I am mistaken.
Also for whatever it's worth, this is a 620 vs 200 cell. 400 should be in between I suppose
Edit: This one is apparently 400 cell, which to my eye looks noticeable more dense than the US one in that other thread. But I admit the Euro one in that thread also looks even less dense
Old Sun, Nov-12-2017, 12:30:43 PM   #32
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Reputation: 0 bmw m3 s50 is on a distinguished road
Portugal
Yea I was going to say in those awe pics above the 200 cell cats do not looo lik the 200 cell cats in the other thread. The 400 cell cat pic def looks less dense then the 600 cell pic above
So are you thinking that the USA cats have a higher cell count then the euro ones?
Jump to top bmw m3 s50 is offline   Reply With Quote
Old Sun, Nov-12-2017, 12:36:06 PM   #33
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Portugal
Originally Posted by m3 hal View Post
I would not assume the change in placement is trivial without proof.
Losses scale up.
Terra says he has compared them IRL.
Well I would assume placing a restrictive cat near the collector in the header was the leading cause to the power reduction from the euro to USA m3
Regarding the scaling question my question is really do to the different size in the cats. If the USA cats have a higher cell count but have a shorter body then the euro cats with a lower cell count but a longer body. Will that really effect the restriction in exhaust flow since the exhaust is traveling through a shorter body but with a higher cell count?
Old Sun, Nov-12-2017, 03:10:38 PM   #34
m3 hal
Maybe. Assuming 200cpi vs. 400cpi, a square inch of 200cpi = 14.14 cells x 14.14 cells, and a square inch of 400cpi = 20 cells x 20 cells. The 200cpi (assuming square cells, which they are not in reality) cells have 0.0707" sides, while the 400cpi's cells have 0.05" sides. 0.0707" per side * 4 sides * 200 cells = 56.56 in^2 of surface area per square inch of cross-section that is in contact with the exhaust flow per unit length along the body. 0.05" per side * 4 sides * 400 cells = 80 in^2. Assuming the per unit length loss coefficient is the same for the two different cells, the 200 cpi would have lower losses than the 400 cpi as long as it's less than 80/56 = 1.43 times longer.
You'd also have to look at the losses associated with transitioning the freestream exhaust into and out of the cells. I think it's logical to assume that higher cell density = higher losses, but I'm not sure of any sensible way to compare without learning those loss coefficients through experiment. That's not all of the variables, but probably two of the biggest assuming same placement of the cat.
Jump to top m3 hal is online now   Reply With Quote
Old Sun, Nov-12-2017, 04:01:24 PM   #35
icecream
Registered Apples
icecream's Avatar
We are never going to know lol. Every one f these threads goes the same way. For piece of mind I'm just getting 200 cells and welding them into the section 1. Done.
Old Sun, Nov-12-2017, 08:51:56 PM   #36
usdmej
Originally Posted by mpower22 View Post
In fact, the only reason BMW put the cats near the engine in the first place was to meet CA emissions standards.
fwiw, euro cats always passed the sniffer tests when CA smog checks still required them for this platform
Jump to top usdmej is offline   Reply With Quote
Old Sun, Nov-12-2017, 09:38:08 PM   #37
m3 hal
That's different than cold start emissions requirements for manufacturers.
Old Sun, Nov-12-2017, 10:35:50 PM   #38
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
Is there a way of cleaning older cats?
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Sun, Nov-12-2017, 10:42:42 PM   #39
usdmej
yes even with a functioning SAP there's a noticeable smell during cold startup with euro cats that you don't get with usdm headers
Old Mon, Nov-13-2017, 02:07:21 AM   #40
Cha5en
Reputation: 0 Cha5en is on a distinguished road
Is there, really? I never smelled/noticed a difference.
Jump to top Cha5en is offline   Reply With Quote
Discussing OEM cats vs Euro Cats vs CSL Cats vs ALL other cats in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
