Old Mon, Nov-22-2010, 01:52:39 PM   #1
duvinclunk
nightman.
duvinclunk's Avatar
Reputation: 0 duvinclunk is on a distinguished road
Default SMG - Won't shift out of R in order to start car.
Ok so I pray to God that it is only the salmon relay but my car will not shift out of reverse into neutral in order to start the car. It literally has had ZERO problems up until this, no shift problems, not starting problems, nothing. I disconnected the battery to try and reset anything but it was to no avail. Has anyone experienced this?
11 E90 ZCP SG/B M3
06 ZCP IB/B M3 (Sold)
02 Tiag/R M3 (Sold)
Jump to top duvinclunk is offline   Reply With Quote
Old Mon, Nov-22-2010, 01:56:29 PM   #2
Touring
E46Fanatics
Touring's Avatar
Reputation: 0 Touring is on a distinguished road
Puerto Rico
try having someone move the car back and forth while you shift also push the brake hard
Jump to top Touring is offline   Reply With Quote
Old Mon, Nov-22-2010, 02:47:23 PM   #3
gixx750
gixx750's Avatar
Reputation: 0 gixx750 is on a distinguished road
+1 push on the brake harder!
Jump to top gixx750 is offline   Reply With Quote
Old Mon, Nov-22-2010, 05:08:10 PM   #4
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
x2, sometimes you really have to get on it.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Mon, Nov-22-2010, 07:33:36 PM   #5
ImolarotII
Red on Red
ImolarotII's Avatar
Reputation: 0 ImolarotII is on a distinguished road
Always have an extra salmon relay on your glove box.
This should almost be mandatory for us SMG owners.
Jump to top ImolarotII is offline   Reply With Quote
Old Mon, Nov-22-2010, 07:49:25 PM   #6
duvinclunk
nightman.
duvinclunk's Avatar
Yeah I pressed on the brake pedal harder and it worked. What does that do?
Should I get a salmon relay?
11 E90 ZCP SG/B M3
02 Tiag/R M3 (Sold)
Old Mon, Nov-22-2010, 07:58:04 PM   #7
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
also try opening the hood and then shutting it again.
if you already changed the salmon relay, then why have another one in the glove box? the likely hood of the relay going bad again is very slim
Tischer aka GetBmwParts
Old Mon, Nov-22-2010, 08:46:57 PM   #8
Touring
E46Fanatics
Touring's Avatar
Puerto Rico
so does your car work now?
Old Tue, Nov-23-2010, 04:57:50 AM   #9
duvinclunk
nightman.
duvinclunk's Avatar
Yes it works now. I just pressed the brake harder. What exactly does that do?
11 E90 ZCP SG/B M3
02 Tiag/R M3 (Sold)
Old Tue, Nov-23-2010, 05:22:26 AM   #10
AmirsM3
AmirsM3's Avatar
Reputation: 0 AmirsM3 is on a distinguished road
Weird. I'm curious about this, too, in case it happens to me.
2011 e90 M3 Space Grey DCT
2005 M3 SMG Convertible Jet Black : Depo Corners / DiCE SOLD
2007 350Z A/T Enthusiast Carbon Silver 296 rwhp 270 rwtq SOLD
2003 911S 6 Spd Guards RedStock
2010 Panamera Turbo Black PDK
Jump to top AmirsM3 is offline   Reply With Quote
car, order, shift, smg, start
Discussing SMG - Won't shift out of R in order to start car. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
