Old Thu, Jan-29-2015, 01:58:09 AM   #21
Steezy
Reputation: 0 Steezy is on a distinguished road
Default Re: OE Euro Mirrors for $60 shipped
Originally Posted by BearDeXPS View Post
All these that are sold super cheap have a significant amount of scratches and possibly already failing... I had to go through a dispute.
I ended up getting some other ones that would have cost around $90 shipped (from Latvia)... I would just take my lesson and only buy the units that are 5 out of 5 stars.
I also applied a bead of clear silicone around the perimeter before installing at the gap between the lens and backing plate to help mitigate moisture behind the lens causing it to fail.
The people who bought these from this seller reviewed them very positive. They said they were in excellent condition. Maybe you had a bad set.
Jump to top Steezy is offline   Reply With Quote
Old Thu, Jan-29-2015, 02:15:29 AM   #22
Shadytype
Undercarriage checker
Reputation: 0 Shadytype is on a distinguished road
You cats that got a set will NEED TO FOLLOW UP on this post and let is know how they are.
Better the community.....
Jump to top Shadytype is offline   Reply With Quote
Old Thu, Jan-29-2015, 02:22:33 AM   #23
Steezy
Will do, hopefully they don't take too long to deliver
Old Thu, Jan-29-2015, 02:45:38 AM   #24
Andy2108
Andy2108's Avatar
Reputation: 0 Andy2108 is on a distinguished road
Might pick some of these up...
EDIT: Looks like he might not have any more available?
Jump to top Andy2108 is offline   Reply With Quote
Old Thu, Jan-29-2015, 04:05:27 AM   #25
Alotaps
Reputation: 0 Alotaps is on a distinguished road
He only had about 3 left when I posted this. They went within the hour. $60 shipped is ridiculously cheap for these.
There are a couple of other sellers selling the same thing for around $90 shipped - which is around the same price as Khoalty, Bimmian, etc... however, these are OE which are $270 at ECSTuning.
Jump to top Alotaps is offline   Reply With Quote
Old Thu, Jan-29-2015, 02:50:56 PM   #26
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
Agreed, I was going to list my set for $100 shipped, this was a steal!
-Chauncey
2003 E46 M3 COUPE - With "bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension/Braking: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Check out my for sale threads:2003 BMW E46 M3 Coupe TiAg/Blk (Supercharged & Track Ready)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Thu, Jan-29-2015, 04:32:25 PM   #27
Blanchimont
License Revoked
Blanchimont's Avatar
Reputation: 0 Blanchimont is on a distinguished road
Will definitely provide a review once I have them!
Jump to top Blanchimont is offline   Reply With Quote
Old Thu, Jan-29-2015, 06:07:01 PM   #28
lmattiso
lmattiso's Avatar
Reputation: 0 lmattiso is on a distinguished road
Originally Posted by Aavi View Post
Does the heating element work for all E46 M3's (pre or post facelift?) or do you need a cold weather package for it to work?
And for pre-facelift - what I gather from your statement is that you need create slack by basically trying to see if you can extend the wire so it will plug into the Mirror base plate heating element connector, right?
I'm not sure if all M3's have the wiring for heated mirrors but it looks like OneTimeM3 installed them fine and he doesn't have the cold weather package (I do however). You're correct, there are two wires that need to be extended a bit to plug into the mirror base heating element.
Here's where I got mine from, the pictures were exactly what I received and the quality was almost perfect.
Ebay uswomanseller
Here's a comparison of the old and new driver's side mirrors.
Jump to top lmattiso is offline   Reply With Quote
Old Thu, Jan-29-2015, 10:44:25 PM   #29
Steezy
Nice. How long they take to deliver?
Old Thu, Jan-29-2015, 11:10:59 PM   #30
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
would bang.
Discussing OE Euro Mirrors for $60 shipped in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
