Old Fri, Aug-07-2009, 04:24:10 AM   #21
TurboDave
TurboDave's Avatar
Reputation: 0 TurboDave is on a distinguished road
I guess I'm the next lucky contestant that gets to try this as well. I'll be opening the dash and seeing if the torx are tight and then replacing it, if removing it and reseating it doesn't help. My symptoms seem to be limited to the blower just not working randomly. All the controls light up and work and when the blower is operating it does match the set fan speed.
Jump to top TurboDave is offline   Reply With Quote
Old Sat, Aug-08-2009, 05:19:13 AM   #22
bigneil
bigneil's Avatar
Reputation: 0 bigneil is on a distinguished road
Originally Posted by kajtek123 View Post
Today the air suddenly stopped coming out of vents. all the lights on the digital unit were on and responding but no air. after few minutes the air starts coming out again for few seconds/a minute and then dies again. after i press the a/c button when the air is coming out, it suddenly dies. also, the air only comes out at one speed no matter what adjuster says.
any input appreciated
Yes replace the blower motor resistor, easy DIY, even if you only have 1 US patent.
Jump to top bigneil is offline   Reply With Quote
Old Thu, Aug-13-2009, 02:04:03 AM   #23
TurboDave
TurboDave's Avatar
Just got done replacing mine tonight. Did the trick! Yeah, cold air blowing again!!!
Old Thu, Aug-13-2009, 04:16:03 AM   #24
mikeowen00
Reputation: 0 mikeowen00 is on a distinguished road
A few weeks ago tightening the 2 torx screws on mine seemed to bring it back to life, but it's getting intermittent again. I ordered a new one (Behr brand) from Pelican today to swap the thing out before it leaves me with no ac in 100 degree heat. $43 isn't too painful a repair.
Mike
1996 M3 Black/Black
18 in Beyern Black Mesh wheels 8.5/225s & 9.5/255s
Eibach Racing Springs
Bilstien Shocks/Struts
AA Tuning X Brace
AC Schnitzer Front Strut Brace
Tri Flow Cat-Back Exhaust System
UUC Shift Knob
Jump to top mikeowen00 is offline   Reply With Quote
Old Tue, Jan-05-2010, 06:31:46 PM   #25
Synenergy52
Reputation: 0 Synenergy52 is on a distinguished road
My M3 stopped blowing air out of the blue about a few weeks ago. All lights on the control unit work perfectly, everything appears normal. No air.
So I buy a brand new FSU and pop it in and still no air. Does the FSU have to be bolted to properly test it out? I just plugged it in and turned on the fan. Seems you guys fixed your problems by tightening bolts. Unless bolting the thing in creates some kind of necessary ground I don't see how else plugging it in could be required for a proper test. I ended up putting back the old FSU and I'm this close to ordering a new blower :/
Jump to top Synenergy52 is offline   Reply With Quote
Old Fri, Apr-17-2015, 08:32:04 PM   #26
crazyseaman
chris chach
Reputation: 0 crazyseaman is on a distinguished road
Default Re: faulty motor blower or resistor?
I am bumping this because I really hate purchasing parts that wont fix the problem.
Mine basically just stopped working oneday. Has not come back on. Didnt notice any pulsating air. (only weird thing it did was come on by itself when I would put car in reverse on occasion) - best educated guess if I should buy the blower or the FSU?
came across this trouble shooting method. Not sure if this is correct, or if there is an easier way.
1. Pull the IHKA controller and measure the DC voltage from pin 3 of connector X18341 (the black one) to ground. (The shell of the cigarette lighter socket is a good ground.) It should be zero Volts at minimum fan speed and 8.5 Volts at maximum fan speed. If you don't get this signal, the problem is the controller.
2. Expose the final stage resistor connector following the procedures in the Bentley manual.
You should have 12 Volts from pin 2 to pin 4 (ground). You should also have 12 Volts from pin 5 to pin 4. If either one is missing it's a wiring or fuse problem. You should have somewhere between 0 and 10 Volts from pin 1 to pin 4 depending on the fan speed setting. If this signal is missing, the problem is probably the final stage unit, but it could be the blower motor.
3. As a final test, remove the connector from the final stage unit. Jumper pin 1 to pin 4 with a heavy gauge wire. (14 gauge solid minimum) Now jumper pin 2 to pin 5 with another piece of heavy gauge wire. The blower should spring to life. If it runs, the problem is the final stage unit. If it doesn't run, the problem is the blower motor.
themeetspot.info
Like me on facebook for NY events, and rollout info
CHACH:
2002 E46 M3 VERT (NEW PROJECT)
1987 E30 325iS (DAILY DRIVER)
1992 DA INTEGRA (SOLD)
Jump to top crazyseaman is offline   Reply With Quote
Old Thu, Aug-17-2017, 03:01:24 AM   #27
Sammyzuko
Registered User & Abuser
Sammyzuko's Avatar
Reputation: 0 Sammyzuko is on a distinguished road
Blower isn't blowing. I thought it might be the final stage unit so I wanted to check the torx screws before ordering a new one. No luck, but when I pulled it I noticed this sticker....that's not a made on date is it? It's a Behr unit and I assume it's factory original, but I found the sticker odd and wanted to check.
IMG_1520 by sammyzuko, on Flickr
Jump to top Sammyzuko is offline   Reply With Quote
Old Sat, Nov-11-2017, 08:17:25 AM   #28
margaldi
margaldi's Avatar
Reputation: 0 margaldi is on a distinguished road
Greece
Having same issues as you guys. Not blowing air, cold or warm. Replaced the FSU with a new Behr. Problem solved...
Sent from my SM-G935F using Tapatalk
Jump to top margaldi is offline   Reply With Quote
blower, faulty, motor, resistor
Blower motor or final stage resistor? mighty-dog E36 M3 (1992-1999) 2 Tue, Nov-28-2006 12:12:47 AM
Blower Motor Resistor rokayama General BMW Discussion 1 Mon, Jul-31-2006 07:03:36 AM
Blower Motor Resistor vs Final Stage Unit bigneil E36 M3 (1992-1999) 3 Sat, Apr-01-2006 12:23:20 AM
WT heck is the Final Stage Resistor (blower motor) on my 99 M3?! magas E36 M3 (1992-1999) 5 Sat, Jun-19-2004 06:01:40 PM
final stage blower resistor install??? punkska20 E36 M3 (1992-1999) 1 Fri, Jul-25-2003 07:46:52 PM
Discussing faulty motor blower or resistor? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
