Old Mon, May-02-2016, 01:37:00 AM   #171
6spd_legend
Reputation: 0 6spd_legend is on a distinguished road
Default Re: Mishimoto E46 M3 Oil Cooler Build Thread
Originally Posted by Mishimoto View Post
We are definitely interested in any additional results from this past season. The diverter could definitely be reducing the impact of the cooler a bit. You could bypass the diverter and run an in-line thermostat. We do have a -10AN in-line unit that is pretty slick.
This would allow the oil to properly warm-up to your choice of activation temperature (160, 185, 200) prior to running fluid to the cooler.
Correct, a small percentage of oil flow will still reach the cooler prior to thermostat activation.
+1!
-John
Is anyone running this inline oil thermostat? I'm having an overcooling issue w/ my mishimoto oil cooler- car takes forever to warm up so I'd like to add this to the mix.
1995 6 speed Acura Legend Coupe
2001 LSB BMW e46 m3 turbo 720whp (FSR built)
2006 WW Mitsubishi Evolution MR SSL stock
Jump to top 6spd_legend is offline   Reply With Quote
Old Tue, Jul-18-2017, 04:11:29 AM   #172
bigjae1976
It's the same thing as the $45 unit on eBay. I'm about to run it in a month. It's installed...just need to finish the roll cage and get the car on the road.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Nov-14-2017, 09:39:20 PM   #173
TheGenius46M
TheGenius46M's Avatar
Bump for info on in-line thermostat. Looking to pickup one of these soon with a diverter valve and was wondering if anyone has dimensions for the AN lines needed to hook this up plug and play to the OE oil cooler?
2003 E46 M3 TiAg/Cinnamon 6MT
Karbonius | MCS | Volk | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
Old Tue, Nov-14-2017, 09:49:54 PM   #174
Tiago
Tiago's Avatar
Reputation: 0 Tiago is on a distinguished road
It depends of your setup. VAC use -10AN fittings for oil cooler and oil filter housing adapters. Just buy the thermostat with the same fittings size and buy in lenght excess the oil tube. The tube is too cheap to worry with wasted tube, and cut in place for the correct size. Then go to any specialized shop to install the -10AN fittings on the tubes.
ESS VT2-575 / AEM WMI / Supersprint Race System / 3.91 Diff / Stoptech ST60 and ST40 / Bilstein PSS9 / UUC Sways
CLICK HERE FOR PICS OF MY CAR_______________"On the street, fun is better than speed"_______________
Jump to top Tiago is offline   Reply With Quote
Old Tue, Nov-14-2017, 09:55:08 PM   #175
TheGenius46M
Originally Posted by Tiago View Post
It depends of your setup. VAC use -10AN fittings for oil cooler and oil filter housing adapter. Just buy the thermostat with the same fittings size and buy in lenght excess the oil tube. The tube is too cheap to worry with wasted tube, and cut in place for the correct size. Then go to any specialized shop to install the -10AN fittings.
Oh ok. I was under the impression that the tubing most people were using doesn't contour to tight areas very well, but I may be wrong.
Any recommendations on tubing? If this is as simple as it sounds, going to do this sooner rather than later!
Old Tue, Nov-14-2017, 10:06:39 PM   #176
TheGenius46M
Hmm... Looks like I just need two of these kits, -10 AN adapters and some hard lines
https://www.turnermotorsport.com/p-4...6-e46-e82-e9x/
Old Tue, Nov-14-2017, 10:07:31 PM   #177
Tiago
Tiago's Avatar
link to my setup
Old Tue, Nov-14-2017, 10:07:41 PM   #178
bigjae1976
I have this...works fine.
https://rover.ebay.com/rover/0/0/0?m...2F122275115738
Old Tue, Nov-14-2017, 10:43:00 PM   #179
TheGenius46M
Where did you end up mounting yours? Any issues with oil reaching operating temp or does it function like oem for warmup?
Old Wed, Nov-15-2017, 02:02:38 AM   #180
bigjae1976
I mounted it next to the power steering fluid reservoir. It works like normal. It recirculates most of the oil back to the engine. There is a small amount of oil that goes through the cooler during warm up to maintain pressure in the oil cooler loop.
Discussing Mishimoto E46 M3 Oil Cooler Build Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
