Old Mon, Nov-13-2017, 07:48:30 PM   #21
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
Default Re: Rod bearing pics - 2004 M3 motor w/93k miles
Originally Posted by T3AMFiSh View Post
one is coated, one is micro pitted.. the WPC is technically micro pitted to let oil stay in the bearing
so personal preference is what it comes down to? is one more suited for race or street applications?
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Mon, Nov-13-2017, 08:37:44 PM   #22
M3 dude
the wpc one maintains the clearances. the coated one may reduce it further. either way you need the measure the gaps with plastigage.
when i did mine, the gaps were all aroound the min tolerance.
to OP, my bearings looked very similar to your at 205k km (130k miles). if you use good oil, change regularly, let the engine warm up and exercise mechanical sympathy, the bearings could have lasted right up until 150k miles.
Old Tue, Nov-14-2017, 01:35:01 AM   #23
bigjae1976
Originally Posted by Dirty Elf View Post
any reason to not go with the VAC coated bearings vs the WPC OEM ones?
https://www.ecstuning.com/b-ecs-part...47835439wpckt/
vs
https://store.vacmotorsports.com/vac...s54-p1336.aspx
I had a motor rebuilt with VAC coated main and rod bearings. Last 12k miles with Ok maintenance, high oil temps, and lots of time near redline. Despite that, wouldn’t trust the VAC bearings. They reduce clearance and there are comparable or better alternatives available.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Nov-14-2017, 01:37:55 AM   #24
I also wouldn’t put VAC products in my engine
Old Tue, Nov-14-2017, 01:38:31 AM   #25
bigjae1976
The s65/e9X has rod bearing lottery failure (any mileage with any driving style), main bearing lottery failure (any mileage with any driving style) and rod bearing wear (more wear with more RPM usage, necessitating replacement as they wear out).
The S54 just has rod bearing wear (more wear with more RPM usage, necessitating replacement as they wear out)-- none of the lottery failures. Far less of an issue here, really just high revving engine maintenance.
I agree on the rod bearings, there isn’t a typical mileage range for failures. I replaced my bearings at 55k miles.
Main bearing failures have mostly involved superchargers and the first main bearing failing. Although most engines that have been pulled apart have main bearings that don’t look very good.
Old Tue, Nov-14-2017, 03:04:43 AM   #26
Dirty Elf
BSME
Dirty Elf's Avatar
Sounds like positive results, why don't you trust them? What are other alternatives?
why is that?
Is the idea that the coating is added to OEM bearings and the thickness of the coating reduces the clearance... which is bad? Or is there something else going on here? My indy swears by VAC...
First Road Trip
Old Tue, Nov-14-2017, 05:31:40 AM   #27
mrgizmo04
mrgizmo04's Avatar
why is that?
I believe VAC applies some spray-on coating to "reduce friction". Not sure of the film or how it wears/lasts, but does not sound like the best approach. This reduces clearance so you don't get the appropriate amount of oil (of recommended weight) on the journals.
WPC is a treatment process which smoothes out the surface while also strengthening it (think of using super fine sand paper to get it as smooth as possible, except instead of sand paper it is achieved via bombarding the surface of the material with tiny tiny pallets which also strengthens it by packing the atoms closer together).
Needless to say, I'm on WPC in mine.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Nov-14-2017, 11:07:43 AM   #28
why is that?
I've had and seen enough bad experiences with VAC (they're close to me, so I get to see a lot of their disasters first hand) that I would never put anything speced by them on my car again. They're pretty unbelievably incompetent.
Old Tue, Nov-14-2017, 01:12:18 PM   #29
Dirty Elf
BSME
Dirty Elf's Avatar
thanks for the info guys, ill talk it over with my indy and let you know what i end up going with
First Road Trip
Old Tue, Nov-14-2017, 01:13:20 PM   #30
maw1124
Reputation: 0 maw1124 is on a distinguished road
This makes perfect sense. Very helpful. Thanks,
maw
Jump to top maw1124 is offline   Reply With Quote
Discussing Rod bearing pics - 2004 M3 motor w/93k miles in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
