Old Fri, Jun-16-2017, 07:03:43 PM   #11
Default Re: My "custom" (stock?) M3 wagon exhaust
Originally Posted by aznbo187 View Post
Sound clips whenever you get a chance.
Does the car have LSD? If so, might as well hit two birds at the same time.
Car has every M3 mechanical and electronic component converted-- so yes, it has the LSD
Originally Posted by bmw m3 s50 View Post
So it worked huh? Like I had said before in the other thread, I have an overwhelming feeling that you won't have any issues since the e36 and e46 had very similar exhaust routes. I knew any good exhaust shop would be able to do it, bimmerworks being one of them. Who did the work, Steve or Chris?
You have to some day get that Supersprint muffler we had discussed. Should be able to free up some additional HP, while being on the quiet side also lighter then the heavy OEM muffler.
You were smart to retain that same e46 M3 X - resonator. Every little bit helps.
Chris did the work. That guy is a freaking genius, if you ever get him talking!
I called SS in Italy. They said the SS e36 S50B32 muffler is at the volume level of the SS's e46 M3 "sport" muffler-- which is more volume than I want for this car.
Old Fri, Jun-16-2017, 07:12:53 PM   #12
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Reputation: 0 bmw m3 s50 is on a distinguished road
Portugal
Yes, my friends have had Chris do work on their cars that many have said to be impossible. He truly is a genius, dedicated, and meticulous in his work. He is also super nice guy.
You have the US spec muffler or Euro Spec?
I was under the impression that the US spec exhaust piping diameter was 2.25" while the euro exhaust piping diameter was the same as the e46 at 2.36".
Jump to top bmw m3 s50 is offline   Reply With Quote
Old Fri, Jun-16-2017, 07:25:15 PM   #13
Have you ever checked out Chris's e39 540i? <3100 lbs, with full interior! And sealed OE monoballs everywhere, in place of bushings.
From people that know e36 M3's inside and out, the euro and US car are both 2.36" after the neck down point-- the US muffler is just narrower up front, where it meets the mids. I sure hope that's correct, or I'm going to regret not getting a euro muffler!
Old Fri, Jun-16-2017, 07:36:58 PM   #14
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Portugal
I have never seen that car personally but have talked to him about it. I remember back when I got my 540i, I asked him for pointers on what was worth doing on that car. Sadly, I have not seen him in years.
If Chris said that both mufflers are the same then that is right. He has forgotten more about BMW's then most people know. I was unsure about the mufflers but I know the US and Euro have different size exhaust piping. In the e36 M3 days that was a big upgrade with highly modded e36 M3's.
The Supersprint would have weight advantages over the OEM spec but if noise is an issue then it might not be worth it.
Old Fri, Jun-16-2017, 08:37:27 PM   #15
PITT M3 RR
PA
PITT M3 RR's Avatar
Excellent solution - looks amazing
S54 E36 BUILD
Old Fri, Jun-16-2017, 08:41:02 PM   #16
Theaxiom
Reputation: 0 Theaxiom is on a distinguished road
Why not just a custom muffler, sorry if I missed it?
Jump to top Theaxiom is offline   Reply With Quote
Old Fri, Jun-16-2017, 08:51:45 PM   #17
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Euro mufflers are different internally compared to US spec. I've had 3 and 2euro mufflers. All used.
The us mufflers kept coming loose internally (rattling) after a few km. Euro will last longer. Ended up buying a new euro 3.2 muffler which is different from the 3.0 internally.
I ran a euro decat SS mid sections tho, so that might have contributed in them breaking very easily.
So far no issues at 4,000km.
Sent from my Robin using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Old Fri, Jun-16-2017, 09:12:18 PM   #18
There isn't one that's quiet enough that fits. M54 is quiet compared to the s54-- so any muffler designed for that location for the m54 isn't nearly quiet enough (was stock volume levels).
Old Fri, Jun-16-2017, 10:06:37 PM   #19
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
Any power loss when you added the e36 rear? Reason I'm asking is because you went from 2.36 to 2.00 piping, plus have you ever seen the inside of the e36 M3 muffler? 4, 180* turns and the piping just before the tips actually necks down to 1.5"
I know this because I just open my muffler and took out the entire guts, and remade the muffler using 2.5" piping and peforated core pipe with stainless packing. The sound is very good and gave a nice "butt dyno" feel up top.
This is my thread here
https://www.bimmerforums.com/forum/s...ttle-different
Old Fri, Jun-16-2017, 10:10:20 PM   #20
Brian N
wubalubadubdub
Brian N's Avatar
Awesome. I'm a sucker for projects like this.
-My Journal-
Discussing My "custom" (stock?) M3 wagon exhaust in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
