Old Tue, Sep-09-2014, 05:41:57 PM   #21
ZCPE46
aka EVILZCP
ZCPE46's Avatar
Reputation: 0 ZCPE46 is on a distinguished road
Default Re: Mishimoto E46 M3 Oil Cooler Build Thread
IM IN!!
Jump to top ZCPE46 is offline   Reply With Quote
Old Tue, Sep-09-2014, 07:09:03 PM   #22
kokgo20
kokgo20's Avatar
Looking for track data logging.
Build thread
Jump to top kokgo20 is online now   Reply With Quote
Old Tue, Sep-09-2014, 11:21:33 PM   #23
Teslazerok
Reputation: 0 Teslazerok is on a distinguished road
Well this build is coming together really quick!
Looks awesome.
Originally Posted by WuBai View Post
Price is a bit shocking, but I'm already so numb about spending money on this car that I just clicked 'buy' with a thousand yard stare into nothingness.
Jump to top Teslazerok is offline   Reply With Quote
Old Wed, Sep-10-2014, 02:28:05 PM   #24
Mishimoto
Mishimoto's Avatar
Reputation: 0 Mishimoto is on a distinguished road
Originally Posted by mdavidm3 View Post
looking forward to seeing your data logs
Originally Posted by ECSTuning View Post
Looking good guys!
-James
Originally Posted by ZCPE46 View Post
IM IN!!
Looks awesome.
Thanks for following along guys! We should have another update within the next few days.
Mishimoto Automotive
Jump to top Mishimoto is offline   Reply With Quote
Old Thu, Sep-11-2014, 02:13:03 PM   #25
Mishimoto
Mishimoto's Avatar
Another quick update guys!
Mishimoto BMW E46 M3 Direct-Fit Oil Cooler Kit, Part 3: Cooler Comparison and Adapter Installation
Welcome to our third installment of the build! We are nearing the completion of this project, with only some final test fitting necessary and data collection to ensure that this product performs to our standards. First, take a look at the Mishimoto oil cooler compared to the stock unit.
Mishimoto prototype oil cooler (right) and stock oil cooler (left)
Mishimoto prototype oil cooler (top) and stock oil cooler (bottom)
Mishimoto prototype oil cooler under stock oil cooler
The Mishimoto oil cooler is massive compared to the stock unit. Greater size will provide improved capacity that will aid in reducing temperatures. Additionally, the Mishimoto cooler is constructed using a bar-and-plate core that our engineering team designed. This core will provide improvements in heat transfer compared to the stock tube-and-fin cooler. For reference, the images below show the core size difference.
Stock oil cooler thickness
Mishimoto oil cooler thickness
The Mishimoto oil cooler boasts an increase in thickness of over 1 inch! We will have a more in depth evaluation of the core size later on. First, letís install our oil line adapter setup in preparation for cooler testing!
Mishimoto oil line adapter installed
That concludes the third part of our build log. Next time we will be installing our prototype cooler, setting up our sensors and lines, and collecting testing data for our cooler design.
Thanks for reading!
Old Thu, Sep-11-2014, 02:17:12 PM   #26
6spd_legend
Reputation: 0 6spd_legend is on a distinguished road
Thanks for reading!
Thanks for the update. This is looking like a solid option if the price is competitive for those of us who need to upgrade (me)- would be curious to see how this compares to the bimmerworld unit.
1995 6 speed Acura Legend Coupe
2001 LSB BMW e46 m3 turbo 720whp (FSR built)
2006 WW Mitsubishi Evolution MR SSL stock
Jump to top 6spd_legend is offline   Reply With Quote
Old Thu, Sep-11-2014, 02:58:44 PM   #27
Mishimoto
Mishimoto's Avatar
No problem, thanks for taking the time to look through it. Our pricing will be very competitive with the other options on the market. Unfortunately, we do not publish any product testing results against competitor components. We will be doing a full cooling comparison against the factory cooler which will be posted up either tomorrow or early next week.
Thanks again!
Old Thu, Sep-11-2014, 03:04:54 PM   #28
Bumnah
Reputation: 0 Bumnah is on a distinguished road
The new AN lines look to be routed the same as factory, so I suspect the length is similar to stock. The diameter of the lines looks to be larger than factory.
Will you be able to detail the oil pressure differences pre/post oil cooler upgrade, including oil pressure when the engine is hot/cold at idle and in operation?
Between this build and the e46 radiator build you guys seem to have really taken an interest in upping your build quality. Hats off! I've received great customer service from Mishimoto when dealing with your older style e46 radiator, frankly I wish you nothing but the best in business. I may be a part of this oil cooler buy too!
Jump to top Bumnah is offline   Reply With Quote
Old Thu, Sep-11-2014, 03:37:58 PM   #29
6spd_legend
Thanks again!
Looking forward to the test results- any insight on potential release date?
Old Thu, Sep-11-2014, 03:41:21 PM   #30
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
how much more oil capacity is this over stock?
Jump to top mdavidm3 is online now   Reply With Quote
Discussing Mishimoto E46 M3 Oil Cooler Build Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
