Old Mon, Oct-02-2017, 09:20:57 PM   #1
Daily Driver
Reputation: 0 Daily Driver is on a distinguished road
Default Alignment Tomorrow -- Full or half tank of gas?
Sorry for the noob question.... is there a preference to the amount of gas in the tank when you get a 4 wheel alignment? I read somewhere that the dealership adds 300# to simulate the driver, so the amount of gas must make some kinda difference.
Jump to top Daily Driver is offline   Reply With Quote
Old Mon, Oct-02-2017, 09:23:31 PM   #2
kokgo20
kokgo20's Avatar
Default Re: Alignment Tomorrow -- Full or half tank of gas?
I would shoot for 3/4 a tank so it would be something between full and low
Build thread
Old Mon, Oct-02-2017, 10:22:06 PM   #3
lmtfi
lmtfi's Avatar
An alignment? No difference really.
Corner balance - different answer. Maybe.
Old Tue, Oct-03-2017, 03:46:11 PM   #4
WuBai
Five Spiced and Lovin' It
WuBai's Avatar
+1
Good rule of thumb and recommended by all DIY sites that take home alignments to the extreme.
If possible see if you can get away with sitting in the car. It makes a difference of .4 degrees + and - camber for me on the front.
For those that say it makes no difference, I can't really argue. You may feel it or you may not, but if you do enough alignments you certainly will. I'd assume most people don't have the ability to do precise alignments at home so good enough actually is really good enough in most cases.
Old Tue, Oct-03-2017, 04:28:36 PM   #5
I'd shoot for 5/8 of a tank. Assuming you operate the car from 1/4-4/4 of a tank (fill up when it hits the 1/4 mark), your average fuel load will be (4/4-1/4)/2 +1/4 = 5/8 of a tank.
Old Tue, Oct-03-2017, 06:26:33 PM   #6
zeta456
Reputation: 0 zeta456 is on a distinguished road
United Kingdom
I think there is a TIS on this somewhere. It specified the amount of fuel in the tank plus weights in the driver/passenger seats. When I had mine done ( with a Hunter m/c) the tech had all this information to hand. Check with whoever is going to do it.
Jump to top zeta456 is offline   Reply With Quote
Old Tue, Oct-03-2017, 06:32:32 PM   #7
nowanker
"He's no wanker!"
BMW's specs for the added weight include a full tank of fuel.
In my experience... BMW's alignment specs typically have excess neg rear camber, and shorten tire life as a result. Anything you can do to increase the neg camber 'as measured' will result in more favorable (lower neg) values after returning to normal height. More weight=lower ride height=more neg camber.
If you're interested in a more performance oriented alignment, skip the dealer and find a performance shop!
Old Tue, Oct-03-2017, 06:59:04 PM   #8
11b4
11b4's Avatar
+1 don't do factory spec on the rear. My rear tires were Michilen PSS only last 10,000 miles if that with factory spec. And that wasn't doing burnouts or any fancy tire smoke stuff.
Old Tue, Oct-03-2017, 08:33:40 PM   #9
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
I like to have about 3/18ths or depending on the ambient temperature, about 27% empty.
just get an alignment man lol
Jump to top E46_USMC is offline   Reply With Quote
Old Tue, Oct-03-2017, 09:03:25 PM   #10
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
I think there's way too much thought going into this.. just align the damn thing!
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Discussing Alignment Tomorrow -- Full or half tank of gas? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
