Old Sat, Jul-05-2008, 11:33:29 PM   #1
kajtek123
Reputation: 0 kajtek123 is on a distinguished road
Default faulty motor blower or resistor?
Today the air suddenly stopped coming out of vents. all the lights on the digital unit were on and responding but no air. after few minutes the air starts coming out again for few seconds/a minute and then dies again. after i press the a/c button when the air is coming out, it suddenly dies. also, the air only comes out at one speed no matter what adjuster says.
any input appreciated
Jump to top kajtek123 is offline   Reply With Quote
Old Thu, Jul-10-2008, 08:25:21 PM   #2
helrotredMSedan
M3/4/5 Chaffeur
helrotredMSedan's Avatar
Reputation: 0 helrotredMSedan is on a distinguished road
Default Check your resistor first
My blower stopped working last summer, and all it ended up being was a loose final stage resistor. I tightened the 2 torx bolts on it, viola, everything has been working fine since.
HelrotRedMSedan - Chicago Burbs
Rides
-08 e90 M3/6 Jerez/Black Novillo EDC, 19s, Premium, Tech, Winter, CA
-07 e70 X5 SAV Sapphire/Black Nevada, 19s, Premium, Sport, Tech, Winter 1/2, CD Chgr, CA
-Past 98 Dinan M3/4/5 now in Alpine White/Dove
Sway Bars, Braided Brake Lines, Euro Floating Rotors, Dinan CAI, Dinan Exhaust
-Past 06 e90 325xi Sport Tip iDrive Japonrot/Black Dakota
Jump to top helrotredMSedan is offline   Reply With Quote
Old Mon, Dec-29-2008, 01:16:58 AM   #3
brensm3
Reputation: 0 brensm3 is on a distinguished road
i second this, my screw backed out on my stage resistor, tightened and good
Jump to top brensm3 is offline   Reply With Quote
Old Mon, Dec-29-2008, 09:22:24 PM   #4
BrokenM
BrokenM's Avatar
Reputation: 0 BrokenM is on a distinguished road
Same thing happened to me about 2 months ago, turned out to be the blower motor. Exact same symptoms.
Jump to top BrokenM is offline   Reply With Quote
Old Mon, Dec-29-2008, 09:38:30 PM   #5
Porschetech
Cocky Brit
Porschetech's Avatar
Reputation: 125 Porschetech is a name known to allPorschetech is a name known to all
England
i'd go with resistor......sounds like teh control unit is ok as you can still adjust your settings. i've found that with a faulty resistor, you cannot do anything with the headunit. you can't turn it off, you can't select speed and you can't adjust temp
I love all gingers 'n Plambers
Jump to top Porschetech is offline   Reply With Quote
Old Tue, Dec-30-2008, 04:02:20 AM   #6
mighty-dog
Reputation: 0 mighty-dog is on a distinguished road
My guess is also the resistor. That's because the fan blows at only one speed when it does operate.
I have a similar issue with my car except the blower speed matches the climate control setting when the blower runs. This is caused by a marginal terminal on the blower motor itself.
Jump to top mighty-dog is offline   Reply With Quote
Old Sat, Mar-14-2009, 12:26:23 AM   #7
shane82388
shane82388's Avatar
Reputation: 0 shane82388 is on a distinguished road
i know this thread is a bit old, but im having these same problems...where exactly is this "stage screw" located? id like to check and see if it got loose before i go buying parts and stuff...
any help? thanks
Jump to top shane82388 is offline   Reply With Quote
Old Wed, Mar-18-2009, 06:12:59 AM   #8
Montanvs
Montanvs's Avatar
Reputation: 0 Montanvs is on a distinguished road
Here is a great DIY
http://home22.inet.tele.dk/freddy_ja...les/bmw002.htm
I took everything apart thinking it was the blower motor, but it seems to be fine. Looks more like the final stage unit, which I'm going to replace this weekend.
Same symptoms, in that the control unit works, but the fan does not operate. It has been intermittent in the past.
1997 ///M3 No Mods, amazingly stock look
Okay some subtle Mods: CDV delete, wood trim delete, C43 stereo upgrade, ZKW headlights & clear corners.
Jump to top Montanvs is offline   Reply With Quote
Old Wed, Mar-18-2009, 02:18:39 PM   #9
badgtho
Team Nexen Racing
badgtho's Avatar
Reputation: 0 badgtho is just really nice
final stage unit.. where is Bigneil>
Current - '99 estoril/mulberry coupe || Past - '97 alpine/anthrazit coupe || 10,000+ post club || OG club
Badgtho can be rude but he certainly knows more than you.
A Moment of Zen, brought to you by BadGTho:
Originally Posted by salty View Post
At any rate, our MDX is running 5w20 and it can tow 3500 pounds.
Jump to top badgtho is offline   Reply With Quote
Old Wed, Mar-18-2009, 02:49:34 PM   #10
OahuMPower
:FACEPALM:
OahuMPower's Avatar
also going with the resistor due to only one fan speed when it does work..
same thing happened to mine
blower, faulty, motor, resistor
Blower motor or final stage resistor? mighty-dog E36 M3 (1992-1999) 2 Tue, Nov-28-2006 12:12:47 AM
Blower Motor Resistor rokayama General BMW Discussion 1 Mon, Jul-31-2006 07:03:36 AM
Blower Motor Resistor vs Final Stage Unit bigneil E36 M3 (1992-1999) 3 Sat, Apr-01-2006 12:23:20 AM
WT heck is the Final Stage Resistor (blower motor) on my 99 M3?! magas E36 M3 (1992-1999) 5 Sat, Jun-19-2004 06:01:40 PM
final stage blower resistor install??? punkska20 E36 M3 (1992-1999) 1 Fri, Jul-25-2003 07:46:52 PM
Discussing faulty motor blower or resistor? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
