Old Sat, Oct-21-2017, 07:41:41 PM   #1
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Default Possible New Clutch
Hi All
My 100k mile clutch seems to be slipping when getting into the throttle when cruising.So I guess it's time for a new one.
Is the OEM still the option most guys are going with these days? No engine mods to the car.
If so am I missing anything
Clutch plate, disc, throw out, pilot bearing, new flywheel bolts and slave cylinder.
Turn the flywheel or new?
Thanks
Jump to top Engrmikl is offline   Reply With Quote
Old Sat, Oct-21-2017, 08:46:54 PM   #2
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Default Re: Possible New Clutch
Upgrade the pivot pin.
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Old Sat, Oct-21-2017, 09:26:46 PM   #3
Engrmikl
Bronze or Stainless?
Old Sat, Oct-21-2017, 09:46:17 PM   #4
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
Not sure if turning a dual mass flywheel is ok....? Maybe someone else can chime in.
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is offline   Reply With Quote
Old Sat, Oct-21-2017, 10:44:31 PM   #5
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
I had mine done in May, I researched a lot and made this thread, hope it helps. I replaced a lot of stuff that was easy and didn't add much labor.
LuK is the OE, get a BMW TOB. Also get the E39 metal pivot pin.
http://www.m3forum.net/m3forum/showt...ghlight=Clutch
Jump to top ///ALpineVert is offline   Reply With Quote
Old Sat, Oct-21-2017, 11:31:54 PM   #6
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
I've read that a DM flywheel can be changed every other clutch (depending on condition, of course).
I dropped off my car at my shop to do rear subframe mount reinforcement as well as new clutch and flywheel.
Stuff I am having replaced:
  • rear main seal
  • rear main seal housing gasket
  • clutch and flywheel
  • sachs/OE BMW throw out bearing
  • pilot bearing
  • clutch line
  • steel pivot ball
  • fork
  • trans input seal
  • trans output seal
  • SSK (optional)
  • clutch slave
  • clutch master (optional, changing it out since it's not expensive and just want a fresh system since car has almost 200k miles on it)
Jump to top Zzyzx85 is offline   Reply With Quote
Old Sun, Oct-22-2017, 01:35:15 AM   #7
Engrmikl
  • rear main seal
  • pilot bearing
  • clutch line
  • steel pivot ball
  • fork
  • trans input seal
  • trans output seal
  • SSK (optional)
  • clutch slave
Ok I will throw it out there. What's the opinion on the rear main seal. A lot of people say that if it's not leaking leave it alone.
Can I ask is the same with the trans seals
Old Sun, Oct-22-2017, 01:41:44 AM   #8
///ALpineVert
If you are paying someone, why not do the rear main? It's right there and doesn't add much labor. I had mine done with my clutch.
Old Sun, Oct-22-2017, 02:25:56 AM   #9
Zzyzx85
Zzyzx85's Avatar
Exactly. If you're in there and it's right there, you might as well do it. If the rear main seal or trans seals leaks, you need to drop the trans again.
Old Sun, Oct-22-2017, 04:23:08 AM   #10
mrgizmo04
mrgizmo04's Avatar
Do all the seals. You don't want to have to drop the tranny again if they start leaking in another 20k miles. I also went ahead and changed a lot of bushings on tranny/shifter and did the tranny locking pins. Since you are up there and have access, might also do cpv valve/seal and depending on how old your o2 sensors are, easy access to those.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, Magnaflow catback, new SAC/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Discussing Possible New Clutch in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
