Old Sun, Nov-05-2017, 05:26:42 PM   #31
nholmes
Track Junky
nholmes's Avatar
Default Re: E36 M3 coil overs
I’ve got my old Koni Yellows and Eibach springs for sale for anyone interested lol
Follow my build thread here:
Old Sun, Nov-05-2017, 06:03:55 PM   #32
Hasan Shaikh
Reputation: 0 Hasan Shaikh is on a distinguished road
United Arab Emirates
Originally Posted by bluptgm3 View Post
H&R OE Sports on Koni Sports
(requires OE casings for cut-n-gut) H&R OE Sports (requires 1995M”hat”) on Bilstein.
Eibach on Koni Sports (requires OE casings for cut-n-gut).
Dinan (if you can find them) on Koni (requires OE casings for cut-n-gut).
I recommend E46M3/Convertible Rear Shock Mounts and Z3 RSM Reinforcement Plates.
Add 1996+M3 Strut Tower Reinforcement Plates if you don’t have them.
All that cut n gut sounds quite complicated. Are there any easier solutions?
Thanks
Jump to top Hasan Shaikh is offline   Reply With Quote
Old Sun, Nov-05-2017, 06:19:21 PM   #33
westopher
westopher's Avatar
Use bilstein shocks. They don't use inserts and replace the whole assembly. That said, the Konis are far better shocks.
Other option is get coils.
98 m3, techno/anthrazit cloth, 103k and officially worthless.
Old Sun, Nov-05-2017, 08:45:52 PM   #34
bluptgm3
Default E36 M3 coil overs
Originally Posted by Hasan Shaikh View Post
All that cut-n-gut sounds quite complicated.
Are there any easier solutions? - Thanks
Using a drill motor and a Lisle Cut-Off Tool #31500, the whole process is under four hours.
Rear shocks are ~ 2 hours, less if you build up the assembly before hand.
Old Mon, Nov-06-2017, 11:54:53 AM   #35
Hasan Shaikh
Is there a guide for the cutting etc. Thanks
Old Mon, Nov-06-2017, 02:44:20 PM   #36
tsmith25
Reputation: 0 tsmith25 is on a distinguished road
It is pretty easy if you have a drill and either a grinder with a cutoff wheel or a sawzall. I'm pretty sure cutting the strut and installing the insert only took me about 30 minutes for both struts. That is not counting removal and installation on the car.
OP, what spring rates did you decide on?
Jump to top tsmith25 is offline   Reply With Quote
Old Tue, Nov-07-2017, 12:46:14 AM   #37
DasBlitzAuto
Reputation: 0 DasBlitzAuto is on a distinguished road
Another vote for TCK DA. Surprisingly good street ride and they've done an awesome job on the track. Went with the track settings for compression and rebound on the setup sheet and haven't had to touch it. Car is very well balanced.
1997 Estorilblau E36 M3
TCKR Suspension - Turner Sways - Active Autowerke Intake/Exhaust - 17x9 ARC8 - Hankook RS4 245/40/17 Square - UUC EVO Short Shifter
Jump to top DasBlitzAuto is offline   Reply With Quote
Discussing E36 M3 coil overs in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
