Old Thu, May-21-2015, 03:50:40 AM   #101
jhott66
Reputation: 0 jhott66 is on a distinguished road
Default Re: The definitive guide to self diagnosing your ABS/ASC light.
Originally Posted by Garage5 View Post
I have no power at pins 3,16, and 33 at my ABS harness plug. I do have power at 35 and 51. The relay is good. When the relay is pulled. I got 4 volts at 16 and 33. The relay is good though.
1999 BMW M3
What did you find was the problem? I also have no power at pins 3, 16, 33 with relay installed. I have 12 V with relay removed. It's a new relay.
Strange.
Jump to top jhott66 is offline   Reply With Quote
Old Fri, May-22-2015, 12:44:59 AM   #102
circuit_icon
circuit_icon's Avatar
Reputation: 0 circuit_icon is on a distinguished road
Just tested a BRAND NEW ABS relay and got 5 Mega Ohms between 30 and 30a. I suspect that the spec listed in this thread of 50-100 Ohms is incorrect.
Jump to top circuit_icon is offline   Reply With Quote
Old Fri, May-22-2015, 01:03:39 AM   #103
circuit_icon
As a quick and dirty test, I took an ABS pump that I had on the bench and plugged it in under the hood (so it's not installed, but it is "installed" as far as the electronics are concerned).
When we measure the resistance at the ABS computer harness, we were still getting around 40 Ohms for each pin, compared to around 8 when measured at the pump itself. So both pumps have similar resistances.
I then started the car with the different pump "installed", and the ABS light was still illuminated.
Old Sun, May-24-2015, 08:05:47 PM   #104
The Producer
The Producer's Avatar
Reputation: 0 The Producer is on a distinguished road
I feel your pain - I've been chasing an ABS/ASC light issue since christmas. Both relays and pedal sensor are new.
Found a guy with a GT1 setup (not emulated - authentic yellow diagnostic head) Cleared a bunch of old codes, none ABS related. We then queried the ABS computer directly and got a module not present error. New hypothesis/diagnosis is that I need a new ABS ECU.
I've read through all of these threads here and elsewhere, and I have a question that I haven't seen before. In a transition car like mine, with a round diagnostic plug and an OBD2 port, is it possible that certain modules can only be read from certain ports? Example: is it possible that the GT1 couldn't see my ABS/ASC+T modeule because we were connected to the round port? He didn't have the adapter to connect to the OBD2 plug.
Next step for me is a used ABS ECU I think. I just hate the thought of chasing this type of issue with parts.
Jump to top The Producer is offline   Reply With Quote
Old Sun, May-24-2015, 10:04:09 PM   #105
frbz
On the E36 the only thing accessible through the obdII port is the engine computer (DME). All other modules need to be accessed through the round port in the engine bay. The E46 lost the round port and all access to the modules is through the OBD II port.
Jump to top frbz is offline   Reply With Quote
Old Sun, May-24-2015, 10:09:52 PM   #106
The Producer
That's good for me - it removes a variable from the results of today's testing. Thanks for the info
Now I've got to dig out the module to get the part #, put it back in to stay mobile and swap it back out again when I find a replacement.
Old Tue, May-26-2015, 02:25:30 PM   #107
jhott66
The resistance value quoted at the beginning of this thread is incorrect. 5 MOhms is in the ball park of the correct value.
Old Tue, May-26-2015, 02:30:03 PM   #108
Is ABS light tied into traction control? Such that TC removal can trigger ABS light if the removal does not keep the TC electronics plugged in or have them bypassed,
Old Tue, May-26-2015, 10:24:41 PM   #109
circuit_icon
Thanks for clarifying.
Old Tue, May-26-2015, 10:25:32 PM   #110
circuit_icon
I'm wondering this too. I have TC removed in my car. But it was removed before having these ABS light issues.
abs or asc, definitive, diagnosing, guide, light
Discussing The definitive guide to self diagnosing your ABS/ASC light. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
