Old Mon, Nov-13-2017, 03:09:50 PM   #11
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Default Re: Rod bearing pics - 2004 M3 motor w/93k miles
Originally Posted by bigjae1976 View Post
Not sure if you can tell but there is no copper showing. The journals looked good and all measured to .002 with plastigage. I think it supports my theory that doing the rod bearings between 80k-100k is about right.
I'm guessing you mean street miles, what about HPDE championship winning engines? Brand new WPC treated bearings and every blackstone report shows lead
Old Mon, Nov-13-2017, 03:19:18 PM   #12
bigjae1976
Originally Posted by Dirty Elf View Post
replace with OEM, VAC? any other options?
I stuck with OEM WPC treated bearings and rod bolts.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Nov-13-2017, 03:22:29 PM   #13
maw1124
Reputation: 0 maw1124 is on a distinguished road
Are rod bearings a real issue on these, or only when tracked, or what? I knew there were an issue on the E9X cars, but I wasn't familiar with that issue here.
maw
Jump to top maw1124 is offline   Reply With Quote
Old Mon, Nov-13-2017, 03:29:08 PM   #14
bigjae1976
Yeah, street miles.
Track miles have more variables. My theory based mostly on hope and guessing is that your rod bearing replacement intervals should be more frequent once you disturb a factory motor. Think what you want...BMW was likely more precise when they put the motor together.
I think that max RPM plays a huge role. If you’ve got a tune and spin it up to 8200+ RPM every shift, I’d guess you’re looking at a 20k to 30k track mile interval on the OE bearings. The more often you shift at 7500ish RPMs gets you closer to the 80k to 100k interval.
My HPDE championship winning strategy is to build a matching spare motor and swap motors every so often. Then check the bearings when the motor is out.
Old Mon, Nov-13-2017, 03:30:26 PM   #15
Adrian S
Adrian S's Avatar
Reputation: 0 Adrian S is on a distinguished road
South Africa
maw
The short answer is yes. All the high-revving M engines have this issue sooner or later.
Although it is a matter of debate as to when they should be done, as rod bearing wear can vary quite a lot from individual engine to engine. Some engines go well over 120 000miles on original bearings. It all depends on how the engine has been treated throughout it's life.
What is almost certain, however, is the fact that when a rod bearing lets go it usually does a lot of damage - necessitating a replacement engine or at least a new crankshaft/bottom end rebuild.
Given this potential for collateral damage, it really makes sense to consider them a wear item and replace them before this happens. I agree with the suggested 80-100k mile range.
2003.5 BMW M3 Coupe 6MT
2004 BMW 330i M-sport 6MT
Jump to top Adrian S is offline   Reply With Quote
Old Mon, Nov-13-2017, 03:31:18 PM   #16
bigjae1976
maw
I think the E9X M3 had a worse issue with rod and main bearings (supercharged only for the mains) but the E46 S54B32 requires a change interval on the bearings above the normal M5X engine family.
Old Mon, Nov-13-2017, 06:41:35 PM   #17
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
any reason to not go with the VAC coated bearings vs the WPC OEM ones?
https://www.ecstuning.com/b-ecs-part...47835439wpckt/
vs
https://store.vacmotorsports.com/vac...s54-p1336.aspx
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Mon, Nov-13-2017, 06:46:09 PM   #18
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
i really want to see a 30k-50k mile rod bearings that were WPC to see if there is actual wear on them
Old Mon, Nov-13-2017, 06:47:18 PM   #19
T3AMFiSh
T3AMFiSh's Avatar
vs
one is coated, one is micro pitted.. the WPC is technically micro pitted to let oil stay in the bearing
Old Mon, Nov-13-2017, 07:27:40 PM   #20
maw
The s65/e9X has rod bearing lottery failure (any mileage with any driving style), main bearing lottery failure (any mileage with any driving style) and rod bearing wear (more wear with more RPM usage, necessitating replacement as they wear out).
The S54 just has rod bearing wear (more wear with more RPM usage, necessitating replacement as they wear out)-- none of the lottery failures. Far less of an issue here, really just high revving engine maintenance.
Discussing Rod bearing pics - 2004 M3 motor w/93k miles in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
