Old Sun, Oct-29-2017, 10:30:47 PM   #1
JitteryJoe
Default PS Pulley looks a wee tight to you?
I'm in the middle of installing the Turner power pulley set. The power steering pulley wedges against one of the pump mount bolt heads. So either I'm doing some a bit stupid or the pulley has too much diameter. Thw water pump pulley fits fine. Thoughts?
Thanks,
Joe
Old Sun, Oct-29-2017, 10:36:30 PM   #2
Default Re: PS Pulley looks a wee tight to you?
Move the bolt head washer. You will likely need to dremel it off.
Old Sun, Oct-29-2017, 10:54:06 PM   #3
bluptgm3
Turner p/n T#340390?
T#340391 is for 323/328.
Check your part numbers and fitments.
Old Sun, Oct-29-2017, 11:01:50 PM   #4
JitteryJoe
Yes, I could cut away the problem but it is unfortunate the fit isn't right. The mount bolts are new and to spec (that is a wave washer). I'm pretty sure the bolt head would have to be cut with or without the washer. I could just go back to stock as well. Annoying.
Maybe I can find a torx or fillister head bolt with a smaller head diameter. I don't need much. Thanks.
Old Sun, Oct-29-2017, 11:08:10 PM   #5
JitteryJoe
TEN3610004 which is supposed to fit 325, m3, MZ3 according to Turner website
I emailed Turner. I'll see what they have to say. Thanks.
Old Sun, Oct-29-2017, 11:39:45 PM   #6
I would personally cut away the pulley before touching the OE side.
Old Mon, Oct-30-2017, 08:34:36 PM   #7
bluptgm3
Can you confirm that p/n on the pulley you have in hand?
Old Mon, Oct-30-2017, 09:43:41 PM   #8
JitteryJoe
The numbers on the pulley are:
017800TMS01A
158918
Thanks,
Joe
Old Tue, Oct-31-2017, 01:57:35 AM   #9
bluptgm3
Is this your pulley? TEM3610004
See third image....your pulley image does not have the TEM3610004 marking as depicted on Turner website....mis-packaged?
https://www.turnermotorsport.com/p-3...tm_content=BA1
Old Tue, Oct-31-2017, 02:37:15 AM   #10
JitteryJoe
You could be right. Or mine is an older part number (I bought it about 9 months ago). Turner got back to me and is looking into it. I'll post back what I find out. Thanks!
Discussing PS Pulley looks a wee tight to you? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
