Old Tue, Nov-07-2017, 12:10:59 AM   #21
E30User
Reputation: 0 E30User is on a distinguished road
Default Re: SMG Long Gear Shifts
Have you done a search for Gear Position Sensor symptoms? The SMG FAQ thread says delayed shifts can be a symptom of a failing GPS.
However when my GPS failed, it was a bit more catastrophic than just having delayed shifts since I'd lose power and have to coast to a stop. Also, I had some codes that sounded specific to the GPS.
Here's my post from the SMG Faq thread:
2004 M3 here. My first symptoms showed up when I'd shift from 2-3. I'd see 3 show up on the display, but then power would cut out and I don't think it ever went into gear. I'd coast to a stop and turn the engine off. The gear number was still showing. After a minute or two, I'd see the gear number disappear. At that point, I'd restart my car. and things will be fine again until the next time it happens. The last issue I had was switching from Reverse, to N, then 1st. After going neutral, it would not shift into first. Eventually it got into first after some waiting and restarting. I'm pretty sure that I'd only see the problems show up after changing gears. For example, if I get into 1st, I can usually drive around on that if I don't shift to something else.
As for the pump, I always hear it priming when I unlock the car. As far as I can tell, it sounds the same as when things were working.
Sometimes when listening to the pump prime, I'd hear it end with a few thumping sounds. Here is what Autoenginuity game me:
37 - Shift Path (Gear) Position Sensor Evaluation
Status: Static Fault, Currently Not Present
Fault Frequency: 41
58 - Not able to take out of gear
Status: Currently Not Present
Fault Frequency: 48
37 - Selector Angle (WW) Position Sensor Evaluation
Fault Frequency: 54
The next post was another member confirming that their GPS failed the same way and had the same codes. So it's hard to say with certainty if your GPS is the problem since you didn't mention those codes, but maybe others had experiences more similar to yours.
Jump to top E30User is offline   Reply With Quote
Old Tue, Nov-07-2017, 03:12:14 AM   #22
04yfz
If it's not the pump the GPS was also going to be my next suggestion. OP if you need one I have a 50k mile one off an SMG to 6MT conversion I did.
Pat
Old Tue, Nov-07-2017, 11:23:32 AM   #23
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Sorry if i have to ask and not read the whole thing smg faq. Basically for the smg usually the parts are smg pump (motor), accumulator, gps and clutch cylinder?
Jump to top scoopy128 is offline   Reply With Quote
Old Wed, Nov-08-2017, 05:30:25 PM   #24
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
yes, there's also a electronic slave cylinder and the actuator arm, which rows the gears for you.
[2006 E46 M3 | Competition Package | Interlagos Blue | Black | AFE Intake | Enkei MT1 | SMG ---> 6MT]
[2011 E90 M3 | Competition Package | Jet Black | Extended Fox Red | AFE Intake| AFE Exhaust | DCT GTS]
Jump to top MrVond is online now   Reply With Quote
Old Sat, Nov-11-2017, 10:55:22 PM   #25
MrVond
The Phanto///M
UPDATE:
for some reason the adaptation went through and passed.
the only different variables this time is that I did the adaptation on a slight incline with the parking brake pulled, the other times I did the adaptation is with a level surface and parking lever not engaged.
I drove the car for a good hour it seemed to drive like it used to, then i encountered a good incline while shifting through the 2-3 it stuttered, again, i pulled over and re-adapted failed (flat surface, handbrake not engaged).
It failed at least 10 times after this in the same conditions, citing switch path too narrow and that the odd gears shift gates are too narrow.
I tried calibrating again with the incline w handbrake engaged, it passed, but still w some stutter from 2>3 at high load. otherwise it drives fine
Old Sun, Nov-12-2017, 08:39:53 PM   #26
ZCPIBM3
Reputation: 0 ZCPIBM3 is on a distinguished road
It's either GPS or compression spring. Look that up.
2006 M3 ZCP Interlagos Blue
Jump to top ZCPIBM3 is online now   Reply With Quote
Old Sun, Nov-12-2017, 10:16:18 PM   #27
MrVond
The Phanto///M
I changed my Compression spring, its on the first post, yes, most likely the GPS is out
Old Tue, Nov-14-2017, 06:21:24 AM   #28
B_Engineering
B_Engineering's Avatar
Reputation: 0 B_Engineering is on a distinguished road
Germany
Hi,
how many miles does your car have?
If it's not the GPS, could be the synchros as well.
Kind regards from Germany
Thomas
Jump to top B_Engineering is offline   Reply With Quote
Old Tue, Nov-14-2017, 09:24:16 PM   #29
MrVond
The Phanto///M
Originally Posted by B_Engineering View Post
Hi,
Thomas
134k miles. from the troubleshooting thread, it would appear that the GPS is bad, but it only stutters under sudden load for 2-5 seconds.
Old Wed, Dec-06-2017, 08:04:51 PM   #30
ebmw21
Reputation: 0 ebmw21 is on a distinguished road
Any update on this MrVond?
I went through all of the SMG parameters in IMPA, mine passed everything.
Since I've done this I've noticed on the first drive every morning it shifts "as an SMG should" but the second and third drive it goes back to whats described in this thread.
I don't think it is the clutch, as it does not slip when it is in gear.
BBS LM | ST suspention | B-Line Intake | AP V1 | Rouge Sec2 | CPI Rasp Terminator | Headers | CSL SMG Coding |
CSL Bumper | Beisan Vanos Rebuild |
Insta: @jstrattn
Vancouver BC area ECUWORX coding avalable.
Jump to top ebmw21 is offline   Reply With Quote
Discussing SMG Long Gear Shifts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
