Old Fri, Jun-16-2017, 11:26:03 PM   #21
Default Re: My "custom" (stock?) M3 wagon exhaust
Originally Posted by T3AMFiSh View Post
Any power loss when you added the e36 rear? Reason I'm asking is because you went from 2.36 to 2.00 piping, plus have you ever seen the inside of the e36 M3 muffler? 4, 180* turns and the piping just before the tips actually necks down to 1.5"
I know this because I just open my muffler and took out the entire guts, and remade the muffler using 2.5" piping and peforated core pipe with stainless packing. The sound is very good and gave a nice "butt dyno" feel up top.
This is my thread here
https://www.bimmerforums.com/forum/s...ttle-different
Honestly, it's hard to tell-- the M3 wagon always feels a bit slow to me, because my M3 coupe is 3150 lbs (and lighter rotating mass) and up almost 100 hp on it. I don't perceive any power loss, but the two very different e46 M3s has decalibrated my butt dyno. If there is, I'm fine with it-- I just don't like loud exhausts, at least on the s54.
That said, Bimmerworks did say that my e36 muffler was different than any other they had seen-- specifically because it had larger pipe. They actually initially grabbed a second one to use, to make a pipe extension, but had to abandon it for some V8 X5 piping because the tubing was too small. They asked me where I got the muffler from because it was unlike previous e36 M3 mufflers they had seen
(I just got it from a local guy that parts out e36 m3s-- it came off a 99 vert).
Old Sat, Jun-17-2017, 01:41:32 AM   #22
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Is that an RMP car behind you?
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Jump to top Sandeep1212 is online now   Reply With Quote
Old Sat, Jun-17-2017, 05:10:16 AM   #23
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
the euro E36 M3 muffler is identical to the US version with the exception that its made in 60mm piping (2.36") so it could be that..
when i opened up my muffler.. the packing was almost dissentigrated into one of the pipes causing a semi-blockage of one of the tubes.. i was really surprised on the size of piping and the actual path of flow on the muffler.. woke up my E36 pretty well after i made the changes to it. there are others in that thread that kinda did what i did but if you do the perforated core tube (acutally motorcycle muffler piping) and use the stainless wool packing (also motorcycle packing).. it sounds really good. and saves about 18lbs of weight.
Old Sat, Jun-17-2017, 08:24:06 AM   #24
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Hrmmm I think I might have to try this
E46 ///M325i Touring journal
Kaiv's SoCal Feedback!
IG: limited.slip
Old Sat, Jun-17-2017, 09:39:57 AM   #25
T3AMFiSh
T3AMFiSh's Avatar
for those that dont want to click the link
right here where you can see the 2 "S" bend pipes, those go out to the tips.. those pipes are 1.5" OD..
the only thing you dont see, is the steel wool, i used 15ft of it, wrapped both tubes, loosely not too tight and just stuffed the rest into the cavity...
Old Sat, Jun-17-2017, 03:09:03 PM   #26
youinreverse
Reputation: 0 youinreverse is on a distinguished road
Those images aren't viewable unless you're signed into bimmerforums.
Jump to top youinreverse is offline   Reply With Quote
Old Sat, Jun-17-2017, 03:26:44 PM   #27
I have zero desire to add any amount of loudness, so I don't think I'll be going this route.
Any idea what the OD of the euro or US piping is going into the muffler? I'd like to stick a caliper on it to determine which I have...
(not that I'm likely to change it either way, I just want to know)
Old Sat, Jun-17-2017, 06:27:27 PM   #28
Just confirmed with Chris (did the work)-- the piping on this e36 muffler was 60mm (2.36"). Not 2"
Old Sat, Jun-17-2017, 07:22:27 PM   #29
twentyseven
@itsmejonnyv
twentyseven's Avatar
Such an awesome idea, executed perfectly!
Originally Posted by bmw m3 s50 View Post
I was under the impression that the US spec exhaust piping diameter was 2.25" while the euro exhaust piping diameter was the same as the e46 at 2.36".
Originally Posted by ZiMMie View Post
Euro mufflers are different internally compared to US spec. I've had 3 and 2euro mufflers. All used.
The us mufflers kept coming loose internally (rattling) after a few km. Euro will last longer. Ended up buying a new euro 3.2 muffler which is different from the 3.0 internally.
US 3.0 mufflers were different (internals and pipe sizing) than 3.2.
Euro piping is always larger and has a unique center section, but the mufflers were the same -respectively- except for the necking down of the flange to mate to smaller US mid pipes (aka 325/328 parts).
Supersprint does the same exact thing with their mufflers. Only difference between US spec and Euro is the flange size. Otherwise they are all Euro sized ~4" after the inlet.
'04 Jet Black + Cinnamon ///M3 coupe
V-CSL, BBS CH, Öhlins R&T, Supersprint, custom Z4M seats, CSL SMG tune
Jump to top twentyseven is offline   Reply With Quote
Old Tue, Jun-20-2017, 09:00:21 PM   #30
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
I have Dynos to prove to it. I gain a shit load from an ss mid and new muffler than the us muffler with e46 Center. I'll post it when I get a chance.
Sent from my Robin using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Discussing My "custom" (stock?) M3 wagon exhaust in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
