Old Fri, Nov-03-2017, 03:38:28 PM   #11
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
Default Re: SMG Long Gear Shifts
Update: i flashed it w the TTFS tune. it helped a lot, it now know where the gears are. However, when im shifting over 3K RPM, 2>3 and 3>4. it hesitates.
///M
Jump to top MrVond is offline   Reply With Quote
Old Fri, Nov-03-2017, 07:06:57 PM   #12
MrVond
The Phanto///M
just flashed it w my ttfs tune. it seems to have problem shifting 2>3 3>4 under power (3k+ RPM)
///M
Old Sat, Nov-04-2017, 01:41:49 AM   #13
MrVond
The Phanto///M
die schaltwegendstellugen der ungeraden gaengr sind zu untershiedlich
the shift end positions of the odd gears are too different
///M
Old Mon, Nov-06-2017, 12:03:35 AM   #14
MrVond
The Phanto///M
anyone, any clue?
///M
Old Mon, Nov-06-2017, 03:46:03 AM   #15
ebmw21
Reputation: 0 ebmw21 is on a distinguished road
I'm interested in this as well, my cars been having this issue for the past few months. Really makes it less enjoyable to drive.
I've done a full work up on inpa, including realigning everything. Still continues
Jump to top ebmw21 is offline   Reply With Quote
Old Mon, Nov-06-2017, 03:59:44 AM   #16
04yfz
Have you checked the pressure the pump is producing? Check it with INPA it should be around 85 bar.
Pat - Proud E46 Addict
2002 M3 Tiag/Imola Coupe-6MT (SOLD)
2005 325xi Tiag/Tanin - 5MT (SOLD)
2006 M3 Silvergrey/Black Coupe (SOLD)
2006 M3 Tiag/Black Coupe - 6MT (SOLD)
2003 330i ZHP 6MT ---> S54/M3 Conversion (build coming soon)
Old Mon, Nov-06-2017, 04:15:50 AM   #17
ebmw21
Yes i have (my pump was also replaced 3 years ago with a new unit)
Old Mon, Nov-06-2017, 02:42:32 PM   #18
Zroman610
Zroman610's Avatar
Reputation: 0 Zroman610 is on a distinguished road
I noticed this with an SMG car I drove before buying my 6MT. I don't know much about SMG but I could tell immediately the lag was way longer than it should've been. Seemed like the SMG pump failing, which you've replaced. I've heard the TTFS flash helps big time but seems you've already done that. Wish I had more input, best of luck mate.
Jump to top Zroman610 is offline   Reply With Quote
Old Mon, Nov-06-2017, 04:01:06 PM   #19
04yfz
You put a brand new/rebuilt pump in it? If so that is unlikely to be the issue. What was the pressure value? And did it hold?
Are you getting any codes? The fact the adaptations aren't working means something is not working properly.
You mentioned code 53 which from a quick search means "Hydraulic Pressure Loss in System" - a pump issue.
Old Mon, Nov-06-2017, 08:26:36 PM   #20
MrVond
The Phanto///M
its right about 85 when i did the adaptation procedure on INPA.
Again, i'm pretty certain its not a problem with hydraulic pressure, but a problem w SMG system finding the gears. When Inpa fails a test, it gives me error 83, which is an adaptation problem.
///M
Discussing SMG Long Gear Shifts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
