Old Fri, Aug-29-2014, 04:28:13 PM   #1
Mishimoto
Mishimoto's Avatar
Reputation: 0 Mishimoto is on a distinguished road
Default Mishimoto E46 M3 Oil Cooler Build Thread
Hey guys,
During the process of designing and testing our aluminum radiator for the E46, we mentioned on several occasions that we were working on an oil cooler solution as well. We are finally nearing completion of the project and we have prepared a neat build log regarding the development process. Check out the process on our blog or posted below!
http://engineering.mishimoto.com/?cat=147
Mishimoto BMW E46 M3 Direct-Fit Oil Cooler Kit, Part 1: Product Introduction and Component Prototyping
The BMW S54 won the “International Engine of the Year” award at its inception in 2001 and was consistently on “Ward’s 10 Best Engines” list for four years. It’s hard to argue against the E46, an 8,000 rpm, 3.2L straight-6 producing over 330 hp and 260 ft-lb of torque, with a competent chassis, an exhaust note that straightens the neck hair of all within earshot, and a body styling that is unmatched in uniqueness. Although my opinion is slightly skewed, being a fan of most BMW products, many would agree that the E46 was a fantastic vehicle for the street and even better for the track. E46 M3 pricing has trickled downward over the past few years, meaning that even those on a tighter budget can find their way into the cockpit of one of BMW’s finest. We are seeing these vehicles at track days, drift events, parking lot autocross battles, and at the drag strip.
Many of our followers watched as we developed a new radiator design for the E46 M3. We took advantage of the talented engineering crew we have here at Mishimoto to develop and test a radiator solution for the M3 that would provide optimal performance in any condition that our customers could throw at it. We traveled to Florida for hot-weather testing and posted our development process on forums so the enthusiast world would get an inside look at what we do.
This project will be no different. We will be documenting the build process of our direct-fit oil cooler solution for the E46 M3. After successfully designing a performance radiator to efficiently decrease the S54 coolant temperatures, we turned our attention toward the oiling system of the venerable inline 6. Normal operating temperatures range from 170°F to 250°F (76.6˚C–121˚C); however, track driving has proven to raise temperatures to near 300°F (149˚C) for some folks. At certain points, the stock oil cooler cannot provide the efficiency needed to keep oil temperatures from rising. A 3,400 lb vehicle making repetitive 8,000 rpm pulls on a road course in 90˚F (32˚C) ambient temperatures is going to have some issues keeping cool. Our team felt the need to provide an oil cooler replacement that would enhance performance and provide improved efficiency for those who drive their M3 like they should.
Before jumping into this project, we set a few goals to keep our team on the same page throughout the process and to help visualize the end product.
Project Goals
  1. Kit must be direct fit, all inclusive, and require no irreversible vehicle modification.
  2. Must provide a proven reduction in oil temperatures.
  3. Pressure loss must be similar or better compared to the stock cooler.
  4. Must function with stock or Mishimoto radiator.
Let’s break these goals down a bit.
Fitment
Fitment is always an enthusiast’s concern when installing an aftermarket component. Fitment is a goal for 99% of the products we develop. Vehicle modification is a touchy subject with consumers, and we understand this completely. This kit will install similar to the stock cooler, and any components we add will be completely removable if one were to revert to the stock setup. Additionally, we will be including all components necessary to install this kit. This includes any hardware, fittings, etc. needed to bolt this cooler into position.
Cooling Performance
Cooling efficiency is the primary purpose of any heat exchanger. If you are having issues keeping your E46 cool on the track, we want to help solve that problem with an efficient product. We will be thoroughly testing this product to ensure that our cooler is more efficient than the stock unit. Aggressive driving demands a lot from a cooling system, and we want to provide the security and peace of mind needed to beat on your car lap after lap.
Pressure
Oil pressure is obviously important for the health of your vehicle. Manufacturers recommend both a high and low pressure limit for most engines. A general concern of most would be a low oil pressure situation in which bearings are starved of oil and wear is greatly accelerated. Normally when adding a larger cooler, pressure loss is increased slightly due to the increased volume. Our goal would be to provide near-stock oil pressure with minimal loss.
Radiator Fitment
This oil cooler design would need to function with both the stock radiator and the Mishimoto aluminum radiator. This means we would need to incorporate stock-style mounting points, something our engineering team would have no issues designing.
The first key component we would need in developing this kit is an oil cooler line adapter. From the factory, the E46 BMW uses hard lines from the oil filter housing down to the cooler. A portion of the lines consists of rubber hose to allow for flex. Our cooler would utilize -AN fitting connections, so we would need an adapter to convert to -AN at the filter housing.
First, we removed the stock oil filter housing from our test vehicle to collect dimensions needed to create our adapter.
Stock E46 M3 oil filter housing removed
Once removed, our team collected the necessary dimensional data and put a 3D model of our planned design into Solidworks. The adapter would consist of two fittings that press into the housing using an O-ring to create a seal. The opposite end of the fittings would feature the -10AN threads. Although slightly difficult to visualize and explain, the following images will help to portray this better. We would also need a plate that secured the fittings to the housing using a bolt in the center, similar to the way the stock lines mount. Check out a few renderings of potential designs.
Oil line adapter rendering
Once we selected a design and made a few minor adjustments, we were able to utilize our 3D printer to create a live prototype. You can now see the fittings and how they fit into the plate unit.
Oil line adapter 3D prototype
We then installed this prototype to check fitment in the stock housing we had on hand. This plate adapter will be using the OEM BMW O-rings to seal the fittings to the housing. We are also designing this adapter to function with the E90 oil filter housing to expand the product fitment. For reference, check out this 3D component mated to the E90 housing!
Oil line adapter 3D prototype in E90 filter housing
Now that we were able to confirm fitment of this component in the E46 housing, the E90 housing, and even the E36 housing (Euro only), we moved to the next portion of the process. A final prototype was machined from the materials we intended to use in producing this component. The fittings are crafted from CNC-machined 6061 aluminum, and the tie-down plate is machined from 303 stainless steel. Check out this final prototype next to our 3D printed unit!
Oil line adapter prototypes
We then verified fitment with our machined prototype on the oil filter housings to ensure it was identical to our previous prototype. As a side note, for those who prefer a DIY oil cooler setup for their vehicle, we will be offering this adapter as a separate product sold on its own. Whether you have an autocross E36 or need some extra cooling in your E90, this adapter will provide a simple solution to –AN fitting conversion. Check out a few shots of our final machined adapter prototype.
Oil line adapter final prototype
Now that we had an adapter designed and ready for testing, we would need to begin development of our actual oil cooler unit. Check back next time for the initial design and prototyping of our cooler!
Thanks for reading!
Mishimoto Automotive
Jump to top Mishimoto is offline   Reply With Quote
Old Fri, Aug-29-2014, 05:28:34 PM   #2
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
Default Re: Mishimoto E46 M3 Oil Cooler Build Thread
Nice piece so far! Looking forward to seeing progress.
Jump to top Ramp1 is offline   Reply With Quote
Old Fri, Aug-29-2014, 06:02:53 PM   #3
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
subbed to see how this progresses
Jump to top mdavidm3 is offline   Reply With Quote
Old Fri, Aug-29-2014, 06:11:44 PM   #4
lowbudget
Reputation: 0 lowbudget is on a distinguished road
3d printing making r&d so much easier
Jump to top lowbudget is offline   Reply With Quote
Old Fri, Aug-29-2014, 06:36:35 PM   #5
Mishimoto
Mishimoto's Avatar
Thanks for taking a look!
Agreed! The use of our 3D printer has made a significant impact on our product development timelines. We are able to test fit a majority of our components much quicker than if we had constructed an actual prototype. This allows us to fine-tune the component before the functional prototype is fabricated.
Old Sat, Aug-30-2014, 09:33:12 AM   #6
ZCPIBM3
Reputation: 0 ZCPIBM3 is on a distinguished road
Definitely subbed.
2006 M3 ZCP Interlagos Blue
Jump to top ZCPIBM3 is offline   Reply With Quote
Old Thu, Sep-04-2014, 07:44:40 AM   #7
gruppeM3
Motorsport Addict
gruppeM3's Avatar
Reputation: 0 gruppeM3 is on a distinguished road
Please let me know when the group buy takes place.
Jump to top gruppeM3 is offline   Reply With Quote
Old Thu, Sep-04-2014, 09:39:33 AM   #8
Avplayer
Avplayer's Avatar
Reputation: 0 Avplayer is on a distinguished road
very interesting
Jump to top Avplayer is offline   Reply With Quote
Old Thu, Sep-04-2014, 09:44:51 AM   #9
potetuew
Reputation: 0 potetuew is on a distinguished road
Jump to top potetuew is offline   Reply With Quote
Old Fri, Sep-05-2014, 03:39:06 PM   #10
longms
longms's Avatar
Reputation: 0 longms is on a distinguished road
Very interested in the process of and engineering of this product. Sub'd for more!
Jump to top longms is offline   Reply With Quote
Discussing Mishimoto E46 M3 Oil Cooler Build Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
