Old Tue, Oct-31-2017, 12:00:30 PM   #11
Default Re: PS Pulley looks a wee tight to you?
Id change to an allen head bolt if the head is a little smaller, assuming the pulley is the correct underdrive. I recall the fit being close but have not looked at my PS pulley in years and it's a UUC. I run a stick size aluminum water pump pulley since a Stewart pump should not cavitate at whatever speed it is driven to at my 7200 limiter.
Old Tue, Oct-31-2017, 02:03:44 PM   #12
bluptgm3
Originally Posted by pbonsalb View Post
I run a stock size aluminum water pump pulley since a Stewart pump should not cavitate at whatever speed it is driven to at my 7200 limiter.
The Stewart literature recommends not under driving their pumps, in general. Not sure if that applies to the BMW specific pump.
Old Tue, Oct-31-2017, 02:41:14 PM   #13
MaynardZed
MaynardZed's Avatar
Reputation: 0 MaynardZed is on a distinguished road
Been racing with a Stewart pump and underdrive pulley (Turner I think as well) for over 4 years, over 50 track days. FWIW
1999 BMW E36 M3
Ground Control Race Suspension
Full Cage - Flatout Motorworks
OMP Full Containment Race Seat
S52 with bolt ons 237 rwhp (DynoJet)
2550lbs empty
Jump to top MaynardZed is offline   Reply With Quote
Old Tue, Oct-31-2017, 03:04:42 PM   #14
As long as it is cooling properly, no worries. For a naturally aspirated track car with no AC, I would not worry about underdriving the Stewart pump. Even underdriven, it probably moves as much coolant as a stock pump, without risk of cavitation at higher redlines.
I chose the aftermarket stock size metal pulley since I have a turbo and AC and a full weight car and all that power can put a lot of thermal load on the motor although I don't track the car.
Old Tue, Nov-07-2017, 01:51:12 PM   #15
bluptgm3
So what is the resolution to this issue?
Old Tue, Nov-07-2017, 02:37:09 PM   #16
abcurran
abcurran's Avatar
I would personally cut away the pulley before touching the OE side.
Agree. Assuming the pulley is correct, best to get the pulley on a lathe and turn down that last rib, provided doing so won't interfere with the bolt.
Alternatively, you could try grinding down the top of the bolt head instead of fiddling with the washer to ensure even clamping pressure.
Old Tue, Nov-07-2017, 02:45:34 PM   #17
JitteryJoe
I ordered a new pulley. It will arrive this week.
If the pulley is correct then I'll attempt to return the original one they shipped me some time ago. If it still doesn't fit then I'll try to return everything (water pump pulley, alternator pulley, PS pulley) and go OEM size.
Turner was responsive at first but has gone dark. Very annoying.
I'll post the outcome.
Old Mon, Nov-13-2017, 08:07:30 PM   #18
nholmes
Track Junky
nholmes's Avatar
My car had this kit already installed and I took some pics of the pulleys a while back to see what it was:
Follow my build thread here:
Old Mon, Nov-13-2017, 08:32:57 PM   #19
JitteryJoe
Thanks. I'm pretty sure they sent me the wrong pulley. New one hasn't arrived yet (any day). I thought I fast shipped only to discover it is coming ground.
Old Sat, Nov-18-2017, 06:06:27 PM   #20
JitteryJoe
The new pulley arrived and it fits. Pretty tight clearance but enough. Thanks!
Discussing PS Pulley looks a wee tight to you? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
