Old Wed, Jan-28-2015, 04:22:50 PM   #11
Steezy
Reputation: 0 Steezy is on a distinguished road
Default Re: OE Euro Mirrors for $60 shipped
Originally Posted by lmattiso View Post
Keep in mind, for pre-facelift E46's I believe the heating element wires have to be moved a bit to fit the back of the Euro mirrors. On my 2003, I was able to make enough slack by removing some wire wrapping and stretching them out as far as they could go.
I have a 2004 - direct plug and play yes?
Jump to top Steezy is offline   Reply With Quote
Old Wed, Jan-28-2015, 04:24:58 PM   #12
lmattiso
lmattiso's Avatar
Reputation: 0 lmattiso is on a distinguished road
Yes, it's a 15 minute job. Even for 2003 and older, if you can get enough slack on the heating element wires, it's really simple.
Jump to top lmattiso is offline   Reply With Quote
Old Wed, Jan-28-2015, 04:28:31 PM   #13
Steezy
Cool thanks
Old Wed, Jan-28-2015, 04:31:47 PM   #14
Shadytype
Undercarriage checker
Reputation: 0 Shadytype is on a distinguished road
Dammit!!
Jump to top Shadytype is offline   Reply With Quote
Old Wed, Jan-28-2015, 04:53:59 PM   #15
cold m3
___///M3___
cold m3's Avatar
Reputation: 0 cold m3 has disabled reputation
Already installed a pair on my car. I love them!
Photos of My ///M3
Jump to top cold m3 is offline   Reply With Quote
Old Wed, Jan-28-2015, 05:05:06 PM   #16
Blanchimont
License Revoked
Blanchimont's Avatar
Reputation: 0 Blanchimont is on a distinguished road
Does the heating element work for all E46 M3's (pre or post facelift?) or do you need a cold weather package for it to work?
And for pre-facelift - what I gather from your statement is that you need create slack by basically trying to see if you can extend the wire so it will plug into the Mirror base plate heating element connector, right?
Jump to top Blanchimont is offline   Reply With Quote
Old Wed, Jan-28-2015, 05:17:36 PM   #17
Steezy
I just found them on ECS... $287!!!! Glad this was posted
Old Wed, Jan-28-2015, 05:21:02 PM   #18
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
dammiT!
Old Wed, Jan-28-2015, 06:40:43 PM   #19
BearDeXPS
BearDeXPS's Avatar
All these that are sold super cheap have a significant amount of scratches and possibly already failing... I had to go through a dispute.
I ended up getting some other ones that would have cost around $90 shipped (from Latvia)... I would just take my lesson and only buy the units that are 5 out of 5 stars.
I also applied a bead of clear silicone around the perimeter before installing at the gap between the lens and backing plate to help mitigate moisture behind the lens causing it to fail.
Jump to top BearDeXPS is online now   Reply With Quote
Old Wed, Jan-28-2015, 11:17:01 PM   #20
OneTimeM3
Reputation: 0 OneTimeM3 is on a distinguished road
Sweden
At the bottom of the first page of this thread, I did a little writeup of the Koalty versions. It'll show you how the heater connectors are on the opposite side, so the wires will barely be long enough.
I also wrote up instructions on how to remove your old mirrors, which are easy to break if you don't know how it's done.
My 2004 M3 doesn't have the cold weather package, yet the heated mirrors work fine. I've been happy with the Koalty versions too. There seems to be no lack in quality of these mirrors.
Jump to top OneTimeM3 is offline   Reply With Quote
Discussing OE Euro Mirrors for $60 shipped in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
