Old Fri, Apr-03-2015, 06:57:39 PM   #201
will.c
will.c's Avatar
Reputation: 0 will.c is on a distinguished road
Default Re: Fortune Auto Coilovers
Originally Posted by BBRTuning View Post
Thanks for the update! Could you elaborate on this? Did they come with endlinks?
My pleasure!
FA does not supply endlinks. I initially tried to use stock endlinks but they were too long. They hit the FCAs. So I went to Pep Boys and bought the most similar looking pair that were about the right length. Turned out Chevy Impala's endlinks fit pretty well, and since then I had no mechanical issues throughout several DEs and street use.
Recently when I went to corner balance, the shop kept on chasing the 50 lb difference in the front left and right. When they disconnected the front swaybar endlinks, that 50 lb difference went away. What had been happening was the non-adjustable endlinks preloaded the front coilovers. So they swapped out one (not both) endlink with an adjustable one from Turner.
I think a little bit of preloading doesn't really affect handling much, nor will a typical driver tell the difference especially on the street. I went with an adjustable endlink just because the shop had it.
Jump to top will.c is offline   Reply With Quote
Old Fri, Apr-03-2015, 08:31:07 PM   #202
BBRTuning
BBRTuning's Avatar
Reputation: 0 BBRTuning is on a distinguished road
Originally Posted by will.c View Post
My pleasure!
Interesting, so you asked for OEM replacement Chevy Impala endlinks? Happen to remember the year? Might do what you did and get a single adjustable link since like you said that's all you really need.
How about the rear?
///BBRTuning | 2001 LSB M3 6MT | AEM Infinity + flex fuel | JE 11.5/Carillo S54 | Streamline CSL box | Dbilas 288/280 cams | Moton 3WR rear coilover, 700/500 | Stoptech Trophy BBK 6F/4R | Slicer-spec BBS RIA Japan 18x10.5 et22 (x4) | BMW M 4.10 | Turner monoball FCAB/RTABs | Turner lower-rear + Wisefab upper arms | Z3 rack | Lang Racing CF roof | full interior 3310lb wet
Jump to top BBRTuning is online now   Reply With Quote
Old Fri, Apr-03-2015, 09:04:02 PM   #203
will.c
will.c's Avatar
How about the rear?
I bought ProSteer SL519.
http://www.pepboys.com/product/details/9873056/00059
For Turner's adjustable endlink, my shop had to machine a few additional threads so that it can be shorter. The shortest setting was still too long. I'd advise going with another mfr that's much shorter than OEM. FYI I just measured the ProSteer link, and it's about 7" long center to center.
Rear I kept OEM on both sides.
Old Sun, Apr-05-2015, 03:16:13 AM   #204
admranger
Registered troublemaker
My pleasure!
Any shop that tries to corner balance w/o first disconnecting the sway bar links does not have any idea what they are doing.
This is as elementary as it gets.
Sadly sold: Ď11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Ď19 X3M40i, Carbon/Oyster
Ď18 330i xdrive GT, Mineral White/Black
Old Mon, Apr-06-2015, 12:20:46 AM   #205
BBRTuning
BBRTuning's Avatar
If you read his post he said that he had NON-adjustable endlinks when he went to get corner balanced. Corner balancing the car with the endlinks disconnected, and then connecting them after balancing is silly because if there is preload it will throw everything off. The right thing to do is to adjust them so there is no preload and balance the car that way, which is what he did.
Thanks will.c for the info on the end links! I found these on ebay and they seem perfect and pretty inexpensive (adjustment anywhere from 6-10" with two different length links included:
http://www.ebay.com/itm/V-maxx-Adjus...a6c6a2&vxp=mtr
Old Mon, Apr-06-2015, 12:40:39 AM   #206
admranger
No, you always check without the end links connected, then add the end links and see whether they are influencing things (one end at a time). Otherwise you are just guessing. If you need an adjustable end link, then you'll know which end to put the adjustable end link on. Leaving them on and you could end up at zero cross-weights and still be completely wrong.
FWIW, my car was up on the scales a ton during my racing career. I know my way around this.
Old Tue, Oct-31-2017, 09:01:01 PM   #207
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
Bumping this. Would like to hear more feedback in regards to how these perform on track for a mid level/advanced driver.
Jump to top Fhcrubarb is offline   Reply With Quote
Old Tue, Oct-31-2017, 10:14:16 PM   #208
BBRTuning
BBRTuning's Avatar
Iíve been running my FA510s for a couple years now and overall Iíve been quite impressed for the price. Iíve had a lot of different level dampers on different cars and Iíd say these have the best damping characteristics vs. price that Iíve had. I recently had mine re-valved and upgraded to the newest spec ďCFDĒ design and theyíre even better damping and tuneabity wise.
Theyíre amazingly compliant on the street on full soft, and as you increase the damping, the high-speed compression remains quite comfortable for how responsive the car is. Iíve flung the car off plenty of curbs at the local tracks here and itís very hard to upset the car. They seem to have got the damping pretty close, as Iíve ended up running similar damping settings front to rear, depending on if Iím just street driving, canyons, or track. Other cheaper coilovers Iíve had on other cars you often end up with wildly different damping settings front to rear to get the suspension frequencies in line.
Iím now running 9kg (500lb) front Eibachs and 11kg (600) rear TCK VVS beehive in-board springs, and with 275 or 285 square tire setups and ~3300lb curb weight, I definitely need more spring rate all around. Iím at the point where I have the dampers at full stiff on track to try and help reduce roll, but even cranked up it really absorbs the bumps well. Iíve been impressed with how well the adjustment works for a single-adjustable. There really is a noticeable difference throughout the range, although I donít make a change smaller than about 3 clicks.
I use Vorshlag camber/caster plates with them, as the FA plates they provide only give you camber adjustment, and use the GC adjustable end links.
I did blow the rear dampers after about 1 year/10k miles of use, but I discovered it was my fault. I had the rear damper length adjusted too long, so that they were near their bottom travel at ride, and under compression were getting close to bottoming out. Run them like that long enough and youíll blow the damper. After rebuild, I set them shorter (although you do sacrifice a bit of droop) and have had no problems.
Going forward, Iím going to go up in spring rate and am considering having them re-valved and upgraded to the 2-way external reservoirs for more adjustment.
Old Fri, Oct-19-2018, 09:05:20 PM   #209
asianvenom
Reputation: 0 asianvenom is on a distinguished road
Resurrecting this thread from the dead: I just placed an order for the FA500 coil overs for my E46 M3, thanks to this thread. I have BC coilover on my 750il, but I feel like something is not right about it, as in getting tossed on decent size bump, no matter what my settings is, and even swapping swift springs a few times. coming from GC track coilovers from E36 M3 500/600lbs this never happen. Giving this FA500 a shot for the price. GC/camber plates will put it well over $2,500 not what I want to spend right now.
Jump to top asianvenom is offline   Reply With Quote
Old Sat, Oct-20-2018, 01:59:32 AM   #210
hopalong
Reputation: 0 hopalong is on a distinguished road
You won’t regret it. Love mine!
Jump to top hopalong is offline   Reply With Quote
Discussing Fortune Auto Coilovers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
