Old Mon, Oct-30-2017, 04:07:32 AM   #1
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
Default SMG Long Gear Shifts
SMG Long Gear Shifts?
My SMG transmission is still suffering from long gear shifts and giving me the cog gear. it cant seems to find the gears fast enough. it sometimes have a problem finding third gear. and downshifts seem to be also a problem.
dropped the transmission and
i've replaced:
Compression spring (23317511337), my old one is cracked and i replaced it.
Compression spring 23311228405
locking pin(the roller thing) 23317501584
i have a suspicion that the locking pin is not sitting properly....
ill try to re-calibrate using INPA
any other suggestions?
[2006 E46 M3 | Competition Package | Interlagos Blue | Black | AFE Intake | Enkei MT1 | SMG ---> 6MT]
[2011 E90 M3 | Competition Package | Jet Black | Extended Fox Red | AFE Intake| AFE Exhaust | DCT GTS]
Jump to top MrVond is online now   Reply With Quote
Old Thu, Nov-02-2017, 03:54:02 PM   #2
MrVond
The Phanto///M
Default Re: SMG Long Gear Shifts
update:
Used INPA to Adapt SMG using the special processes option
Adaptation failed, error 53
car is drivable, but still cant find gears that well enough.
car doesn't seem to know where clutch bite points are.
Ill try to:
Try to adapt again via Inpa
adapt via DIS
soft adapt (neutral at 30-40 mph, put to 'N', pull in '+' & "-" paddles)
reflash w the TTFS tune i bought
Old Thu, Nov-02-2017, 04:11:11 PM   #3
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
Not knowing too much about the problems of SMG (even though I have one), my first thought would have been a broken spring, but you've already corrected for that, so I'm at a loss.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Thu, Nov-02-2017, 09:28:34 PM   #4
E30User
Reputation: 0 E30User is on a distinguished road
Since you have INPA, can you get the codes that are causing the cog light?(nevermind, just saw your update with error 53 mentioned)
Also, I don't know if you can do it in INPA, but DIS will let you run an accumulator pressure test, which could help narrow things down a bit. I'm still learning things as I troubleshoot my own smg issues, but I believe slow shifting is usually caused by the system taking a long time to reach the correct pressure to shift.
When you unlock your car, how long do you hear the pump priming? Have you checked your fluid level?
Jump to top E30User is offline   Reply With Quote
Old Thu, Nov-02-2017, 09:33:37 PM   #5
LemonOne
LemonOne's Avatar
Reputation: 0 LemonOne is on a distinguished road
I'm curious to know, what can you tell from the pump priming sound?
Jump to top LemonOne is online now   Reply With Quote
Old Thu, Nov-02-2017, 11:27:30 PM   #6
E30User
No sound at all when one is expected could be a symptom of pump failure. This is assuming everything is getting power correctly, and not a salmon relay issue. While I haven't experienced this myself, a longer than usual, or abnormal sound seems to lead to a problem at the pump. It could mean the pump motor is running poorly, or something else is causing difficulty or delay when building up pressure. Someone please correct me if I'm wrong.
I hesitate to throw around "pump failure" as the cause for now. I think there's still some other things to check before narrowing it down to that.
Old Fri, Nov-03-2017, 12:34:27 AM   #7
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
When u say longer shifting like how many seconds? I noticed mine when i shift to 2nd it is like one second or it will blink 2 times the rest just blink one
Jump to top scoopy128 is offline   Reply With Quote
Old Fri, Nov-03-2017, 02:27:38 AM   #8
MrVond
The Phanto///M
pump is priming just fine. fluid levels are good.
Old Fri, Nov-03-2017, 02:28:04 AM   #9
MrVond
The Phanto///M
could take up to 10 seconds before it finds the gear, with the gear blinking a lot.
Old Fri, Nov-03-2017, 02:32:14 AM   #10
scoopy128
Ah ok that happens to me sometimes after two hours of drive and traffic sometimes going to 1st or quick change 3-4 it will blink. Was told it might be the accumulator doesnt build pressure.
Discussing SMG Long Gear Shifts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
