Old Tue, Oct-31-2017, 07:02:01 PM   #21
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Default Re: Possible New Clutch
I bought the new RMS kit and trans seal so I have them on hand. i will make the call when we get it opened up. I'll also be asking the Indy shop what his warranty on it would be.
This is on hold with my E60 having a mechatronics issue.
Jump to top Engrmikl is offline   Reply With Quote
Old Tue, Oct-31-2017, 07:46:12 PM   #22
rpearl555
So Shiny So Chrome
Reputation: 0 rpearl555 is on a distinguished road
Just went with a luk clutch kit for $235 shipped. I really wanted a comparison between luk and Sachs but couldnít find one. In fact I saw a couple instances where members said their clutch was luk that came with the car.
Old Sat, Nov-11-2017, 11:58:47 AM   #23
Engrmikl
WOW I like the new clutch. Mine was toast.
Went with the Sachs clutch and Luk flywheel and all the usual stuff. Didn't do the RMS but made a deal with my Indy that if it start leaking within 15k miles he will do the labor for half. Fair enough.
Not sure if I still had the factory gear in there but it was marked both Sachs and LUK
Any recommendations on proper break in?
Old Sat, Nov-11-2017, 02:08:36 PM   #24
I would do the rear main for sure. There’s no voodoo magic on the original and it’s not a hard replacement if you’re half way competent/careful.
Old Sat, Nov-11-2017, 03:26:08 PM   #25
mrgizmo04
mrgizmo04's Avatar
I would do the rear main for sure. Thereís no voodoo magic on the original and itís not a hard replacement if youíre half way competent/careful.
Yeah, just use the dang white plastic cone it comes with. I "forced" one in without it and however slightly bent/creased the edge to where it started a leak AFTER I put the tranny back on. Had to redo. Not fun.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Nov-14-2017, 01:11:36 AM   #26
e30will
Reputation: 0 e30will has disabled reputation
Originally Posted by Zzyzx85 View Post
I've read that a DM flywheel can be changed every other clutch (depending on condition, of course).
I dropped off my car at my shop to do rear subframe mount reinforcement as well as new clutch and flywheel.
Stuff I am having replaced:
  • rear main seal
  • rear main seal housing gasket
  • clutch and flywheel
  • sachs/OE BMW throw out bearing
  • pilot bearing
  • clutch line
  • steel pivot ball
  • fork
  • trans input seal
  • trans output seal
  • SSK (optional)
  • clutch slave
  • clutch master (optional, changing it out since it's not expensive and just want a fresh system since car has almost 200k miles on it)
I also replaced the throw out bearing guide tube ("guide bushing," 23-11-7-512-866).
Jump to top e30will is offline   Reply With Quote
Old Tue, Nov-14-2017, 01:21:50 AM   #27
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
Search around, there are differing opinions. 400 or so miles of city(stop and go)driving was the common answer iirc.
Jump to top ///ALpineVert is offline   Reply With Quote
Old Tue, Nov-14-2017, 05:16:45 AM   #28
mrgizmo04
mrgizmo04's Avatar
Normally 200-500 miles, depending on split between city and highway for break-in.
'05 M3 6MT coupe
Old Tue, Nov-14-2017, 04:17:23 PM   #29
BearDeXPS
BearDeXPS's Avatar
Proper break in?
Literally just drop it
Discussing Possible New Clutch in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
