Old Mon, Nov-13-2017, 10:48:23 PM   #11
M3 dude
Reputation: 0 M3 dude is on a distinguished road
Default Re: Backroads / 'Canyon carving' suspension
based on feedback i'm thinking of trying on a b12 or even b6+oem kit (i already have GC plates).
my gripe with coilovers is that they need constant adjustment and due to having FA isolation on the springs transmit alot of nvh (all bushings are rubber - except for subframe).
coilovers were fun for the previous 2 years that i had them, but novelty is wearing off....
Jump to top M3 dude is offline   Reply With Quote
Old Mon, Nov-13-2017, 11:09:49 PM   #12
EricSMG
40 something
Okay - for you I think the B12 + camber plates (and maybe adjustable rear lower arms) is going to be the ticket. This is a very stout/high performance setup that won't kill you on the street - it's firm but it's quite compliant most of the time. It's cheap, reliable and uses stock spring pads all around for maximum isolation.
It's a turn-key, set and forget badass setup. Drop is around 1/2" all around but it takes a while for the front to settle.
It might be a little soft for track use but I bet it'd work pretty well, overall.
'04 SG/Black 6MT || '04 JB/IR SMG
Jump to top EricSMG is offline   Reply With Quote
Old Mon, Nov-13-2017, 11:46:08 PM   #13
M3 dude
thanks. a mate is selling that kit.. might try it out
Old Thu, Nov-16-2017, 03:46:56 PM   #14
mercedesc63
Reputation: 0 mercedesc63 is on a distinguished road
Originally Posted by M3 dude View Post
hi all,
wanting to get some input on what is a good suspension combo for aggressive backroad driving (bumps / off camber etc).
im currently running MCA (Aust brand) coilovers (monotubes, digressive valving, single adjustable) with 500/600 springs, gc tops and weight jacks. so, plenty of adjustability available.
it does the job well, but given this is a firmer setup, the highway trips are abit of a chore - street driving isnt too bad.
does anyone have some pointers on how to set up a suspension for canyon carving / hard driving?
barely get out to the track.. so can compromise there.
help appreciated
I have The Bilstien PSS10 I just upgraded my wheels to 275/30 front and 285/30 rear from an 18" setup 245/40 and 275/35. Ride quality is surprisingly good and a welcomed loss of road feel in the steering. But the kicker is that even on almost full soft or setting 3 with a ground control sway bar it handles it's part compared to my much stiffer suspension I had previously (handled good but rode total shit).
2002 E46 M3 Jet Black/Black
Red Brembo BBK 355/345 4 pot
OG BBS LM 245 front/275 rear
H&R RSS Coilover/GC Camber Plates
Titanium Eisenmann Section 2
Miestershaft Eisenmann Ti Section 3
Ground Control Front/Rear Sway Bar
Ground Control Front End links
AOA Rear Adjustable Arms
CSL Front Tower bar
Painted Jet Black Kidney/Side Grilles
Valentine (1.85) Hardwired
Euro bumper (no reflectors)
Jump to top mercedesc63 is offline   Reply With Quote
Old Thu, Nov-16-2017, 06:09:06 PM   #15
Originally Posted by usdmej View Post
how bout KWv3 or clubsport since your'e interested in comfort for normal driving?
TC Kline coilovers also are also very streetable relative to the performance
KWV(anything) is too crappy of handling for a canyon carver.
KW Clubsports are too harsh for reasonable street use.
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, 03 530i, 04 M3 wagon
Old Thu, Nov-16-2017, 06:39:54 PM   #16
BBRTuning
BBRTuning's Avatar
Reputation: 0 BBRTuning is on a distinguished road
hi all,
help appreciated
I'm surprised to hear about your experience with MCS. Those rates aren't too extreme and should ride decently provided the damping is set up properly. It's really all relative though - everyone has a very different concept of what is "comfortable".
Where did you get them from? Gary over at GT Machino in Sydney is a suspension (and particularly MCS) guru and dealer for them. He has a kit on his car that rides fantastically. Might be worth talking to him about it.
///BBRTuning | 2001 LSB M3 6MT | AEM Infinity + flex fuel tuned by me | JE 11.5/Carillo S54 by Pure Performance | Moton Motorsport 3WR + rear coilover, 700/450, no rear bar | Stoptech Trophy BBK 6F/4R 355x32 | Apex SM-10 18x10+25 (x4) | BMW M 4.10 | Turner monoball FCAB/RTABs | Z3 rack | Lang Racing CF roof | Sparco Evo2 (x2) | AP Race roll bar
Jump to top BBRTuning is offline   Reply With Quote
Old Fri, Nov-17-2017, 12:52:25 AM   #17
David@ApexRaceParts
David@ApexRaceParts's Avatar
Reputation: 0 David@ApexRaceParts is on a distinguished road
Your most cost effective option would be to drop to a lower spring rate, then adjust your rebound to match the new rates. Outside of that, the B12 + camber plates setup should suit your needs quite nicely!
- Max
925.245.0773 | info@apexraceparts.com | Instagram | Facebook | Blog
Jump to top David@ApexRaceParts is offline   Reply With Quote
Old Fri, Nov-17-2017, 01:27:10 AM   #18
dothraki
Reputation: 0 dothraki is on a distinguished road
I have 8KG front and 12KG rear that came with the BC BRs. How do you compare this with OP's 500/600 spring rate? What is the stock spring rate?
Jump to top dothraki is offline   Reply With Quote
Old Fri, Nov-17-2017, 02:56:36 AM   #19
Paulo M
You guys making me want some pss10’s
What ever happened to kw’s? Just few years ago they were the “go to” coilovers even ahead of pss10’s. I liked them when I had it on my car, very comfortable and quiet. Didn’t get a chance to push them however.
BREMBO BBS DIXIS
Old Fri, Nov-17-2017, 05:31:53 AM   #20
BBRTuning
BBRTuning's Avatar
kg/mm*56 = lb/in, or just type “8 kg/mm in lb/in” into google for example and it will give you a calculator to play with.
Discussing Backroads / 'Canyon carving' suspension in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
