Old Mon, Oct-16-2017, 04:20:03 PM   #1
Monterey///M3
Reputation: 0 Monterey///M3 is on a distinguished road
Default Crank no start, OBD Port doesn't work as well
Hey guys, I have an issue with my 97 sedan that has me at a complete loss.
The car cranks but doesn't start, then it backfires into the intake tube. I can't pull codes from the obd port or the port inside the engine bay either.
What I've done so far was change the crank position sensor which I thought was the culprit based on threads I've seen online but that obviously wasn't it.
Any ideas?
Thanks
Vehicles:
2004 Ti/Dove M3
1997 Boston/Modena M3 Sedan
Jump to top Monterey///M3 is offline   Reply With Quote
Old Mon, Oct-16-2017, 08:05:54 PM   #2
Double E
Double E
Reputation: 0 Double E is on a distinguished road
Default Re: Crank no start, OBD Port doesn't work as well
Backfiring into the intake typically means timing is off. Like way off. No guarantee on that diagnosis but with an interference engine as the case...consider a couple of things:
When did it last run correctly?
What changed in that time period?
Who else drove it? (Anyone have access to your keys?)
Pull plugs and do a comp check to make sure the fundamentals of the engine are in-tact.
For codes, I've had difficulty pulling them from either port too. I had success with taking of the round cap, leaving it off then reading from the inside OBD port. It took 3 times for the scanner to connect though.
'97 M3/2/5. Hellrot on Black ...and a racecar.
Jump to top Double E is offline   Reply With Quote
Old Mon, Oct-16-2017, 08:47:10 PM   #3
This is the need to know right now before things get opinionated on unknown possibilities. I'd also like to add;
Why do you suspect the crank position sensor and not simple things like Fuel and Spark?
Old Mon, Oct-16-2017, 10:35:24 PM   #4
Monterey///M3
The last time it ran was around 2 months ago. Ran perfectly, I went on a 230 drive and then parked it. The engine is fine, was rebuilt less than 6 months ago.
When I was doing some browsing on the forums, i thought that was the issue. The car is getting fuel and spark. And since I don't have obd for some reason, that was the only logical way to go.
Vehicles:
2004 Ti/Dove M3
Old Mon, Oct-16-2017, 11:05:04 PM   #5
How was fuel and spark checked?
Since the motor was rebuilt, can you check the fuel injector electrical rail to make sure it is securely clipped into place (each injector)?
Pull the intake airbox and try to start it MAF only.
Pull the fuel pump fuse and see if it eventually starts (it will die) and then reinstall fuse.
Old Tue, Oct-17-2017, 03:57:41 AM   #6
thirtysixnick
I want to take a part in this fun too!!!
I have the same issue every morning/if car sits for more than maybe 4/5 hours.
Had my cylinder head rebuilt, had a timing problem that was throwing a CEL for vanos, sent it back to get fixed, got "fixed", and since then the car has had this issue.
I barely have to crank it with no start, then crank again and starts right up. I have no CEL, but should I check anyways???
Don't think my problem is related to spark so I'm guessing fuel or, even more of a surprise, timing
Old Tue, Oct-17-2017, 06:28:49 PM   #7
Monterey///M3
Everything looks to be connected. Fuel was checked via the bleed valve in front of the fuel rail. Spark was checked via the old school spark tester I have.
Tried starting it without the intake box, same issue.
Pulled the fuel pump fuse, just cranks now without any backfire.
Vehicles:
2004 Ti/Dove M3
Old Tue, Oct-17-2017, 07:30:54 PM   #8
Double E
Double E
Comp check time.
I suppose you could set #1 at TDC (Use a dowel in the spark plug hole to get it set to TDC, right?) ...and pull off the front cover to expose the cog & see where the timing marks are as a result.
The comp check is a faster/easier way to determine if you're capable of creating internal combustion. Something tells me timing is off. Hope I'm wrong.
Old Wed, Oct-18-2017, 05:13:14 PM   #9
ECU is connected properly and both sides of the connection are free of any corrosion? The connector on the E36 needs to be forcefully compressed down after the latch is seated.
Old Tue, Oct-24-2017, 01:10:16 AM   #10
Monterey///M3
Ecu is connected properly, has 36psi fuel pressure, has spark, timing is good. I'm at a total loss here guys
Vehicles:
2004 Ti/Dove M3
Discussing Crank no start, OBD Port doesn't work as well in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
